Question about Toshiba Tecra 8000 Notebook
Format hard drive - Toshiba Tecra 8000 Notebook
How to recover lost data's in my computer after i formatted my hard drive
There are applications available that have varying degrees of success in recovering data from formatted hard drives. The bigger problem is whether or not you have written anything else to the drive since formatting it. These applications can recover the partition table and the File Allocation Table if things are pretty much pristine. What ever you do, don't put anything else on the drive you formatted. This will only corrupt things further and make recovery harder. If the data is crucial data, you may be better served getting a data recovery service to do it for you, although this can be very expensive and has no guarantee of success.
This link will take you a listing of many options for recovery. I cannot vouch for any of them.
Google
Sep 05, 2016 | Hard Computers & Internet
My glyph harddrive dont show up on my mac why?
If the hard drive was formatted on a PC computer in NTFS file format then the MAC will not recognise this hard drive.
If you want to transfer data between the PC and MAC then you need to format the hard drive with a PC in FAT32 file format. The MAC can read and write to a FAT32 formatted hard drive
Aug 08, 2012 | Glyph GT 050Q Hard Drive
Trying to format my hard drive and out of no where it is saying Can not format media is write-protected?
Use a program called Active Kill disk it is a free download this will wipe the hard drive clean every partition will be wiped clean just like from the factory it will then be like installing a new hard drive. Remember to rate my solution.
Apr 28, 2012 | Toshiba MK3265GSX 320 GB SATA Hard Drive
My toshiba 1 tb hard drive all ofa suddn says that i need to format it and i have alot for stuff on it that i need how can i make it work again
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 28, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
Hai i have transcand stor get 320GB hard disk. my propblem my computer detect the hard disk but when i try to open that it asks "do you want format it?" what shoud i do?.
If the computer is prompting that the drive needs to be formatted, this means either the drive has become currupt (not likely) or that the drive hasn't been formatted or is an unrecognised format
if the hard drive was formatted on a Mac or Linux machine without choose Fat32 format, the drive will be prompted to be formatted under a windows machine
if there is no information on that drive, i'd suggest just formatting it
remember formatting a hard drive removes all information off that hard drive.
May 12, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
How do I erase all data on my external hard drive?
depends on the erase you want to do. if you want a simple format just open my computer
right click the drive and hit format. select Quick format and then click the format button.
Apr 22, 2011 | Computers & Internet
Cannot format hard drive message appears : hard disk cannot be formated" all 20 hard drives on different computers giving me same problem
lets get all of the details first you say you cant access the hard drive then the message cant be formatted how are you trying to format the hard drives what procedure??? will need more imformation a hard drive must be formatted from a ""third party disc""
Apr 09, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
How do I format this hard drive to a FAT32 hard drive?
Go to My Computer, right click on the drive, go to format. select fat32 on the type list. Remember that this will delete all of the files on the Hard Drive.
Mar 03, 2011 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
How to format IDE hard drive?
This drive is an IDE drive. The jumpers can be set on it to make it a slave.
Once set as a slave, you can identify the drive letter given to this drive and format it either at a command prompt: C:> format [drive:] /s (to make it bootable) or no /s to just format it.- OR within Windows: right click on the drive letter and select format.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
My SmartDisk 80 gb FireLite hard drive says it is full but it is empty. What could be the reason for this and how would I format it? I use a Macbook pro. I dont want to have to buy a new external...
You will receive an error message when copying a file larger than 4GB to the hard drive if the drive is formatted FAT32. The FAT32 file system has a file size limitation of 4GB. You may also receive an error when backing up to the hard drive using backup software. To correct this problem you will need to format the drive to NTFS. If you are using Windows ME or 98SE, you will not be able to use NTFS.
There are some products that do not support the NTFS files system or changing their file system. If you own a FlashTrax/FlashTrax XT/FotoChute/PhotoBank/USB FireLite XPress, you cannot change the format of the drive to NTFS. It must be kept as FAT32 in order to operate properly. If you are using SOHO NAS via ethernet, do not format it to NTFS. If you have any questions, please contact technical support before you format the drive.
Warning: Formatting a hard drive erases all data from the drive. Please backup any data prior to formatting the hard drive.
To format to NTFS, open My Computer.
1.Right-click on the Verbatim hard drive, left-click on Format.
2.Select NTFS as the File System.
3.Place a check in Quick Format.
4.Click Start.
Once the format completes, you will be able to copy files larger than 4GB to the hard drive.
Feb 03, 2009 | SmartDisk FireLite 80GB 400Mbps FireWire...
Toshiba Tecra 8000 Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
