Question about Hitachi 1TB HDS721010CLA332 SATA2 U300 7200rpm 32MB SATA II Hard Drive
Hds721010cla332 how long is the warranty
How to connect a SATA2 HDD to a SATA1 motherboard?
It should work. If not, there are jumpers on some drives. Not a DIY task because it requires unusual skills. Does not always work in any case.
Jul 06, 2014 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
Hds721010cla332
is it recognize setup ? bios ?
Sep 26, 2013 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
Imminent harddrive failure
Hard Disk about to fail This warning means the hard disk will fail sometime in the near future. You need to back up your data regularly before the hard disk fails or you will lose your data.
Oct 01, 2012 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
How do I get Windows 7 to reconize my Hitachi HDS721010CLA332 HDD?
if it does not see the hard disk on installation or otherwise..it means you do not have the ahci (or raid ) driver installed ..and the laptop is set to run in this mode..but was installed without them ..the easy fix is go to bios ..look for the hard drive ,. and disable the ahci function for it ..and let it work on sata as ide ..or ide compatible ..or something like that ..anyway but not ahci ..save settings with F10 and restart and if you have a working windows on it ..it will boot proper and that's all ..if you do not have the windows..you can now install it further ..
The other option is to install windows from a usb flash ., and use the drivers disk in the drive ..and when it gets to the point where you select the partition ..it will ask for 3rd party drivers and you can select them on the disk and install ..or it will take them auto ..and this way you will have an installation of windows with the ahci function on ..and will be a little faster
have a nice day and don't hesitate to ask for future guidance ..
please rate my answer ..
Dec 20, 2011 | Hitachi HDS721010CLA332 Deskstar 7K1000C...
I purchased my old computer in 2009 and it came with the Hitachi HD, HDS721010CLA332 (0F10383). That computer has failed and I purchased a new HP Pavilion. Can I take the old Hatachi HD and make it a slave...
Hi there.
Since your hard drive is a SATA drive, there is no such thing as master and slave drive anymore.
All you need to do is plug it into your new computer (assuming there is an extra slot for a hard drive in there). You will need an extra plug from your power supply that will plug into the hard drive as well as a SATA cable that will plug your hard drive into the motherboard.
Another thing you can do is get an external hard drive enclosure and put it in that. Just make sure you get a SATA one, not an IDE one. I hope this helps.
Sep 08, 2011 | Hitachi HDS721010CLA332 Deskstar 7K1000C...
Hi, I have problem here. I just bought Hitachi Deskstar 7K1000.C. It works fine at first, but one day latter some clicking noise appear. It detected in BIOS, but then make my Windows take a very long time...
The short answer is the drive is having trouble calibrating itself, and should be sent back under warranty for replacement.
There are things you could try to recover the unit, but why risk voiding the warranty only to wind up with a questionable drive afterward?
Mar 17, 2011 | Hitachi Deskstar 7K1000.C HDS721010CLA332...
Drivers
The drivers are available at the Hitachi product support site, here is a web link to that site.
http://www.hitachigst.com/portal/site/en/drive-search/
Jan 16, 2011 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
Hitachi 1TB HDS721010CLA332 SATA2 U300 7200rpm 32MB SATA II Hard Drive Logo
29 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
