Question about Compaq Presario M2000 Notebook
Dead laptop Given: Compaq Presario M2000 Situation: Running fine, battery running low, so I plugged in AC power supply, PC suddenly went totally dead. Unplug AC, still dead. Remove battery, reinstall battery, PC still totally dead. Nothing, at all, no charging light, nothing, nothing at all. Is there a reset button or something, or did the mb blow out? Thanks.
  • Anonymous Dec 23, 2007
    daughter was on laptop using ac power with battery pack in/charged. all of a sudden the computer went dead - no power,at all. We tried without the ac cord, just battery and nothing. Took battery out and tried just ac, nothing. Let it sit, put ac cord in and out again, different outlet, etc. and still no power. I read found site with a manual/troubleshooing and it said to "reset power" but didn't explain how. Cannot find a button or info on this.
  • Anonymous Mar 14, 2014
    I am @ total loss. Up 24/7 to no avail. What's your advice?
Where is reset button
Posted on Jan 18, 2008
Where is the reset button
Posted on Jan 13, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Posted on Aug 27, 2007
  • rob love Aug 20, 2013
    Where is ther reset button?
SOURCE:
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
May 12, 2012 | Compaq Presario M2000 Notebook
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
Dec 11, 2010 | Compaq Presario M2000 V1000 V2000 V3000...
Have compac persario m2000. The power supply will
the issue might be with the power jack . i mean the port where you insert the charger.. to fix this issue your laptop needs to be repaired.
Jun 14, 2010 | Compaq Presario M2000 Notebook
Battery won't charge
This is true, you will not be able to charge the battery without the correct charger. For mostly all laptops, when the charger is not maintaining a charge, it is time for a new one. However, it does not have to be the manufacturer's adapter, but I recommend purchasing the battery made for the Compaq Presario M2000 Notebook.
NextTag.com has decent deals on these adapters. http://www.nextag.com/ac-adapter-compaq-presario-m2000/search-html
I hope this helps. Please let me know if you have any other questions.
Thank You, Raph30
Jan 25, 2009 | Compaq Presario M2000 Notebook
Presario m2000 no power
the same EXACT this happend to me! i didnt know what to do so i just a new charger at dell.com
Sep 12, 2008 | Compaq Presario M2000 Notebook
Compaq Presario M2000 DEAD
My power plug that goes in the computer gets hot enough to melt the plastic ring on the end of the plug. so i am going to get a new power board and try that.
Jul 27, 2008 | Compaq Presario M2000 Notebook
HP Compaq Presario V5000 PC - Shuts doen while plugged into AC adapter.
eather you have one or a couple of the following problems,
1. you have a bad battery
2. the power supply is defective
3. the charging circuit in the laptop is defective and the motherboard will require replacement or repaired.
Dennis
Jun 19, 2008 | HP Compaq Presario V5000Z Notebook
Computer wont come on
well, sounds like your power cord took a dump on you check and make sure power cord light is working first i would suggest
takeing up to office depo or computer store or maybe some one you has a lap like your try the power cord on it and see if it boots up that computer or takea differnt power cord and try reboot it they sale altn. power cords for laptops (cheaper in ebay ,ubid or just type in power cords in your search engine ). i hope this helps lala linda
Jun 03, 2008 | Compaq Presario M2000 Notebook
Presario M2000
i need intel presario m2000
May 08, 2008 | Compaq Presario M2000 Notebook
Compaq Presario M2000- DEAD
try check the power supply itself..it maybe losse connections or worn out!! Have it checked to a liscenced technician to provide you with further diagnosis of your problems.
Goodluck!!
Feb 05, 2008 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
571 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
