Question about Refrigerators
Crosley conservator Ice maker don't work
  • 31 Answers
SOURCE: Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
Posted on Jan 07, 2009
SOURCE: BROKEN DOOR BRACKET
Reliable Parts http://www.reliableparts.com/ has them in stock. The parts are made by Serviplus. According to Eric at their main number, there are several in stock in the San Francisco store. I called 877-733-9241.
One word of warning: when I went to pick up the part (I needed only the 221C6568), the first one they brought out was a 221C6578 that was mislabeled. You might want to ask them to verify before they ship them.
Posted on May 07, 2009
woodchuck789
  • 4070 Answers
SOURCE: crosley conservator is freezing, fridge not cooling
No, it is not normal. The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 05, 2009
ZJLimited
  • 17970 Answers
SOURCE: My frig is not geting
If the refrigerator is not running, first I suggest check to see if there is power to the refrigerator. Make sure the plug is properly seated in the socket and the temperature control is turned to the "on" position.
If "0F 0F" appears on the display, the refrigerator is in DEMO MODE. To exit Demo Mode for controls on the outside of door, Press and Hold the Energy Saver and Adjust Freezer buttons at the same time for 3 seconds. To exit Demo Mode for controls inside the Fresh Food Compartment, Press and Hold the Ice Off and Freezer buttons at the same time for 3 seconds. You will hear a beep and "0F 0F" will no longer be displayed. Adjust Refrigerator and Freezer temperature to the desired settings. Allow 24 hours for temperatures to stabilize.
If the refrigerator is running and not cooling or not cold enough, several factors may influence the temperature. Try the following:
* If the refrigerator has just been serviced, it could still be in a diagnostic mode. Please disconnect power to your refrigerator for 30 seconds and this should clear the control panel. The refrigerator should now cool normally.
Check the temperature control settings:
* For Dial or Digital Readout Models, adjust your temperature control by one number higher for a cooler temperature setting.
* For Actual Temperature Readout Models, adjust your temperature control by one degree lower for a lower temperature setting.
Additionally, for some troubleshooting tips, go here: Refrigerator-Troubleshooting
Keep us updated.
Posted on May 20, 2011
  • 7 Answers
SOURCE: water won't dispense but ice maker works
Most likely the valve has failed. Usually located in the back of the refrigerator, near the bottom - otherwise, follow your water line (feed from the house water supply).
Posted on Aug 02, 2012
My Crosley Conservator Ice maker will only produce crushed ice, HELP!
Ensure the Wire Signal Arm is not in UP position. • Ice maker should produce 2.5 to 3 pounds of ice in a 24 hour period. • Water supply is turned off. • Water pressure is too low. • The freezer is not cold enough.
Apr 15, 2015 | Crosley Refrigerators
I have a Crosley side by side refrigerator. I replaced my ice maker line due to a water line repair. Now, I can't get any water to come out the door or in the icemaker
Note: Always make sure your filter is current if you have one. Not doing so will cause water to not despence properly
Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out.If so, you just verified that the valve and electrical portions are working properly and either the filter is bad or the resevoir, , located inside the lower refrigerator side is frozen. If no water comes out but the valve vibrates, then the valve is bad. If no water and no vibration, continue reading.With the machine plugged in but the wires that go to the valve for the dispenser off take a volt meter and place a lead to each wire and have someone press the panel in the door as if getting water. The reading should go from 0 to around 115-120 a/c.If your not getting electricity down there at anytime than thje door switch is bad.
Testing the ice maker:
As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. For whirlpool and its subsidaries,you can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. For GE, you turtn the ice maker off, wait about a minute then turn back on, water should automatically shoot water in the icemaker. That will tell you the water valve is good and icemaker is bad, or the ice maker is good and the valve is bad if no water. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
Jun 17, 2012 | Crosley Refrigerators
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice maker doesn't dispense ice
The most reasonable things could be that the gas ran out; the buttons and thermostat don't work; power issues; or you might have a leakage on the gas pipe.
Try calling a fridge/air condition technician to verify this.
Nov 23, 2011 | Frigidaire FRS26RBCW Side by Side...
The ice maker in my fridge just stopped working.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
dfhghdgdhdsgh
Jan 08, 2010 | Crosley CFFH10W Top Freezer Refrigerator
Help Ice Maker problems
I'm not familiar with Crosley but you can get advice and parts from repairclinic.com but first of all find the model number & serial number. This is a great site for appliance
repair. Ken
Nov 24, 2017 | Crosley Refrigerators
Ice forming on the coils of my Crosley Conservator dehumidifier
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Jan 09, 2009 | Frigidaire FDL25P1 Dehumidifier
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
