Question about Electrolux Refrigerators
Electrolux fridge temperature control
Hello. I have an Electrolux Refrigerator. Model#EI32AR65JSO; Serial Number WA1090145. First it froze everything, then the temp went up to 78 degrees and wouldn't come back down. Called technician. He replaced the relay. It's been 7 hours and the temp moved from 78 to 76. Still think that something is very wrong. Can you help me?
myob247
  • 1342 Answers
SOURCE: GE Profile- Freezer/ Fridge at 56 wont go cooler!
More good into HERE
Posted on May 03, 2008
bobicehouse
  • 1524 Answers
SOURCE: fridge not holding correct temp. fridge is 55 and freezer is 25
Sounds like a defrost problem.
Posted on May 07, 2009
MNfisherman
  • 11896 Answers
SOURCE: Fridge is freezing everything!
There is a flap that directs the air from freezer to fridge. Sometimes this flap can stick Or the actuator that controls the flap can go out. Same with autodefrost timer which seems to give a lot of people trouble. Thermostat is at the top, uncirculated cold air sinks, food in the bottom of the fridge freezes.
Posted on Sep 09, 2009
shastalaker7
  • 1515 Answers
SOURCE: Hello
Hi, even though the freezer is working, you need to check the evaporator fan in the freezer to make sure it is running to move the air to the lower part of the box. If you open the door on freezer, make sure it doesn't have a switch around the perimeter that will shut the fan off. Some do and some will not. Check this and get back to me. You may have a faulty thermostat control. Get back to me and let me know about the fan motor. I will wait for you're response.
Shastalaker7
Posted on Jan 24, 2010
  • 1218 Answers
SOURCE: My GE Refrigerator model GSL25JTFBBS stay in
Good day,
35 minutes would be considered nominal. That is the amount of time needed to heat up the cooling coils behind the rear panel in the freezer compartment, and then allow it to drain the condensate water out the drain.
The defrost cycle is made up of 2 parts.
The first part involves shutting all fans and compressor off, and turning on the heater/heaters mounted on the bottom of the cooling coil to above freezing. About 10 to 15 minutes.
The second half occures when a defrost thermostat mounted on the top of that coil senses the coil is above freezing. It cuts the power to the heaters, and lets the system just idle, while the water is allowed to drain out of the drain.
If that tstat is working properly, the food temperature is affected slightly but never to an above freezing condition.
The thermostat is a small 1" round disk clipped to the top of the coil.
Only one possibility, but that tstat could be hanging allowing the freezer coil compartment to reach a very high temperature. If so, it needs replaced.
You should also check to see if both fans and compressor start running as soon as the cycle is done.
Posted on Mar 12, 2010
Why is the electrolux refrigerator won't hold set temperature? I set it +5 but its turning back to +18. What should i do? Not any of function mode could be set, its always turned to +18.
Hey Beke, thank you for your submission!
Based off the information you have provided your Electrolux refrigerator will not hold the temperature it is set to. When you set the temperature on the refrigerator it may take 24 hours for the temperature to stabilize. I may need your model number in order to further assist you. You can locate your model number on the inside wall of your refrigerator usually on a silver or white tag. With this information I would be able to assist you further. -Matt
Apr 09, 2016 | Electrolux Refrigerators
How do I completely clean the Electrolux Perfect Temp Drawer? Gravy has gone in-between the plastic parts.
Hello Gayle, thank you for your post!
I understand that gravy has fallen into the perfect temp drawer on your Electrolux refrigerator. In order to assist you further I would need to have the model number of your refrigerator. You can locate the serial tag (which lists your model number) on the inside wall of the fresh food side. With that model number I can research to see what additional information I can provide you with. I look forward to assisting you further. -Matt
Jan 02, 2016 | Electrolux Refrigerators
I need a compressor electronic control unit for Electrolux fridge with number VCC3 2456 56 F 71. Please replay. Thanks
Hello friend, thank you for your post!
Based off my understanding you need the compressor electronic control for your Electrolux refrigerator. If you could please provide me with your model number I would be able to assist you further. You can locate your serial tag (which lists your model number) on the inside right hand wall of your refrigerator usually on a silver or white tag. With that information I can better assist you. -Matt
May 26, 2015 | Electrolux Refrigerators
Need to order main control board part for Electrolux fridge but don't have model or serial number on fridge.
Hello Sandra, you usually always can locate the model number on the rear of the fridge, I'm not sure if you have looked their, but I'm sure you did if it's missing the only thing I can suggest I s you take several pictures of the Fridge front rear and inside so who ever is supplying the part can identify the model, I'm not sure if you have removed the main control panel if not then this is certainly the best option and take a picture of it as close as you can, the majority of all circuit boards have a code number to identify them tis would be your very best option, if as you say their is no code or model information on the rear of the fridge. I hope this is of some help to you.
Good luck on getting your part.
Mar 04, 2015 | Electrolux Refrigerators
How do I adjust freezer temperature on Electrolux refrigerator?
Hello friend, thanks for your inquiry!
I see that you would like to know how to adjust the temperature within your Electrolux refrigerator, EI23CS55GS1. To adjust the temperature you would use the control panel on the front of the freezer door. There should be a "-"or "+" near the freezer temperature control and that is how you would adjust the temperature within your refrigerator. Be sure to check and make sure that the control lock is not on or you will not be able to adjust the temperature. Any adjustments made within the refrigerator need at least 24 hours to stabilize. I hope this is has been helpful. -Matt
Oct 18, 2014 | Electrolux Refrigerators
The power went off then turned back on but the electrolux side by side refrigerator control shows off how can I reset back on.
Good Afternoon friend, thank you for your post!
I understand that your Electrolux refrigerator is not coming on. Is it displaying any codes on the panel? Would you be able to provide me with your model number that way I could research additional information for you please? You can locate your serial tag (which lists your model number) on inside wall on the right hand side. I look forward to your response. -Matt
Sep 16, 2014 | Electrolux Refrigerators
Serial number search engines
I understand that you would like to verify you have the correct part. I have provided a link where you can run your model number and it will provide you a parts manual. Within that manual you can search for all parts available for your refrigerator. I hope this helps. -Matt
Frigidaire Product Manuals
Sep 01, 2014 | Electrolux Refrigerators
Where is the reset button on my electrolux fridge?
Good Afternoon Friend, thank you for your post! I see the temperature in your Electrolux refrigerator is too warm and would like to know how to reset it. May I please have your model number? The serial tag, which lists your model number, is typically located inside the cabinet, on the right side wall. With this information I can better address the issue at hand. In the meantime, please double check the temperature control. If the temperature is set too warm, set control to a colder setting and allow 24 hours for temperature to stabilize. Thank you - Z.
Apr 22, 2014 | Electrolux Refrigerators
Electrolux fridge temperature control displays a "square"
Try lower either the thermostat setting or the airflow control to the refrigerator to see if the temps are lowered.
Nov 26, 2013 | Electrolux Frigidaire Fridge Defrost Timer...
Electrolux side by side refrigerator model E126SS55GSO touch pad on ice and water dispenser will not respond to touch, error code of CE on freezer and fridge temperature, alarm keeps beeping non stop. ...
You have a communication failure, check the wiring at the freezer door hinge and if it is ok replace the control beneath the unit if it continues replace the user interface as well.
Sep 22, 2013 | Electrolux Refrigerators
Refrigerators Logo
70 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
