Question about Seagate Expansion 1 TB USB 2.0 Portable External ST910004EXA101-RK Hard Drive
P/N 9SD2A2-500 where is dash board available?
How to pull dashboard on a 2005 Buick Lacrosse
I dont know that such thing is available but, any time you have to get a dash boar out, you have to remove the steering column as well, and that is not a simple thing to do. best luck to you
Dec 16, 2014 | Buick Cars & Trucks
My 2001 VW Polo oil pressure warning light comes on regularly after driving for approx 8 miles - oil level & pressure both appear to be ok and water level too. Oil sensors replaced but to no avail....
Have you checked your thermostat. Some cars do not have gauges for all componants of the car located on the dash board. A bad thermostat could drive the oil pressure gauge up, if there is not a coolant level gauge on the dash board.
Nov 27, 2010 | 1999 Volkswagen Golf
Dash lights, speedometer light, gear indicater lights don't work on 99 gmc truck
The gear indicator display can be repaired, the problem is due to a failed solder joint on the circuit board, it's not a difficult fix. There's a guide available for it here - Silverado odometer problems
Oct 28, 2010 | 1999 Chevrolet Silverado 1500
On my 98 cadillac deville my dash wont come on my the sides do but the odomder and gas guage wont . do you think it the circuit board .
Yes, I agree there probably is a problem with the circuit board.
The unit must be removed and replaced in order to reliably fix this problem.
I don't know anyone who would fix indiividual components on the boards.
Try the dealership.
Unfortunately, the car is out of warranty and over 10 years old so some parts are no longer available.
Try a salvage yard for parts.
That's all I know.
Jun 01, 2010 | 1997 Cadillac DeVille
The fan switch broken away from dash board Honda Accord 1997
You should be able to buy just the fan switch from Homnda.
May 24, 2010 | 1997 Honda Accord
HEADLIGHT FLICKER THEN SHUT OFF
check to ensure the connection is secure at the light socket itself even jiggle the connection to ensure this dirt etc may cause a faulty connection ...also is this just one or both headlights
Sep 12, 2009 | 2000 Ford Crown Victoria
Blower motor only works on high?
ther could be fuse or relay for that in fuse box (engine compartement
Jul 21, 2009 | 2002 Chevrolet Cavalier Coupe
Cannot find where to plug 16 pin diagnostic controller
graham, the only 99 civic engine available in the US is the 1.6 L, so this might not help u, but the 1,6 is the traditional location : driver side, under dash, driver side of steering column, behind lower dash panel. To make things interesting, isn't your steering on the right ? (ours is left). Guess u have to check both sides? Let me know if this is any help, if not , I'll try again!
Nov 25, 2008 | 1999 Honda Civic
Compass
I dont have one and I beleive my car has all of the dealer upgrades avail.. Sorry
Aug 12, 2008 | 1994 Lexus LS 400
Seagate Expansion 1 TB USB 2.0 Portable External ST910004EXA101-RK Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
