Question about Bernina Activa 130
Owners manual I have inherited my mother's sewing machine but the manual is nowhere to be found. I don't know how to do any thing but sew a straight line and change the pressure foot with it. Anyone know where I can get instructions?
  • 84 Answers
SOURCE: long stitch!!
Hi teza...I assume that you have decreased your stitch length selector resulting in no change, indicating that the internal stitch length mechanism is either insufficiently lubricated, or truly broken If not broken, you can work the mechanism free by removing your needle, selecting the maximum stitch length and any non-overlock stich pattern, ie. straight or zigzag, fully depress your foot pedal so it runs at maximum speed, and methodically press and release the Reverse button/lever. After a minute of this, hand crank your machine while observing the feed dogs, and changing your stitch length. If your stich length is set to 0, your should observe your feed dogs moving vertically up and down with no back/forward motion, however, increasing as you lengthen your stitch length. Repeat the previous high speed work out until you notice full strokes of your feed dog...good luck my friend
Posted on Aug 02, 2007
  • 202 Answers
If your feeddogs look like they are working properly it could be this...I have seen and corrected a few problems like this in the past. What can happen is your needlebar is stuck in the Basting position. Basting is when even though the machine is turning properly the needlebar will only go down every few revolutions. There is a small pin in the needlebar that disengages when Basting stitch is selected (by an electro-magnet). Usually these will stick from hardly ever or not using it. Old oil gummed up usually but can happen in a drop. The pin will not go back in. Possibly (probably also) the needle bar got turned ever so slightly knocking the hole for the pin slightly off so it can't go back in. In which case the needlebar has to be turned to the correct alignment. This should only be fixed by a trained tech. Everyone... use the basting feature occasionally. We have a saying about those. "Use it or lose it".
Posted on Aug 27, 2007
  • 1388 Answers
SOURCE: Bernina Activa 130/131
Because you say all was working for a while before this latest event, it will be the supressor that has failed, they are generally in the foot control (some machines have them in the main body near the power inlet) and it needs to be removed, it only stops interference to Radio & TV and is not necessary for correct function...............your nose will tell you if it is in foot pedal or inside the machine..
Unplug from mains, undo cover/s and find the electronic looking item which is cracked, burnt & probably oozing brown goo and smelling like burned plastic only worse.... Simply remove this from the circuit, clean the region with some denatured spirit, methanol or similar, wait until completely dry and re-assemble....this should fix the problem of the machine "running on" by to whether you have done a good job of the initial electrical repair, only you will know that.
By the way, how's the dog ? Guess the machine was not plugged in at the time !!
Posted on Feb 10, 2008
  • 619 Answers
SOURCE: Bernina Activa 135 sewing machine
Hi , the pedal micro switch are stuck , you may visit fixya repair service just , (enter zip area), you can find sewing machine repairman near you
Posted on Feb 22, 2008
  • 202 Answers
SOURCE: Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
Posted on Dec 12, 2008
  • 202 Answers
SOURCE: Bernine 153 QE motor sometimes does not respond to foot pedal
If its not the footcontrol (which it probably is) it is most likely the circuitboard acting up. Needs a tech.
Posted on Feb 28, 2009
0 characters
1 Points
Does anyone have a manual for the New Home Janome sewing machine Model 577
Search the internet for:
Manufacturer + Model + the word "Manual"
Nov 10, 2015 | Janome Sewing Machines
Where would I find a free owners manual for a kenmore buttonhole attachment model # 213702016 ?
Who inherited the sewing machine and the rest of the things for it . perhaps your sister got what you need .
Sep 27, 2015 | Kenmore Sewing Machines
I'm trying to get my mother's Singer Touch & Sew Deluxe 645 to sew a straight stitch. I don't want to buy a manual since the machine rarely gets used and I have limited time to "fix"
Not much information to go on. What do you mean it won't sew a straight stitch. It just won't sew a straight line? It won't form a stitch? What?
Dec 12, 2012 | Singer Sewing Machines
I have inherited a Husqvarna 4500 from my mother. Everything was working beautifully until I ran out of cotton on the bobbin. I read the instructions and did as directed. When starting to straight sew...
This is not a solution but I am actually looking for the instructions/manual for a 4500 Husqvarna Viking sewing machine. Would appreciate any help. Thank you.
Jan 05, 2011 | Husqvarna Huskystar 207 Sewing Machine
Singer Samba 6 sewing machine
It would be wise to have the machine cleaned & serviced. Do you have a manual for it? Did it come with oil at one time? I found a free manual at
You have to register (free)...choose to skip the popups (2)...and you can save the manual to your hard drive.
I checked the don't need to oil the machine...but page 61-63 shows cleaning...and it's basic. You take the two screws from the throat plate, remove the bobbin case & brush the inside of the machine bed out...I use a small artists plastic bristle brush, or a small childs tooth brush.
Hope this helps.
May 14, 2010 | Singer 7442 Mechanical Sewing Machine
Denim pro #1750 don't have an owners manual
Try this site. You may be able to find a manual there and if not maybe if you contact them they can help with sewing a straight stitch. Hope this helps and good luck!
Aug 27, 2009 | Sewing Machines
I have inherited an old 'Brother' sewing machine with no manual
i have an old brother machine maybe back in the 60s-80s and the thread keeps coming out of the needle and i dont know how to do anything with the bobbin.i have no idea how to use the machine at all.i would love to learn any help.cant find any thing online to help.
Jul 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
69 people viewed this question
Top Bernina Sewing Machines Experts
Level 1 Expert
Bargain Box
Bargain Box
Jose Cada
Jose Cada
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
