Question about Pioneer DEH-P6900UB CD Player
Pioneer DEH-P6900UB Hello, I've just installed the DEH-P6900UB and I'm unable to get the motorized faceplate to open to install CD's. I've read the manual and all that's stated is to press OPEN to engage the faceplate. This is my second DEH-P6900UB unit that has done this. I returned the first thinking it was defective however, it seems I may be overlooking something. The installation is fine and nothing I see prevents the face plate from opening and being lowered. The faceplate itself can be removed but unit doesn't open to expose CD slot. Any suggestions would be greatly appreciated. Thank you.
  • GSpeed Aug 27, 2007
    Your reply is appreciated,thank you. I did make sure both red(ignition switch) & yellow(constant 12 V supply)wires are connected. When OPEN is pressed I can hear the faceplate working but doesent extend. I also checked to make sure the screws used to attach unit to factory brackets weren't to long as to interfere with anything. There is a RESET button, which I used only after trying the OPEN button first. The RESET button seems to just put settings back to factory. However, on page 8 in the Operation Manual it gives guide lines when the RESET button should be used (prior to using this unit for the first time after installation, if unit fails to operate properly). I've included links to the Operation Manual & Installation Manual for a better understanding of the unit and functions. Again, thank you for taking the time to assist me.
    -Installation Manual Link https://www.pioneerelectronics.com/pio/p...
    -Operation Manual Link https://www.pioneerelectronics.com/pio/p...
  • GSpeed Aug 31, 2007
    Will I uncoverd the problem. It was the factory brackets were to tightly screwed into the sides of the unit, which I guess compressed the motorized faceplate, causing it not to expand fully. Thanks again for your assistance.
    Scholar:
  • 98 Answers
Make sure that you have power not only to the red wire but also the yellow wire... one is battery power the othe ris ignition on power. If it only is getting one power it might not think the ignition key is on.. also maks sure there is not a reset button somewhere that you can press with a pen...
Posted on Aug 27, 2007
  • Mike Ryan
    Mike Ryan Sep 01, 2007
    ahh.. must me some import then.. i think they specify no longer screw than like 4 mm long...
    ampman
SOURCE:
Faceplate won't open all the way
Sometimes the mechanism is misplaced, just disassemble that mechanism and turn on radio without the secondary plate and wait until the motor to get to the final position when it turns off again, reassemble.
Oct 06, 2012 | Pioneer Premier DEH-P960MP CD Player
Where can i get a pioneer deh-p6900ub ribbon replacement
where can i get a replacement ribbon for my 6900.
Jan 07, 2011 | Pioneer DEH-P6900UB CD Player
Which wire is the remote wire for the pioneer deh-p6900ub head unit
if ;you are talking about the amp remote wire it is blue/white.
Nov 10, 2010 | Pioneer DEH-P6900UB CD Player
I am unable to reset my pioneer deh p4100. I see
remove the unit and disconnect the battery+red and yellow cables.check the front unit for derfomed plastics or stucked somehow microswitches!someone stucked from the heat!
Jun 05, 2010 | Pioneer DEH-P4100
DEH-P6600 and DEH-P6700
if you still have that deh-p6600 faceplate i'll buy it from you
Sep 25, 2008 | Pioneer DEH-P6600 CD Player
Detaching??
when it opens to eject the cd, i think you just pull it straight out. i didn't have this same model, but that's how mine worked.
Jun 17, 2008 | Pioneer DEH-P6900UB CD Player
No installation guide for deh-p6900ub radio
grey-right front +
grey/black-right front -
white-left front+
white/black-left front-
green-left +
green/black-left rear-
purple-right rear +
purple/black- right rear-
Mar 28, 2008 | Pioneer DEH-P6900UB CD Player
Pioneer DEH-P6900UB iPod Control
My suggestion is that the ipod-connector is bad. Try changing the ipod connector. If that doesn't work, unplug your Pioneer device for 24 hours, and then plug it back in. This will reset all the configuration options and should reset the devices that it recognizes. If that doesn't work, try calling Pioneer's support.
Nov 13, 2007 | Pioneer DEH-P6900UB CD Player
Pioneer DEH-P6900UB & Sandisk Sasa e280r
Did you format it while connected to a PC? If so check that you didn't format as NTFS, the Pioneer HU can only read FAT32 I think.
Sep 20, 2007 | Pioneer DEH-P6900UB CD Player
Pioneer DEH-P6900UB CD Player Logo
785 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
