Faa087s7a frigidaire air conditioner
Noise
22yooper
  • 828 Answers
SOURCE: Does the frigidaire model FAA087S7A
Should not be necessary as the casing is designed to drain condensate toward the back when it is installed level .
Posted on May 02, 2008
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
  • 11 Answers
SOURCE: Frigidaire FAH106N1 Thru-Wall/Window Air Conditioner
Check for blockage of the air pathway. Check that the fan turns freely, as the bearings or bushings could be shot. The fan blades could also be loose. You might just want to replace the fan, as it is cheaper than replacing bushing/bearings.
Posted on Jul 08, 2008
SOURCE: Electronic control on Frigidaire air conditioner not working
which one take live or nuetral ?
common
start
run
thanks
Posted on Jul 11, 2009
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: frigidaire in wall air conditioner making noise fan/ motor?
    Is it a clicking or banging sound? The fan is most likely not kicking up the moisture to cool the evap coil off enough in the unit so you might here more noise for a little while. Monitor it and let me know if anything changes.
    Posted on Sep 07, 2012
    Frigidaire airconditioner ModelFRA18EMU2 made a popping noise now will not come on
    probably a wire connection burned loose. it will make a popping sound.
    Jul 13, 2015 | Frigidaire Energy Star Room Air...
    You need to ohm out the unit starting with the power cord.
    Feb 01, 2014 | Heating & Cooling
    Frigidaire Air Conditioners make alot of noise when running
    Hi James - Thank you for your question! I am happy to assist you. I understand you stated it sounds like a bad bearing, however may you please describe or me more specific in the particular noise the air conditioner is making? Does the noise occurred at all times? With this information I can better address the issue at hand and provide you the most accurate information. Thank you and I look forward to your response.
    Jul 18, 2013 | Frigidaire Heating & Cooling
    Frigidaire in wall air conditioner making noise fan/ motor?
    Sep 05, 2012 | Frigidaire FAH106N1 Wall/Window Air...
    Constant noise when compressor running
    most likely there is something touching the body so try to lift the back side and if noise goes away put a block of wood under the unit
    May 19, 2009 | Frigidaire FAH126N2T Thru-Wall/Window Air...
    Noise
    Adding cloth or any other sound absorbing material will not work. There is not enough room to add anything appreciable in the fan area.
    Jul 22, 2008 | Frigidaire FAC107P1A Wall/Window Air...
    Jul 07, 2008 | Frigidaire FAH106N1 Wall/Window Air...
    Year old Frigidair Air Cond. making loud clunking noise. Model #FAA067P7A.
    I think I get a "bug" or "animal" in my unit every once in a while, that gets caught in the fan and thrown around for a few minutes. It makes a clunking noise, as you say. Maybe???
    Jun 05, 2008 | Frigidaire Heating & Cooling
    Does the frigidaire model FAA087S7A need to tilt backwards in the window?
    May 02, 2008 | Heating & Cooling
    Heating & Cooling Logo
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
