Question about HP Photosmart R727 Digital Camera
Shutter won't open/close, and blank screen on "capture."
My camera's shutter lens won't open or close automatically when I turn on/off the camera. Also, on the "Capture" menu, the screen is just black, although the zoom lets me know on screen when it is going digital.
  • 1 more comment
  • MadiB6 Aug 27, 2007
    I'll try that. Thanks!
    I tried cleaning it out with a small paintbrush inside the lens area. It's sometimes opening and closing now, but the camera is still turning itself on and off at whim. And the screen is still black. Any ideas?
  • MadiB6 Aug 29, 2007
    So the shutter problem is fixed, but the camera is still shutting off and on at will, and the capture/review screens are still black.
  • 59 Answers
It prolly took a bump at some point or has crud inside...try cleaning it GENTLY with alcohol NOT WATER.
Posted on Aug 27, 2007
SOURCE:
The screen unexpectedly went blank and black....apart from camera info symbols..all pictures taken now are black..... pictures taken before can be seen on screen,....lens moves in and out ok
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 04, 2011 | Nikon COOLPIX S220 Digital Camera
My powershot A540 shows a black screen and takes blank photos. Something between the viewer/card and the lens is closed and only opens occasionally, no matter how much I fiddle with the settings.
Jul 04, 2011 | Canon PowerShot A540 Digital Camera
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
Shutter appears to be stuck closed.
Theirs oil on the shutter blades causing it to stay closed, Thats why you can't see though the lens or the viewfinder also, This comes from the grease from the zoom assy, It's a major job to fix it, Has to be fixed by a repair shop
Jun 04, 2010 | Canon PowerShot S3 IS Digital Camera
My lcd screen will not show the picture. The
First try pressing the DISP or DISPLAY button to make sure that you didn't accidentally turn off the LCD. But if that's not the case...
Try taking and downloading a picture taken while the screen is blank. Is the picture also blank? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Read the users comments there also for more tips.
Jan 31, 2010 | Canon PowerShot SD1000 Digital Camera
When I turn on my camera the screen is blank
Do the icons show up on the screen or is it totally blank?
Can you view previous pictures?
If the icons show on the screen then have a look into the lens to see if the shutter is closed over the inner lens. you may have to adjust the zoom to bring the inner lens and shutter mechanism up close to the outer lens to get a better look.
If the shutter is covering the inner lens then it is stuck and will need to be freed by opening the camera up.
If the screen is just black then it just may be possible that the ribbon for the screen has partially slipped out of it's socket on the main board.
If it comes out all the way then the camera should not even power up.
Jul 27, 2009 | Fuji FinePix A800 Digital Camera
LCD screen is blank and pictures are also blank
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 24, 2009 | Canon PowerShot A620 Digital Camera
My cannon s21s has a blank screen
You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 20, 2009 | Canon Cameras
My screen is black or blank
I think you mean your automatic lens cover opens. A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Feb 23, 2009 | Nikon COOLPIX L18 Digital Camera
HP Photosmart R727 Digital Camera Logo
101 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
