Remove Impeller. on a Davey 81814-0 model - Computers & Internet
How to remove impeller from davey pump 5255H
impeller thread is left hand
remove the fan cover at the end of the motor to hold the shaft and undo the impeller in a clockwise direction
Dec 30, 2016 | Pool & Spa
Can anyone give me a # that works for Utilitech? I need a Impeller and diffuser kit and Lowes where we bought it from isn't any help, the number I have for Utilitech is busy...Thanks!
pump impeller and diffusers are available from any pump repair shop
find the brand name of the motor /pump ( onga, davey or the like ) and find a pump shop that handles that brand and they will have what you want
Jun 07, 2016 | Pool & Spa
I need remove broken impeller from davey pool pump sls-150
Use chisel to break off plastic portion, then wrench to remove remaining threaded insert.
Feb 12, 2015 | Pool & Spa
I have a Davey pool pump and there sounds like a stone is in the impeller how do I open it and clean it out
The easiest way to check would be to put your fingers or a thin but long object through the hole at the bottom of the pump basket which leads to the impeller. Make sure the impeller turns. If the impeller turns there is nothing stuck in it. More than likely the bearings have gone bad which is common. Any small motor repair facility should be able to fix this or your local pool man.
Swim Time
Jan 26, 2015 | Pool & Spa
How to install a mechanical seal ?
I would suggest you try and find a schematic of the and go from there.
Here's a search for that pump
https://search.yahoo.com/search?ei=utf-8&fr=ytff1-&p=davey%20fire%20single%20impeller%20pumpfighter&type=
My experience with seals on those types of pumps(never done davies) is to remove the outboard housing--- then remove the impeller----take the nut off---then get a piece of brass or very hard plastic (buffer)-- put this on the end of the shaft---then hit it with a hammer---you will need help with this as someone to pull on the impeller while you strike the buffer---after that done, then remove the inside housing---find a socket or piece of pipe/tubing that the size of the seal and drive it out----depending on mfg the seal's removal usually it's is driven from the impeller side out of the inboard housing (some are opposite)---it's nice to have a press but not everybody has one in their cellar----make sure you clean and buff the shaft before reversing procedure careful not to hit cut or score new seal when installing it-- that's about the best I can do for you---it's like trying to cut hair over a telephone
Aug 11, 2014 | Plumbing
Remove Davey Impeller
It all depends on which one. there are units from tiny up to fire fighter units. They all come apart differently. search Davy Impellers and a model number....
May 25, 2014 | Pool & Spa
Davey Pump won't start
Some of those have a safety switch if low on oil they want start.
Jan 16, 2014 | Davey Crickett High-Pressure Twin Impeller...
Davey XP500H pump parts diagrams
hi looking for davey xp 500h pump impeller diagram to clean and replace impellers
Mar 31, 2012 | Cars & Trucks
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
