Question about Euro-Pro Ninja MEGA Kitchen System 1500
The large container leaks from the bottom and the mechanism seems very loose.
I made some ice coffee this morning and when I pulled off the unit, there was a ton of liquid in the actual machine base from the container. It doesn't seem like I can tighten it, can you?
The freezer has an obvious leak. When we wait a few days, we can see that water leaked into the freezer and it turned into a large brick of ice? What does that mean?
Hi Monica,
This seems to be a problem with overflow of water into the ice maker, or a leak in the feeder to the ice maker. My suggestion is to turn off the ice maker by raising the lever on the unit, and see if the ice re-accumulates. This would mean that the water is leaking from the inlet, and the ice maker has no obvious fault. If you find this, you can remove the ice maker from the freezer by removing the screws holding it to the inside, unplug the unit from the back of the freezer, and pull straight out. Look at the inlet of the water at the rear of the freezer and see if there is a break in the line or a crack somewhere along it. You can replace it from the back of the refrigerator itself, going from the bottom where the water is hooked up to the top by removing the panel that guards it.
I hope this isn't too confusing.
Joe
Sep 13, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
WATER LEAKS BOTTOM OF UNIT WHEN IS MAKING COFFEE ALSO, HOW DO YOU DECALCIFY UNIT? iS THERE AN ON LINE MANUAL?
Below are solutions for a leaking coffee maker and how to decalcify the machine?
Tools and Materials needed to fix this problem are as:
* White Vinegar * Fresh Water * Volt-ohm Meter * Screwdriver
Step 1 - Clean
If your coffee maker seems to be clogged, try cleaning it with a mixture of white vinegar and water. Assuming that your coffee maker has a 12 cup capacity you will want to use 11 cups of vinegar and 1 cup of water. Fill the coffee pot to the 11 cup mark with vinegar and then fill it to the 12 cup mark with water.
Pour this mixture into the reservoir and turn on the coffee maker, allowing it to run through a brewing cycle as if you were making a pot of coffee. By doing this you will dissolve any build up in your coffee maker. If the coffee maker is leaking because the pump is clogged, then this might clear the clog and stop the leaking. If it has been a while since you last cleaned your coffee maker, you may need to run the vinegar through more than one cleaning cycle to dissolve all of the buildup.
Step 2 - Pump Valve
Unplug the coffee maker and examine the pump valve. If the pump valve is broken or has a clog, then the water will not be able to rise up and flow through the fill tube. When the coffee maker is turned on, the water needs to go someplace. If it cannot flow through the fill tube, then it may leak onto the countertop. If the pump in your coffee maker is sealed, you will need to replace the whole pump. If the pump is not sealed you should check it to ensure it is not clogged with coffee grounds or mineral deposits.
Step 3 - Brew Switch
Examine the brewing switch to ensure that is working. To get to the brewing switch, remove the base plate. Next, you will need to test the switch with your volt-ohm meter. Touch the tester to the RX1 scale. If it reads 0 ohms then you will know that the switch works fine. If it gives you a number other than 0 then it is time to replace the switch.
Step 4 - Tube Connectors
If the coffee maker is leaking or sputtering then you should take a look at the tube connectors. Many times, a leaky coffee maker is caused by faulty tube connectors. If you find the leak is in an elbow, clean the surfaces before you replace it. If the tube connector leaks, replace both the tube and the elbow so that you can be sure the pieces will both fit together properly.
To decalcify, you will be needing a : decalcifying cleaner and A container large enough to hold the same quantity of liquid as your water reservoir
1) Remove the machine's water reservoir. 2) Empty all liquid from the reservoir. 3) Fill the reservoir with warm water. 4) Add one packet of the recommended cleaner to the full reservoir and stir until the cleaner is dissolved. 5) Return the water reservoir to the machine. 6) Turn the machine on. 7) Set the large container underneath the steam wand. 8) Set up your machine so that hot water -NOT steam-will be emitted from the steam wand when the steam valve is opened. 9) Open the steam valve according to the manufacturer's instructions. 10) After all of the decalcifying solution has drained into the large container (within a few minutes this will occur), remove it and discard the liquid that has been collected. 11) Rinse the water reservoir thoroughly and then fill it with the type of water you usually use for brewing. 12) Return the water reservoir to its normal position. 13) Using only water repeat steps 7 through 9 until the water reservoir is empty again.
I hope the above helps....
Good luck.
Jun 22, 2011 | Jura Capresso Impressa S8 Coffee Maker,...
Hi, I have an XP7240 and recently i only half a cup of coffee. the rest of the water is coming from the underside of the machine(not the drip tray) where ther appears to be an overflow hole. This morning...
I can remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. Take photos and remove the components from top till bottom to get to the bad parts that need replacement. It's a lot of work but if you're handy you can get to the valve on the bottom of the machine. I have the same problem but haven't looked up the replacement part (can be expensive). Good luck!
Jul 30, 2010 | Krups XP7230 Compact Super Automatic...
Leaking water
Check for two loose screws holding the backplane that holds the infuser unit. With the machine OFF, open the door and press the two red buttons to pop out the infuser. You will then see two 3 mm hex head screws attaching the backplane. Check that they haven\'t come loose; if so, you\'ll need a hex socket to tighten them. Then re-insert your thoroughly cleaned infuser and see if that has stopped your water leak.
May 28, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
I have a Kitchenaid dishwasher model KUDS01FLSS2. I finished replacing the door balancer cord and started the dw up and it started leaking underneath from the bottom somewhere around the middle of the...
In this Kitchenaid dishwasher model KUDS01FLSS2, the whole motor and water pump assembly simply sits (I think loose) in the bottom of the DW. From the inside, it is the round mechanism where the sprayer is mounted above the chopper, all one piece sitting in (or mounted with) a large rubber washer around it. Somehow this assembly had lifted up slightly on one side which allowed the water to just poor through the bottom floor of the DW. I simply pressed down on the whole mechanism positioning back in its proper place. It did not take much pressure at all to position it back into its place. This stopped the leak and is working like a charm.
Nov 13, 2009 | KitchenAid Dishwashers
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer seems as if it is not cold enough
Your sensor is packed in ice and giving false reading (always frozen)
You NEED to defrost. Will take 2hr
Turn off or Pull plug on freezer
Take everything out and put in cooler, brown bags, large bin or boxes to stay cold
Defrost by setting large pail of boiling water in each side bottom of freezer and closing door(s) for 1/2hr
Open freezer, empty pails in sink and use pails to hold large chunks of ice from freezer that will come out easily
Toss out ice chunks
Check sensor to be sure it is no longer packed in ice
Wipe down interior dry
close doors
plug in
wait 1/2hr
reload with stuff you want to keep
Done!
Mar 26, 2009 | Refrigerators
GE profile refrigerator model # TBX25PR
See if ice is jammed up in the tunnel the ice is pushed through.
Will the motor turn the auger with all the ice removed.
Jan 25, 2008 | Refrigerators
Water is leaking from bottom of base.
I just had good luck pulling the grinder bottom piece forward while pulling directly up on the blade mechanism. Hope this helps.
Dec 25, 2007 | Cuisinart DGB-600 Coffee Maker
Grinder bottom piece cannot be removed
If you open the door in the front and remove the straining basket you will see an open space where the very bottom the grind cup sits. Take a long thin standard head screwdriver and insert it there until you feel the post of the grinding engine against the screwdriver. Turn the screwdriver like you are turning a screw. The grind unit should start to move up. You can try to use the screwdriver to pry upward to finish the job. Another post said that redrilling the brass post insert on the grind cup worked for him. The problem seems to be the grind motor post that has swollen or been misshapen through the use of the machine. If they were to ask me, there is a better design for this contraption, just look at any blender. Flat disks with downward (or upward) facing fingers on the removable container and the motor.
Sep 16, 2007 | Cuisinart DGB-600 Coffee Maker
Euro-Pro Ninja MEGA Kitchen System 1500 Logo
71 people viewed this question
Top Euro-Pro Wine & Spirits Experts
Don Hart
Dave braun
Dave braun
Don A
Don A
Are you an Euro-Pro Wine and Spirit Expert? Answer questions, earn points and help others
