Question about Creative Labs I-Trigue 2.1 3300 Computer Speakers
Speakers making buzzing sound - Creative Labs I-Trigue 2.1 3300 Computer Speakers
I checked my speakers there not blown out still making buzzing sound. Why?
the buzzing sound is an symptom or indication that there is a defect on the output audio system from your unit. A good audio system does not give out a buzzing sound.
Check for shorted audio wire coming from your audio unit going to the speakers
Feb 23, 2016 | Audio Players & Recorders
I got a subwoofer jbl 145 wiht my system after one hour of use it make a noisy sound very loo buzzing sound and i have to power it off to stop it!
A very low buzzing sound usually indicates that the speaker is on its way out. Its the small period of time when the speaker is making sound or not.
May 27, 2011 | Harman Kardon Audio Players & Recorders
I just bought logitech 5.1 surround sound speakers, but its making a buzzing noise how do i fix that please. could it be that my sound card is not good enough?
if you buy a 5.1 speaker you also need 5.1 sound card that supports the speakers. although it will still work with ordinary sound card but you can't actually use the feature of the speakers. the buzzing sound can cause by loose connections of the audio cable or audio connector. you can also hear a buzzing sound if you connect it at the wrong port. just remember the color codes
green - audio out (for speakers) red - microphone blue - line in or audio in black - digital audio
Apr 22, 2011 | Logitech X-530 5.1 Speakers
My logitech x-210 speakers make a buzzing sound
Sounds like the speakers are not plugged in to the computer, or are plugged in to the wrong socket.
The speaker socket on a PC is usually green, a 3.5mm stereo socket.
Apr 23, 2010 | Logitech X-540 Computer Speakers
Computer speakers
Try updating your drivers for your sound card.
Mar 13, 2008 | Logitech X-230 Computer Speakers
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
Speakers have no sound
the buzzing sound is normal for half way, however it does tell you the speakers work, First thing is to make sure the mute is not on.next make sure you have it plug into the out put just and not the mic or input.
Dec 02, 2007 | Logitech X-530 Computer Speakers
Rear Speaker problems
The delay is normal as it's designed to create a spacious large room sound. The buzz however, is not. It sounds like the power supply is bleeding into the amp and should be serviced.
Jun 01, 2007 | Aiwa NSX-DS55 CD Shelf System
Creative Labs I-Trigue 2.1 3300 Computer Speakers Logo
20 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
