Question about Vehicle Parts & Accessories
How to put the hed lights back into the grill on a 1962 ford f100 pickup
The mounts seem to be loose the hedlight moves even tho i screw the two screws into place am I missing something
  • Vehicle Part... Master
  • 5,480 Answers
That metal ring around the bulb is the retainer which secured the headlight, so it wouldn't move. If it's still loose, there must be some missing parts on the assembly. 1962 was a long time ago-the year I graduated high school.
Posted on Jul 11, 2013
Car goes backwards even tho its in drive
try moving the gear selector to d1 or d2 it may just be 1 or 2, if this puts the vehicle into drive then your shift linkage of shift cable may need adjustment it could also be loose bolt on the shift shaft under the dash. use a flash light and look under the dash to find the shift cable, its a thick black cable that runs up to the back of the steering column the cable is then clipped on to the column and the cable comes out to a eyelet and is popped onto the shift shaft the bracket on on the shift shaft is held in be two bolts if these bolts come loose they can cause shift linkage problems. if they seem loose you can repair it just by removing each bolt , one at a time and putting lock tight on them then tighten them, be careful not to over tighten though. hope this helps!!
above is a picture of a shift cable so you know what you are looking for. sorry I could not find a picture of where it connects to or of it installed. good luck!
May 29, 2012 | 2001 Ford Expedition
Replacing headlight on 1989 Toyota
if the turn signal cover is loose, and you are not really sure and dont want to break yours, visit your local junk yard and try the exact same thing there. But you could always try a rag and a flat head screwdriver, use the rag to cover the screwdriver and gently pry the turn signal lens out from the back of the housing. Usually the rubber grommets have just gotten old with age and weather. have you tried removing your headlight? although rare, somethimes the headlights need to come out first with certain models.
Oct 29, 2011 | 1989 Toyota Pickup SR5
Nothing fits as it should, I would like to find a step by step install vidio for a part number 71405 shadow billet grill by putco. thanks mb
Congratulations on your purchase of a high quality PUTCO product. Should you need any application or technical assistance feel free to call us at: 1-800-247-3974 Monday-Friday 8:00 a.m.- 5:00 p.m. (Central Standard Time) Contact your PUTCO dealer for other quality accessories. PUTCO Inc. - 216 West First Street - Story City, Iowa 50248 PLEASE READ ALL INSTRUCTIONS BEFORE INSTALLATION AND TO CHECK TO SEE THAT ALL PARTS ARE INCLUDED. Please consult your Vehicles owners manual for vehicle air flow restrictions Putco is not liable for any vehicle damage resulting from the installation of our Grille inserts (71101) 99-02 CHEVROLET SILVERADO / 00-06 TAHOE/SUBURBAN, (71107) 01-02 CHEVROLET HEAVY DUTY, (71102) 99-02 GMC SIERRA/YUKON, (71102) 01-02 GMC HEAVY DUTY, (71104) 99-03 FORD F-150 (71137) 03-06 CHEVROLET HEAVY/LIGHT DUTY, (71138) 03-06 GMC HEAVY/LIGHT DUTY, (71189) 07-UP CHEVROLET LIGHT DUTY, (71163) 07-UP CHEVROLET HEAVY DUTY, (71158) 07-UP TAHOE/SUBURBAN/AVALANCHE, (71190) 07-UP GMC SIERRA LIGHT DUTY, (71164) 07-UP GMC SIERRA HEAVY DUTY, (71159) 07-UP GMC YUKON/YUKON XL. Step 1: Remove the factory plastic hood that covers the area between the grille and radiator by removing the plastic plugs or screws that fasten it in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 3: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 4: Reach between the grille and radiator and reinstall the bolts, plates and nuts onto the grille insert. Step 5: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71105) 99-07 FORD SUPER DUTY PICKUP AND 00-05 FORD EXCURSION, (74105) HORIZONTAL SIDE VENTS Step 1: Remove the four factory screws that hole the top of the factory grille in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 4: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. If you have purchased the side vent pieces install them at this time. NOTE: The installation bolt will go though a hole in the side vent that is closest to the center grille section. Step 5: Carefully pull the grille forward and reach between the grille and radiator, install the bolts and mounting brackets onto the grille insert and/or the flat washer and nut on the side vent pieces. Step 6: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71103) 94-01 DODGE RAM, (71132) 02-05 DODGE RAM, (71156) 06-08 DODGE RAM, 04-UP FORD F150 AND 08- UP FORD SUPER DUTY Step 1: Remove the bolts and mounting plates from the bag kit. Step 2: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 3: Reinstall the plates and nuts onto the grille insert. (Verify that the bolts do not come into contact with the radiator) Step 4: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. Note: Please adjust horizontal blades if irregular. This is the result of shipping and handling outside of Putco's contro
This is the installation instruction sheet for your grill.
Apr 16, 2011 | Ford F-250 Cars & Trucks
1971 ford f100 pickup neutral safety switch wiring color code
Ford Neutral Safety Switch; Ford Reverse Light Switch; Backup Light Switch.
The Neutral Safety Switch wires in my 1971 Ford F100 are orange with a blue stripe.
The Reverse, or Backup Light Switch wires are black with a red stripe.
There are two sets of two wires across this combined neutral safety and backup light switch, for a total of 4 wires. Photos are at the end of this post.
The switch for the 1971 Ford F100 pickup truck is the same as in many other years and models. For details, including parts numbers, see the following quote from an expert at Ford Truck Enthusiasts:
http://www.ford-trucks.com/forums/287185-back-up-light-and-neutral-safety-switch-2.html#post5601846
The neutral switch also controls the backup lights, and is the same 1967/77.
C7TZ-7A247-A .. Neutral/Backup Switch (Motorcraft SW-600)
There is no separate backup light switch..except on 1967/68 F350's.
Neutral switch location 1967/77:
The plastic half moon shaped neutral safety switch mounts on the outside lower portion of the steering column (NOT on the transmission!).
It's activated by an inverted Y shaped lever that snaps on the shift tube
D0TZ-7B097-B .. Lever, Neutral Switch Actuator = From FTE sponsor DIRECT FORD PARTS: Ford suggested retail price: $18.72 / FTE member net: $13.23.
The switch is also still available from Ford, but the website is down so I can't post the list & net prices. .
1978 is the FIRST year the F100/350's have the neutral switch mounted on the transmission. __________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
IMAGES
Driver side of the neutral / reverse switch showing the travel slot for the switch arm, the return tensioning spring, and the arm.
The front, steering wheel side of the neutral / reverse switch after removal from the steering column. The switch's two functions are actuated when the lever in the column moves the switch lever shown here to different positions as gears are selected.
The neutral switch is installed on the steering column near the firewall, with 5/8" bolts into the steering column (visible hole) and down column from a rectangular opening in the column housing. The actuating lever for the switch is attached to the gear shift shaft inside the housing; the lever is visibly protruding from the opening in this image.
Back of neutral / reverse switch, showing the wiring attachments. Black with red stripe is the backup light wiring, Orange with blue stripe is the neutral safety switch, it prevents starting in gears other than neutral & park.
Aug 03, 2010 | Ford F-100 Cars & Trucks
Need to change the headlights on a 1995 pick up....no clue even how to begin
You need to remove the chromed plastic grille piece to get at the screws that hold the headlamps in place. Open the hood, and there are four (I think) screws holding the top tabs of the grille in place. Just above the bumper, along the bottom of the grill, are a couple more screws. Once this grill piece is removed, you will see the screws holding the headlamp frames in place. (Make sure you don't move the adjustment screws. There is one at the top and one at the side set in a recess -- these aim the lights.) With the screws removed, the frame will come off and the headlamp can be removed and the electrical connector disconnected. Reverse everything to reinstall.
Feb 05, 2010 | 1995 Nissan Pickup
1995 Chevy G20 stalls.
Not sure if this will help. I have seen this happen!!! remove the cover under the steering column and locate the ignition switch. Get a flash light. You really need a flash light to see this. Set the E-Brake real good. While watching the ignition switch. (actual SWITCH not where the Key goes) . Turn the key back and forth with out starting and see if the switch is loose. (it has 2 hex head screws in it ) and is like 4 inches long with a bunch of wires in it and mounted the passenger side of the column under dash. If you cant see it move then try removing it from park and see if it moves. The switch is mounted on slotted holes. and if it is loose it will only move with the legnth of the column or front to back of vehicle. any ways if it is loose there is a way to put it back right ... as fallows:
key needs to be in the off position. loosen screws 1/2 turn each,
use your finger to push the switch up towards the key but not force it. like pushing a key on a key board. Tighten both screws and check it out. This seems like a long process to go through but it costs nothing but time.
Mar 02, 2009 | 1995 Chevrolet G20
How to get back off the Compaq Presario sr5000?
Its not the back that you will get open it is the side pannel that slides backwards
Let me know... Matt
Jan 25, 2009 | Compaq Presario 5000 PC Desktop
Ford Windstar 1998
Need to check your trans fluid first. do this with van running and engine warm.
Aug 28, 2008 | 1998 Ford Windstar
Vehicle Parts & Accessories Logo
70 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
