Air condition compressor is on the engine just below the alternator, depending on model camry you asking about. You need to get workshop manuel for your model. Depending on what exactly are you looking for, there are various parts to the air condition system that are under the hood, as well as inside the vehicle.
Some are vacuum controlled ( most are ) and some electronically. Could be a vacuum hose connection, or faulty in dash control unit. try going to a in between setting and see if anything happens( though i doubt it ). A lot of models do not always put air condition air to the floor, mid area is common.Unless you use to get air to the floor, check owners manual for control settings...
The manual can be found at http://www.aerusvacuums.com/support/manuals/index.cfm. You can go to either "Current Modesl" or "Older Models" and select the Lux Floor Pro. These are basically the same machines as yours.
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
