Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Does boost cycle create more clorine or just run the generator longer. I have a intex cs8110
4 Suggested Answers
  • 22 Answers
SOURCE: my intex clorinator display quit any solutions
check with intex they will normally replace it if it wasnt your fault.
Posted on Jun 17, 2010
  • 297 Answers
SOURCE: I need the owners manual for model cs8110 intex
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Posted on Jul 29, 2010
moe_2782
  • 443 Answers
SOURCE: model cs8110 I have a 24' x 52" aboveground pool not a Intex will the 8110 provide enough clorine for this size pool
first you need to fined out how much the water volume is and then add the right amount per ltr
Posted on Jun 12, 2014
Have intex cs8110 salt generator. Can't program it. 00 will not stop flashing. There are no up/down arrows on this unit.
Take the battery out (or unplug), wait 10 minutes, and reboot it. Read the instructions and reprogram it from the beginning.
May 29, 2015 | Intex Pool & Spa
How do i set up boost cycle on modelcs8110?
This is pretty easy but first you need to realize that when you boost, the system will run 8x longer than what you have it programmed for daily... So, if you normally run it for 4 hrs per day, the boost cycle will run for 32 hrs... That's important because the filter/pump needs to be running that long plus an hour...
To begin a boost cycle, simply hold down the boost button until the BOOST Green light comes on...
Hope this helps...
Jul 01, 2014 | Intex Automatic Salt Water System for ...
Free Chlorine won't register in pool?? I have done everything the manual suggests and cannot get a reading on chlorine from my pool. If you check the water coming directly out of the generator it...
if getting reading from unit and losing by the time it gets to pool water chlorine is locked need to add non chlorine shock to oxidize and super shock pool
Sep 02, 2017 | Intex Automatic Salt Water System for ...
I have a salt water clorinator system can I use softwater salt instead of pool salt when I set up my pool
no you must use a 99% pool salt
The electro cells in a salt generator can not turn anything else into sanitizer ( chlorine )
Jun 21, 2010 | Intex Automatic Salt Water System for ...
Problem with system
There is no code 77 Call intex and give them your information. They will have a new unit shipped to you in days
They are really good with warranties as long as you have a valid receipt
Jun 17, 2010 | Intex Automatic Salt Water System for ...
Code 91
If you have hard water in your location you may want to try cleaning the electrolytic plate. I had the same issue where no matter how much salt was added I had code 91. I shut the water down going through the filter / generator. Pulled the outlet hose off and put on a cap. Pulled copper cell out and filled chamber with vinegar. Put cell back in and let set for 1 hour. Fluhed it out and hooked everything back up. Nop more salt problems. The process is in the book.
Jun 07, 2010 | Intex Automatic Salt Water System for ...
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Jun 01, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
11 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
