Question about Phonak ComPilot
What does yellow light mean - Phonak ComPilot
Hi my name is Mike I have a 2002 x5 and in the dash board there was 4 little green lights on on bottom right now I got one red one and one yellow one what does it mean thx lots
Hi Mike. The lights are the service maintenance lights. When an oil service or inspection service is performed the lights should be reset to all green. Over time the lights will go from all green lights and disappear until a yellow light comes on. The yellow means the next service is due. The red means over due.
Feb 10, 2017 | 2002 BMW X5
2011 terios . Yellow spanner light comes on. What does that mean
The yellow spanner light indicates a service is due
Jul 09, 2015 | 2010 Daihatsu Terios 1.5
My neutron R32 blinks continious yellow when switched on
blinking yellow light usally means the motors are not engaged so find the levers to reengage motors
Dec 04, 2013 | Invacare Health & Beauty
What is the yellow flashing light
In the cross-sections, when there is a yellow flashing light "a driver may proceed through the intersection or past the signal only with caution."
Mar 21, 2013 | iBuyPower Gamer Computers & Internet
I can't figure out what the yellow light means
Diane, what exact model of Samsung printer do you have and where are you seeing the Yellow light and under what circumstances?Does the printer work correctly or do you have problems with it?
Dec 26, 2011 | Samsung ML Office Equipment & Supplies
Satellite pro L300 screen is blank. Power light is on (green), battery light is yellow, HDD light is off.
Sounds like it's broke. Blank screen means it's broken, battery light is yellow I beleive it means time to replace the batteries.
Apr 16, 2011 | Toshiba Satellite Pro L300 Notebook
The light is on yellowe
Hello Qutey Babe, Hi.... the yellow light means there is no signal from the CPU. check your CPU.
Blue means normal, there is signal coming from CPU Yellow (orange usually). means no activity on the CPU,
Dec 06, 2010 | Acer AL1916W 19" LCD Monitor
Yellow light keeps blinkingand the tv wont turn on
If the status light is blinking yellow it means the filter cover is open ( On the left side of televison)
If the lamp light is blinking yellow it means the lamp cover door is open. ( Behind front lower panel) If both covers appear intact the switches may be defective or not engaging properly.
Dec 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
What does the yellow light mean?
when the light changes to yellow it is just adjusting to the newly added water. If you let it run the light should turn back to green. I think the light is only indicative of water level. I've had this humidifier for over a year and only gotten a yellow light once. It turned green after some of the water in the basin drained. Hope this helps
Dec 13, 2008 | Crane Cow Humidifier
MAINTENANCE LIGHT ON MY 1997 ACURA 2.2 CL IS YELLOW
Time for service, look in your owners manual for the mileage.  At the very least you are due for an oil change.
Yellow means you need it soon
Red means you ignored the yellow and need it now
If you don't rely on your car to get you places, you can ignore these and do some expensive repairs later.  If it's time for a timing belt and you ignore that,  it might cost $2000-3000 when it breaks.
Oct 29, 2008 | 1997 Acura CL
Phonak ComPilot Logo
134 people viewed this question
Top Phonak Cell Phones Experts
Vladimir Frolov
Brett Duxbury
Brett Duxbury
 Mikey
Mikey
Are you a Phonak Cell Phone Expert? Answer questions, earn points and help others
