Question about Daewoo DVDS151 DVD Player
Daewoo DVD-5700 Tray will not open, any suggestions?
I've had the same problem with mine. The dvd slips out of the tray causing it to stick shut. Take the player apart using a small philips screwdriver (about a million tiny screws)Pull the dvd out, put player back together and your set.
Posted on Aug 29, 2007
2 Suggested Answers
SOURCE:
  • 130 Answers
SOURCE: Disc Tray: Daewoo DVDS151 DVD Player
Some have a little hole in the front, you pull the power and use a paper clip. Bend it out so its fairly straight then you poke it into the hole and it unloads the mechanisim. If there is no hole you may have to remove the cover.
Posted on Apr 21, 2006
Manually open dvd tray
Look next to the DVD tray to find a small hole. Once you have found that hole use a small paper clip and straighten one part of the clip. Carefully insert that extended paperclip into the hole, if you meet resistance apply gradual pressure until the tray opens...if the tray does not open...Remove the paperclip end (straighten the paperclip again and reinsert the straight end of the paperclip straight into the hole. Once you meet resistance press gently again, if you feel the paperclip continue into the hole without bending, continue pushing until the try opens. This is the correct way to open a CD/DVD/Blu-ray tray with or without the power on.
If you need further assistance, please ask...
I’m happy to help further over the phone at https://www.6ya.com/expert/steven_142d2a6ad692ab09
Oct 22, 2012 | Daewoo P480 DVD Player
DAEWOO DH-6100P wont play original dvd's (from any region)
press open/pay insert disck, and close the tray.
put your password, if do not recognize your p. put oooo default password, and ready.
God bless you
Jul 14, 2012 | Daewoo DVR-06
Toshiba DVD player doesn't retract or load media. DVD carrier is stuck in the out position
There is a rubber band on the motor that opens the tray out to load the disc, somehow that must of slip off the motor. Or the motor itself went bad.
Oct 11, 2009 | Toshiba SD-5700 DVD Player
Daewoo S04 DVD won't open
The tray is blocked. Unplug and open the player's casing and check for any obstructions and remove it. It might be a disc or something. Check also the gear as you can hear the motor running but the tray don't open.moz-screenshot.png
Aug 23, 2009 | Daewoo DVRS04 DVD Recorder/VCR
Daewood DVD-5700 DVD Player ~ Won't play any DVDs
Hi.
There could be several reasons for this problem.
Since the unit has not been used much the lazer
shouldnt be burned out...but it can mean that it collected dust by not being used.
How is the condition of the disc you tried to play?
Are there children in the family...they love to put things in the tray and load it in. =)
A cleaning kit might help if there is dust on the lazer lens.
Regards...
/Tech5508
Feb 14, 2009 | Daewoo DVD-5700 DVD Player
CHANGE ZONE 0
1. Open DVD tray.
2. Entre 0520 using remote.
3. Press keys in this order: UP, DOWN, LEFT, RIGHT.
4. Enter region code, 0 for complete code free.
5. Close DVD tray.
May 26, 2008 | Daewoo DV-6T955B DVD Player/VCR
Daewoo DDT-21H9 S TV/DVD tray will no longer open.
This could be a simple belt problem . Or if it is motor driven then you would have to check if there is voltage to the motor or the motor is bad . This would require removing the dvd deck to get to the belt . Good luck
Mar 11, 2008 | Televison & Video
Apr 21, 2006 | Daewoo DVDS151 DVD Player
Daewoo DVDS151 DVD Player Logo
105 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
