Question about Friedrich SL22N30 Kuhl Plus Series 21000 BTU Air Conditioner
Air conditioner filter light stays on - Friedrich SL22N30 Kuhl Plus Series 21000 BTU Air Conditioner
LG filter light stays on
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. Air Conditioning Boca Raton
Jun 12, 2016 | LG Heating & Cooling
Rudd acheiver 10 heat pump wont stay cool
did you change the air filter and do not set it below 70,the tstat is not a gas pedal its works like a light switch, on or off, also please don't use your breaker as a switch its a safety device and will be damaged over time,If the unit starts to form ice (and it should never do that)
set the tstat from cool to off and the fan button from auto to fan on,this will speed up the thawing
Jul 02, 2013 | Ruud UBHC Air Conditioner
MY WINDOW UNIT LEAKS WATER ALL OVER MY FLOOR AND BLOWS WARM AIR. I CLEANED IT AND IT STAYED COOL FOR A WEEK AND IT FLOODED AGAIN.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Your unit is freezing up...check the air filter...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 03, 2010 | Premier Heating & Cooling
Why doe check filter light stay on. Filter is clean and in the right place. AC works fine
If you are speaking of the Filter light on the thermostat it is just a timed setting on the thermostat in most cases where the thermostat will flash filter every 30, 60 or 90 days depending on the settings. Looking up the user guide will show hot to turn the filter reminder off or how to reset it each time. Normally a thermostat does not have a communication of dirty filter with the actual system itself. More of calendar based filter changing.
Aug 17, 2010 | Airtemp B7D18E7A Air Conditioner
Model # m6p09s2a portable maytag air conditoner unit...red light keeps blinking at the unit where power button is located....unit will not turn on. the light just keeps blinking
Greetings,
I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
Hope that works for you. Stay cool. :)
Jun 16, 2010 | Maytag Portable Air Conditioner M6P09S2A
I have this ac unit, clean filter light on ??
The filter light comes on buy hours of run time, it's just a reminder to check /clean the filter. There should be a filter reset button on the thermostat to rest the hours counter and the light will go off. If the t-stat doesn't have a button for that, it's somthing like push UP & DOWN at the same time. need t-stat model and serial number to get info, If the installers left the manual for it, look in the index under filter or maintenence. if you're not able to locate the manual, let me know and we can go from there.
Sep 14, 2009 | Fedders SFPEB08F2A Air Conditioner
Intertherm Furnace Will not stay on
possible dirty air filter low air flow causing high temp in fire box to trip limit switch or fan motor is bad hope this help let me know if you if this solved problem I may need more info
Jan 04, 2009 | Intertherm P3RA-048K Air Conditioner
Air conditioner turns on then shuts itself off immediately
There's something wrong with your aircon. Usually the lights will start to blink. Depending on the brand and model, the number of times it blinks will give you an error code which tells you what's spoilt. You may like to check this out http://www.astiquer.com/blinking.html
Jun 09, 2008 | Frigidaire FAA065M7A Air Conditioner
Friedrich SL22N30 Kuhl Plus Series 21000 BTU Air Conditioner Logo
57 people viewed this question
Top Friedrich Computers & Internet Experts
David Payne
David Payne
Are you a Friedrich Computer and Internet Expert? Answer questions, earn points and help others
