Question about Refrigerators
Maytag mfi2269vem3 freezer door won't close all the way
The freezer door does not shut all the way and the alarm keeps beeping. We've emptied the drawers in the freezer but can't remove them. What can I do about this?
Master_Tech
  • 770 Answers
SOURCE: Maytag Frenchdoor w/freezer drawer - drawer sticks
you will need to remove the front and get to the slides clean them off and buy a low temp silcone to apply to tem do not buy grease apply it and work it in the problem will go away
Posted on Jan 24, 2008
SOURCE: bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Posted on Dec 04, 2008
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Posted on Feb 21, 2009
SOURCE: kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
Posted on Aug 08, 2009
bigjohn007
  • 425 Answers
SOURCE: The alarm beeper keeps beeping even though the
hi,
you can check a limit switch at its door. it is located usually at the door area inside.
maybe it is not working already or get stuck that is why it doesn't sense that the door is closed.
most of the time it is getting stuck and you can fix it by just pulling it out or other ways to do it.
hope that solves your problem.
Don't forget to rate me. Thanks...
Regards,
John
Posted on Jan 10, 2011
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
My Miele Fridge Freezer Keeps Beeping Although there is no issue, how do i remove the alarm?
I bet the light is also staying on inside even if the door is closed. There is a switch inside that turn the light on and off when the door is open. If the (Door Switch) is working then the light inside should shut off when the door is closed to save energy. It also tell the computer the door has been shut in case you forget then it will notify you. The switch may not be working. Look for a door with on ebay or sears. Need your model number and brand of the unit.
Sep 20, 2016 | Miele KFN8762SDED Bottom Freezer...
How can i stop the door ajar alarm when door closed and 0 f
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 19, 2014 | Frigidaire Freezers
Alarm sounds on fridge, not cooling
is it a bottom mount machine,freezer on the bottom?if the door doesn't close all the way and the alarm is on this could be your problem,the warm air gets in and freezes up the air ducts.look on the ceiling of the freezer and on the lite,if there's ice or like snow there the door was left open.also check the inside back wall of the freezer,touch it and see if there's any ice or like snow on the inside back wall,you could have a defrost problem or like i said before the door could be stuck open,look for frozen water droplets on your food packages or on the ceiling of the freezer,if so shut down the machine,pull out the food in the freezer and with a hair dryer heat the back inside wall of the freezer for like 15 to 30 minutes,turn it on,if you can feel cold air blowing into the fridge section you should be fine,you might have a package or i've seen people install the door draw in backwards and the alarm will go off because the door isn't closing correctly.let me know what you find and where the alarm is coming from,the freezer or the fridge side.good luck and happy holidays to you.
Dec 23, 2011 | Refrigerators
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
Freezer drawer slides
you have to keep the white wheels on the rod even or the draw won't close correctly,pull the racks out fully open and even on both sides,you might have to adjust the wheels so both sides are even,i use a marker and mark the wheels,now when you hook the door assy on.you have to make sure the wheels stay in place or when you close the whole unit one side of the door won't close all the wa,it's a little tricky if you never tried to line them up before but if you mark the wheels part numbers 12002497 so both sides stay lined up it will close correctly. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MFD2560HES/3048/0161000/M0412077/00009?blt=06&prst=0&shdMod=MFD2560HES this is the sears site and will show you a picture of all the parts.hope this helps
Dec 01, 2011 | Maytag MFD2560HES Bottom Freezer French...
Our maytag bottom freezer was left open on a crack and it thawed and then froze up... We emptied it and shut it down to thaw out. we dried it too, but the freezer is hard opening and closing . any...
HI,
The rails got water in them and froze. The only way to correct this is to remove them, allow to dry completely, like 1 or 2 days. Re install them and it should be fine. But the down side it the door won't stay closed during this process. You can order new rails but your rails aren't defective. It your option to elect which one of these you wish to do. If you are under warranty, have them replaced with new ones and keep the old ones.
I hope this helps
Aug 17, 2011 | Maytag Refrigerators
Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
Feb 01, 2010 | Maytag MFI2266AE Side by Side Bottom...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
