Question about Watches
Toshiba password when i turn my computer on it doesnt show my account screen. all it show is a black screen and a password display. how can i break this password?
  • 1 more comment
  • lukasz1007 Nov 11, 2007
    My laptop this toshiba a200-1m5. I forgot password to bios. I can not start system.
  • Anonymous Feb 19, 2008
    forgott admin acccount password
  • ruben11111 Sep 14, 2008
    I even can't start my BIOS, I need a password to get into it, how do i solve this?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 57 Answers
You will make a jumper shot for reset bios password send me email id for video
Posted on Oct 28, 2012
If the bios doesnt display the password, you can download OPHcrack(just google it) and set the biosto boot from CD
Posted on Apr 02, 2008
  • 59 Answers
You're most likely looking at the BIOS startup password. It will prompt before it even tries to start Windows. Most computers have a way to override this but more info will be required....make/model of machine would help greatly.
Posted on Aug 27, 2007
SOURCE:
I have a 2012 Ford Focus, when you turn the radio on, it displays 1 hour mode and plays for about 5 seconds and then shuts off, also I can not set time and date on the display screen?
if you have the code for the radio. remove the negative lead from the battery and leave of for a few minuets 10 at best then put it back on. then put code in radio, should sort it out.
Jun 26, 2017 | The Watches
I changed the battery in my Kenneth Cole KC1658 watch and nothing is showing on the screen...it is displaying a black. How do I turn the watch on?
1.make sure your battery good condition.
2. make sure installed properly.
3. reset movement there is two whole on circuit board use stapler pin to connect both whole for one second remove pin
your watch display should show up .
Oct 02, 2014 | Kenneth Cole KC1658 Watch
At first sorry that my english is not as well as it has to be. i have buy the Diesel Watch Style # DZ7080 color gold about too years ago in a shoping mall in miami florida. today i went to some one in a...
Black display, battery is ok. But, if you open it, pull out mechanism and look at screen and push time/date button in some dark place you will see that they are still running but without backlite. As i know it cannot be repaired.
Aug 02, 2011 | Diesel Watch Style # DZ7080
Have Rado 193. am trying to sync analog and digital time. Manual says turning crown slowly adjusts minutes. Does not - only hours change
You can adjust the analogue hands without changing the digital ONLY when you have set the watch to 24hr fornat. Do this by going to the second Timezone screen (T2) and pressing the crown once briefly. If A or P appears, the time display is in 12-hour mode. If no letter appears, the time display is in 24-hour mode. To change mode, press crown briefly a second time.
Now go to the basic display where no digital info is shown. Pull the crown out. Now slow turning will adjust the minutes and fast turning the hours, but only of the hands. Therefore you can synchronize the two. After they show the same time, press the crown back in and adjust both times together using the crown as normal on the standard "Time" digital screen
Dec 28, 2010 | Rado Maxi R21347712 wristwatch
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    How do I set the time on this watch?
    Hi, function SOswitchMenu() {var el = document.getElementById('bodyDiv');if ( el.style.display != "none" ) { el.style.display = 'none';}else { el.style.display = '';}var el2 = document.getElementById('h2');if ( el2.className == "calHeader goog-zippy-expanded normalText" ) { el2.className = "calHeader goog-zippy-collapsed normalText";return;}if ( el2.className == "calHeader goog-zippy-collapsed normalText" ) { el2.className = "calHeader goog-zippy-expanded normalText";return;}} function SOframeReload() {var f = document.getElementById('soFrame');f.src = f.src;}
    I had a watch similar, and it's actually very easy to adjust as soon as you have the solution, so:
    You need a very thin stick (maybe a toothstick or a think pencil). 1) Stick it into the upper pinhole (on the right side on the watch). Then it starts to blink. 2) Adjust by pressing the lowest pinhole 3) Confirm with the upper pinhole 4) Now you'll go through each step (hour, minute, date, 24/12h, etc.) 5) Finally you will se the time on the watch (not blinking), If you press the lowest pinhole you can choose between: - static screen showing time - static screen showing date - shifting screen showing both time and date
    Br. M
    Dec 14, 2009 | DKNY NY1304 Watch for Men
    How to disable netgear firewall?
    Rest you router by pushing a small paper clip or pin on the reset hole back of router..
    Hi, Follow the steps below to setup the home router:
    *-make sure you are able to go online from moem directly.
    1. Connect a computer to the router using any one of the 4 available ports.
    2. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
    3. Access the router usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
    4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
    5 go to Basic settings .> Does Your Internet Connection Require A Login? > no > Internet IP Address: Get Dynamically From ISP > Domain Name Server (DNS) Address : Get Automatically From ISP > Router MAC Address: Use Computer MAC Address > click on apply
    6 go to Router Status ..if you have and IP Address under internet port.. you would be able to go online wired..
    if not turn of your computer, router , modem....want for 1 min turn on your modem first, wait for the lights on modem > then turn on the router ..wait for the lights > turn on your computer. you would be able to go online..
    Click on wireless settings (under setup) from left menu.
    Change the channel to 11
    Apply settings to save the changes.
    go to WAN SETUP > check disable spi firewall > reduce MTU to 1400
    I hope the steps above will help resolve the issue. If you need any further help, please email us back so that we can continue to work on a solution.
    I hope this information allows you to resolve this issue.
    Aug 20, 2009 | Bulova Harley Davidson , , Red Flames On...
    How to turn off hourly alarm on Gap Sport watch?
    Click reset button (lower right) - this shows you the alarm time as indicated by a large letter 'A' that appears in the display.
    Keep holding the reset button and simultaneously press the mode (lower left) button.
    This toggles the days of the week at the top of the display.
    All days shaded in black means the hourly alarm is on.
    All days clear means the hourly alarms is off.
    Now, if I could just figure out how to choose the exact days the alarm can be set to ring ... it seems like it is possible.
    Aug 16, 2009 | Watches
    Watches Logo
    380 people viewed this question
    Top Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
