No wifi connection. When I try to connect wifi through "settings" I get message "To see available networks, turn on wifi".When I turn on I get message "Turning on". But it does not scan any net work as buttons for "scan" and "wifi Direct remains disabled. When I go to the Advance Settings in Wifi I see mac address A4:EB:D3:6B:FO:95 whereas IP address is unavailable. I am not getting wifi connection in my newly purchased samung galaxy grand GTi9082 two months back. I was getting wifi connection but after some updates wifi feature stoped working.
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
To help you connect to the internet via WiFi from your Samsung Galaxy Tab, follow the steps given below:
- First activate the Wi-Fi connectivity: on the Home screen, press the 'Menu' option and then click on 'Settings'.
- Now click on 'Wireless & Networking' and then 'Wi-Fi Settings'.
- Click 'Enable Wi-Fi'.
- The check mark will turn green and your device shall automatically search for available network.
First, try restarting the Galaxy S6. To do that, hold the power button on the right side of the phone until prompted. Hold it down again to turn the Galaxy S6 back on. It's a simple process but it has been known to dislodge Wi-Fi issues
If that doesn't work, Galaxy S6 users will want to try rebooting the local router if that hasn't been done in awhile. We recommend unplugging the router for a good 30 seconds and then plugging it back in. Users can do the same for the modem as well. Galaxy S6 users might also consider updating the routers firmware. This process will be different depending on make and model. If those simple fixes don't work, it's time to head into the Galaxy S6's settings.
If the Galaxy S6 isn't getting a solid connection, it's time to force the device to forget the Wi-Fi network in question. To do that, head to the desired connection in Settings. On the Galaxy S6, this can be found in the Connections portion of Settings. Once there, select Wi-Fi. Tap on the desired network and select the Forgetoption. Users will then need to reconnect to the Wi-Fi network. Make sure the password is readily available or the device will be locked out.
If that doesn't work, head into Wi-Fi, tap More in the top right corner, and select Advanced. Ensure thatAlways allow scanning is turned on. You'll also want to make sure that Keep Wi-Fi on during sleep is set toAlways.
Ensure that Wi-Fi is on. When you see a green check mark next to the Wi-Fi option, Wi-Fi is on.
Choose a wireless network from the list. Available Wi-Fi networks appear at the bottom of the screen. When no wireless networks are listed, you're sort of out of luck regarding wireless access from your current location. Optionally, type the network password. Touch the Password text box to see the onscreen keyboard. Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long. Touch the Connect button. You should be immediately connected to the network. If not, try the password again.
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity This chapter introduces useful tips on how to connect to the network available that enables applications of the phone to run. Using a Wi-Fi network Connecting to a Wi-Fi network 1. Tap Settings from the applications menu. 2. Tap Wireless & networks > Wi-Fi settings. 3. Tap Wi-Fi to activate the technology. 4. Select and tap a network. You should enter the password if the network is secured. indicates a secured Wi-Fi network. 5. Tap Connect. Once the network is remembered, the phone will automatically connect to it when in range. Activating Wi-FI Connecting to a Wi-Fi network Note The icon next to each network indicates the strength of the signal. For example, indicates the signal is poor while indicates the signal is strong. Using the Easy Setting 1. Tap on the top of the home screen and drag it down, or press n in idle mode and tap Notifications. 2. Tap in Easy Setting. The icon turns red when the function is on. About network notifications You are informed by default when a Wi-Fi network is available around you. The message in the status bar indicates a network is available. Tap Network notification in the Wi-Fi settings if you do not want to be informed the availability of the network. Setting Wi-Fi networks 1. Tap Settings from the applications menu. 2. Tap Wireless & networks > Wi-Fi settings. 3. Tap Wi-Fi to activate the technology. 4. Tap Network notification if you want to know an open network available. 5. Tap Automatic connection if you want the phone to connect to Wi-Fi network automatically. 6. Tap WPS button connection if you want to establish a new wireless connection using the Wi-Fi Protected Setup (WPS). You should press WPS button on your Wi-Fi access point within two minutes. Searching for Wi-Fi networks 1. Tap Settings from the applications menu. 2. Tap Wireless & networks > Wi-Fi settings.
Select the Wi-Fi check box to turn Wi-Fi on. The phone will scan for available wireless networks.
Tap Wi-Fi settings.
Select from the displayed network detected.
Tap a Wi-Fi network to connect. If you select an open network, you will be automatically connected to the network. If you select a secure network, enter the key and then tap Connect.
Mark the Wi-Fi checkbox. Available Wi-Fi™ networks are
displayed in a list under Wi-Fi networks. The available networks may be
open or secured. This is indicated by the icon next to the network name.
Tap a Wi-Fi™ network to connect to it. If you are trying to
connect to a secured Wi-Fi™ network, you are asked to enter the security
key for that Wi-Fi™ network before you can connect to it. The Wi-Fi™
connection is displayed in the status bar once you are connected.
Useful tip:
The next time you connect to a Wi-Fi™ network, the phone will remember the security key.
To enable Wi-Fi™ network notification of open networks, mark the Network notification checkbox.
To connect to another Wi-Fi™ network, just tap another Wi-Fi™ network in the Wi-Fi networks list.
To scan for Wi-Fi™ networks manually, press the Menu key and tap Scan. The phone scans for Wi-Fi™ networks and displays them in the Wi-Fi networkssection.
You can also try updating your softwares by going to the sites below;
Hello Derek, Connecting Wi-Fi in HTC Desire Cell Phone
From the Home screen, press , and then tap Settings > Wireless & networks.Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless networks.Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks are displayed in the Wi-Fi networks section.If the wireless network you want to connect to is not in the list of detected networks, scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network settings, and then tap Save.Tap the Wi-Fi network you want to connect to. If you selected an open network, you will be automatically connected to the network. If you selected a network that is secured with WEP, enter the key and then tap Connect.
