Question about Kenneth Cole Kc1523 Watch
Battery what size battery? how to take the back off
Fossil fs4141 battery size
  • Remove back
  • Find battery location. Note mounting arrangement for later new battery installation
  • Identify battery type (not size)
  • Obtain replacement battery
  • Install in correct position with correct polarity
  • Check operation
  • Install back
  • Set time, etc.
Sep 12, 2016 | Fossil Watches
Need watch battery size for a fossil blue watch model number Tl-5073
  • Remove back
  • Find battery mounting. Note for later battery installation
  • Read battery type (not size)
  • Obtain exact battery replacement
  • Remove old battery; install new
  • Check operation
  • install back
  • Set watch
Sep 09, 2016 | Fossil Watches
What size of battery fits guess steel
Just take it to a local jeweller and they will change the battery whilst you wait for $6 to $8. There are so many batteries and usually you can't by just a single one in the small sizes that watches use.
You often need a special tool to get the back off, and a jeweller's eyeglass to see the tiny screw and the right screwdriver to fit it.
May 20, 2016 | Guess Waterpro Bracelet Watch
What type of battery fits my watch?
The battery size may be stamped on the back of the watch. Jewelry counters that sell batteries will determine the size and even change it for you. If you are a bit mechanical you can remove the back, mine has little screws but often it is one you pry open with a thin screw driver. You will then see the battery but don't move it until you make note which side is up. The size is stamped on it. Put the new battery in facing the way the old one was and close the cover.
Apr 27, 2015 | Watches
I have a ladies Citizen Noblia 4420E without a battery and need to know the correct battery #. The diameter appears to be 5.8mm.
Im sorry. Unless it is printed on the back of the watch, or you have the battery, or it is printed in your manual, no one can tell you what size is needed. I will send you a link that you can use to determine what size you need. The best I can do.
http://www.watchbatteries-usa.com/size.html
Best regards.
Aug 23, 2010 | Citizen 47321 Wrist Watch
What size battery do I need for armitron digital sport watch 40-8117 m-690
If the watch #/size is not printed on the back of the watch, you will actually have to remove the battery to figure out what size you need. Best regards.
Aug 21, 2010 | Armitron Compass Bezel Chronograph Sport...
What size battery does the callaway cy2097 take
Unless it is on the back of the watch, you will have to remove the old battery to see what size it takes.
Thank you.
Aug 19, 2010 | Callaway CY2097 Watch for Men
I have a Caravelle Bulova watch #48G33 and I need to change the battery. I took it to a jeweler and he mess up the back and told me he did not have a battery that fit. I think he was unable to get the back...
Hey there !
if the back has a notch on the top left of the cover (right underneath to what would be 10'oclock position), it is a 'Pop-up'. But if the watch has 6-8 notches on the back plate of the watch its a screw-off.
Its really hard to say what battery size it would take due to the fact that each watch has a different operating mechanism and its hard to determine that from the model number.
Dec 23, 2009 | Caravell Bulova Caravelle watch
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
BATTERY SIZE
If you do not have the manual for it, you may need to remove the back cover in order to see th battery type. If removing the back proves too hard, a jeweler may do it for free or minimal charge. I got my battery from a dollar store and is a good name brand.Easy to install yourself.
Oct 28, 2007 | Fossil AM3726 Wrist Watch
Kenneth Cole Kc1523 Watch Logo
14 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
