Question about Proform 110R Exercise Bike
Problem with resistance levels
The bike has 16 different resistance levels. For the first 30 days I used it the resistance levels worked properly (the higher the resistance level the harder it was to pedal). However, since that time anytime I manually adjust the resistance level or it adjusts automatically within the established program the actual resistance remains constant (now it takes the same effort to pedal regardless of whether the resistance level is on 1 or 16). It is not the drive belt because I checked that and it is tight, besides the pedals are not slipping. Any suggestions or answers?
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Just bought my Proform 490 LE elliptical 1 day ago
If you purchase from a store I would take it back and exchange it, or if you purchased it on line then the manufaturer and have send somebody out to take care of this situation you have a warraty on the unit
Posted on Mar 13, 2010
SOURCE: proform gl 36
my gl36 proform exercise bike will not turn on even after i changed the batteries
Posted on Mar 20, 2010
maxtreadmill
  • 832 Answers
SOURCE: The magnetic resistence level seems to be the same
This unit incorporates an adjusting motor for the magnetic boot. This unit also uses batteries for the upper console functions I would check the batteries first and replace them, if you haven't done so before.
If this does not resolve the problem then it could be the adjusting motor, then you will have to pull the the side panels in order to apply a 6v dc to the motor and see if it moves smoothly, if not then replace motor.
Posted on Jun 26, 2010
ercupa190
  • 12223 Answers
SOURCE: My Pro-Form 330 elliptical has a resistance
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Posted on Nov 28, 2011
2017 Bajaj Pulsar 150 how to get better fuel economy
Hi, Anonymous the following tips are low cost easy to apply/install and guaranteed to give you better gas mileage and a smoother running bike. The average motorcycle gets 56-64 KMPL. saving .2 Litre of gas could save you a 10 Kilometer walk. 125cc scooters have been known to get 185 KMPL.and more.
1. Proper tire inflation as per MFG. specifications wheels should be balanced and spokes tight.
2. Oil and coolant levels maintained at full marks, low levels produce excessive heat that causes the engine to work harder and reduces efficiency.
3. Keep extra weight to a minimum.
4. Take off from a dead stop should be smooth and easy throttle applied avoid excessive throttle snaps.
5. Smaller windshields get better KMPH than large ones, wind resistance increases as a square of the speed at which you're traveling. For example, at 112 KMPH, wind resistance is double what it is at 80 KMPH (70 squared is almost twice as much as 50 squared). That will dramatically reduce your mileage. Keep that in mind while biking.
6. Keep idle time to a bare minimum or turn off the engine.
7. Re-jet carburetor with a smaller main and mid-range jet.
8. Keep chain/belt properly adjusted.
9. Avoid quick braking, hasty acceleration, high-speed driving, try driving the speed limit and keep a constant speed.
10. On long trips use freeways or flat straight stretches of highways rather than city or rural routes avoid hills and mountains when possible.
11. Keep your engine clean, dirt and grease/oil hold in heat.
12. A full-face helmet is more aerodynamic than other types of helmets. Any other clothing that decreases your aerodynamic should be reconsidered.
13. Any unnecessary bling on your bike is going to decrease fuel efficiency.
14. Use high-quality fuel using low-quality fuel can cause sludge in your fuel injectors.
15. Keep warm up time to a minimum get off the choke ASAP.
16. Motorcycles run best when their engines are maintained, and that includes making sure the air filter is clean, the spark plugs are fresh, the fuel filter is free, and the timing/valves are adjusted.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the links below. Good luck and have a wonderful day.
Tips on How to Increase Bike Mileage
Bike Mileage Tips 10 Quick Tips to Improve Your Bike Mileage https://www.cartrade.com/answers/17319.html
Bajaj Pulsar 180 DTSi Workshop Manual
Bajaj Bike Spare Parts
Bajaj Pulsar 150 DTS User Manual
Jan 23, 2018 | 2011 Bajaj Pulsar 150
I have pulsar 150 , how to increase its fuel mileage ?
Hi, Tushar the following tips are low cost easy to apply/install and guaranteed to give you better gas mileage and a smoother running bike. The average motorcycle gets 35-40 MPG. saving .2 gallon of gas could save you a 6-mile walk. 125cc scooters have been known to get 115 plus MPG
5. Smaller windshields get better MPH than large ones, wind resistance increases as a square of the speed at which you're travelling. For example, at 70 mph, wind resistance is double what it is at 50 mph (70 squared is almost twice as much as 50 squared). That will dramatically reduce your mileage. Keep that in mind while biking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
10 best tips to get maximum mileage for bikes VIDEO
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarOwner%20Manual.pdf
Jun 17, 2016 | Motorcycles
How get milege ?
Hi, Shiva the following tips are low cost easy to apply/install and guaranteed to give you better gas mileage and a smoother running bike. The average motorcycle gets 35-40 MPG. saving .2 gallon of gas could save you a 6-mile walk. 125cc scooters have been known to get 115 plus MPG
5. Smaller windshields get better MPH than large ones, wind resistance increases as a square of the speed at which you're traveling. So, for example, at 70 mph, wind resistance is double what it is at 50 mph (70 squared is almost twice as much as 50 squared). That will dramatically reduce your mileage. Keep that in mind while biking.
Good luck and have a nice day.
Jan 25, 2016 | Vespa Motorcycles
Increase the mileage
Hi Anonymous, the following tips are low cost easy to apply/install and guaranteed to give you better gas mileage and a smoother running bike. The average motorcycle gets 35-40 MPG. saving .2 gallon of gas could save you a 6-mile walk. 125cc scooters have been known to get 115 plus MPG
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Double Your Gas Mileage 2X
Tips to get maximum fuel efficiency out of motorcycles OVERDRIVE
10 best tips to get maximum mileage for bikes VIDEO world record of bike mileage fuel economy 500 KM per Liter of Petrol
http://second5boyish.sincerostranstornos.com/service-manual-2003-caliber-115_maaucew.pdf
Mar 15, 2014 | Bajaj Caliber 115 Motorcycles
Resistance settings not working on fitnex r70 magnetic resistance exercise bike
If this is a new bike that may be the way it is. If it worked differently in the past, you may be looking at a busted tension motor or faulty brake.
Jan 03, 2014 | Champion Fitnex R70 Recumbent Exercise...
What are the different program settings available in exercise bikes?
In most exercise bikes, you can control the resistance and the time. You can choose the resistance level and the duration of the workout.
Feb 07, 2013 | Exercise & Fitness
I get very low mileage with my bajaj platina 100 cc ( i.e around 50 kmpl ) How to set the carburettor to get more mileage.
Hi Mauryadurgap, the following tips are low cost easy to apply/install and guaranteed to give you better gas mileage and a smoother running bike. The average motorcycle gets 35-40 MPG. saving .2 gallon of gas could save you a 6-mile walk. 125cc scooters have been known to get 115 plus MPG
Best 100cc mileage bike in india 2015
Bajaj Platina 100 2014 service manual DOWNLOAD FREE FULLMANUALS COM
PLATINA SPC
Bajaj Auto Platina Alloy Wheel Es User Manual
Jun 21, 2011 | 2011 Bajaj Platina 100
Resistance too strong even when bike is at level one..was working fine??
you need to try unpowering the machine for 30 min then pug back in if this does not reset you resistance motor, you need to get a new and put it in.
Oct 07, 2009 | Fitnex B70 Upright Bike
Tension
The new and improved exercise bikes have what is called magnetic resistance. This is where your resitance is created by a magnet and some sort of power source such as batteries or your bike being plugged into a wall outlet. If you are using batteries replace them. I found that with my elyptical exerciser new batteries made a world of difference in the resistance settings. Make sure the batteries are strong ones. If changing the batteries doesn't help then there may be another problem. This could be the computer or a magnetic part. These parts are usually replaceable through the manufacturer. Just check your user manual and I am sure you can get it replaced. I hope this has been helpful.
Mar 16, 2009 | Cycling
Proform 110R Exercise Bike Logo
77 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
