Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
9hp kawasaki ohv
I have a John Deere RX75 riding mower that i just put a new starter motor in.All terminals have been cleaned at the battery,solenoid,starter,and ground wire.The solenoid is remote from the starter so i connected a short positive cable from the solenoid terminal to the starter and the battery positive cable to the other solenoid terminal connection.I have a diagram from a John Deere parts catalog that shows the cable connecting from the solenoid to the starter as being correct and i assumed the connection from the battery to the other solenoid terminal is correct.The diagram that i have does not show the third eyelet connection and to which solenoid terminal it connects to.Do you know if it goes to the battery terminal or the terminal that goes to the starter ?I was waiting for two weeks for some parts and should of marked the wires instead of leaving it to memory! Thank You!
  • 4 Answers
SOURCE: 4020 w/ 24v system sparks when the battery is connected
I usually fix electrical problems by process of elimination. Disconnect the wires attached to generator and touch the battery cable to the battery if it still arcs disconnect the regulator. continue until you find whats pulling current from the battery.
Posted on Jun 05, 2009
SOURCE: John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Posted on Jun 21, 2009
nova2nv
  • 197 Answers
SOURCE: john deere 318 wiring diagram I replaced an bg 316
Purple wire goes to the solenoid on starter.If you installed starter with single wire post all you have to do is mount a solenoid to the frame just in front of starter,existing batt/starter cable goes to one solenoid post,purchase a short red cable and install on other solenoid post and run it to the starter,plug purple wire into new solenoid and the way you go.
Posted on Nov 16, 2009
Testimonial: "This was great advise bought a solenoid and away i go thx"
6ylucy
  • 742 Answers
SOURCE: manual for john deere sx95
ask manualfox.com - they have it.
Posted on Apr 19, 2010
brado83
  • 106 Answers
SOURCE: Need to replace the belt
HI,
Posted on Aug 01, 2011
Service or part manual for Kawasaki 9hp fc290vbs10 engine that's on a John Deere rx75
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Nov 07, 2016 | John Deere Garden
What type of oil doe it use
10W-30 Turf Gard
http://www.greenpartstore.com/John-Deere-GF-3-10W30-Turf-Gard-4-Cycle-Motor-Oil-Quart-TY22029.html
May 12, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere rx75 adjust belt tension
Best Manuals
Apr 21, 2014 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
My john deere gx75 don't go into reverse and when i put forward gear i hear a noise like a tic tic tic...
It sounds like the spider gears inside transaxle is worn or broken causing noise and causing reverse not to work.
Oct 16, 2013 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere rx75 belt routing diagram
I found manual on amazon... so you can take a look there Amazon com john deere rx75 manual. I hope this was helpful. cheers
Jun 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
