Jkexer polar 5090
The Motherboard has burnt out due to not being turned off and over heating.... Is it possible to replace the motherboard.. and where can I find one?
SOURCE: compaq presario 1200- no power-
i dont really say if your mboard will get a damaged..try to change your power plug..if it still not working, you have to open your laptop, so you can find or know if there's some thing wrong...maybe you should have to buy a new one instead of replacing it..coz, if some parts of the motherboard also have damaged, its very hard to fix.. the parts are very small and delicate to fix it..thanks..
Posted on Feb 20, 2008
ailia
  • 175 Answers
SOURCE: Need to get a replacement motherboard for toshiba satellite P-105-S
Hi Dear. From Laptop Repairing Workshop.
Posted on Apr 14, 2009
  • 94 Answers
SOURCE: Hi, I have a problem with my computer, it keep
1-> Check the cooling fan is working in proper RPM speed
2.-> check heat sinc have coted with proper paste ( it shuld be properly sticked)
*********** board is ok,
Posted on Jul 04, 2009
SOURCE: the motherboard is damaged due to earthing
The motherboard can not be repaired so it is the need to buy the new motherboard and you should to do it.Now you have buy a new one.
Posted on Apr 05, 2010
heavymetal77
  • 721 Answers
SOURCE: burnt components on wr55x10942 motherboard
Replace it & the power supply. Make sure that the switch on the power supply is set to 115v for U.S. or to 230v for Europe.
Posted on May 17, 2010
How do i repair the motherboard when the capacitors are swollen
You need to have fairly good soldering skills to perform a capacitor replacement on a motherboard. There are many adjacent components that are both ESD and heat sensitive. You need to be able to ensure that you replace the capacitors with ones of the same microfarad and voltage rating. Also ensure that you observe the correct polarity. Even after all that, I'd say you chances of a successful repair are 50-50. But capacitors ARE cheaper that motherboards, so if you feel lucky, go for it!
Mar 06, 2015 | Computers & Internet
How to unfold jkexer polar 5090 treadmill ??
see the video and proceed with common sense. and fix it. God bless you
Nov 11, 2012 | Exercise & Fitness
I have a jkexer polar 5090 treadmill and its coming up E1 any ideas please
1) You must adjut the speed sensor, clean it, tight the connector very well.
see the diagram attached.
2) Lube the deck belk, you have deck belt worn.
3) Lube the rollers bearings.
4) Test the input voltage for motor, if there are the motor need repair.
5) Test the output board, for input voltage motor, if there are not the board is faulty.
Sincerely. God bless you,
May 10, 2012 | Polar Exercise & Fitness
My Dell optiplex gx 270 tower's chipset heats up and system shuts down and my friend's gx270 mother board is burnt due to same reasons
check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps
May 06, 2012 | Dell OPTIPLEX GX270 (Y1057) Motherboard
Can i upgrade my packard bell 5090 motherboard?
No. And old isn't what your PC is......it's ancient. Packard Bell machines from that era were in proprietary cases, making upgrades difficult if not impossible. Additionally, the power supply will probably be underpowered and will may not have the correct power connectors for modern mainboards . It's time to part with the old relic and get a new one.
Jan 31, 2012 | Packard Bell (181368) Motherboard
My n81 over heats when i am use it for more than 10 minutes and causes the battery to drain and eventually turns off after that
This is a fault in the motherboard, a possible shorting in a semiconductor thereby draining high current and so the battery is drained.
In most cases the motherboard needs a replacement unless the component that is heating is discrete, a possible diode or regulator.
Need to take consensus after a visual check to estimate.
Oct 03, 2011 | Nokia N81
I have an HP Pavilion dv6 1030us, and I replaced the fan due it going bad, and also the touchpad, and everything worked fine, till I started trying to turn it on, it gets all the way up, and i can enter my...
When you replaced the fan, did you clean off the old thermal compound from the processor and other chips and replace it with a fresh layer? It sounds like your computer is shutting down due to heat. Also, did you remember to plug the new fan into its connector on the motherboard? I know it sounds silly, but sometimes people forget, or don't seat the plug all the way and it comes loose.
There's also the possibility that the motherboard suffered some heat damage before you replaced the fan, but check the other things first.
Jul 09, 2011 | HP Pavilion dv6-1030us Notebook
Turned on and smoke
Is the burnt circuit on the motherboard or the power switch circuit board that plugs into the motherboard? Big difference, if the burnt circuit is on the motherboard then yes the motherboard is done and will have to be replaced, but if it's just the power switch circuit bard, then this is replaceable.
Aug 28, 2008 | Toshiba Satellite A105-S4334 Notebook
OVER HEATING
Two possibilities:
  • the CPU is really overheating; and/or
  • the motherboard is falsely sensing high temp.
Corrective measure for an overheating CPU would be:
  • clean, re-lubricate or replace the fan;
  • clean or refit the heatsink. If it is overclocked, you may need a better heatsink.
If the CPU is not really heating up abd the motherboard is sensing erroneous temp readings, then the problem may be with:
  • BIOS version, try to flash and update the BIOS; and/or
  • check the temp probe underneath the CPU, it may need cleaning or slightly bending away from contact.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 13, 2008 | Intel D865GBF Motherboard
No beeps, no picture!
please check whether there is burning in the motherboard due to this there is no switching in the motherboard. plz get the motherboard repaired. their is no problem in replacing the 20-pin psu
Oct 04, 2007 | Compaq 187498-001 Motherboard
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
