Question about SanDisk Sansa e130 MP3 Player
Searching for new music
IT was working till i tried to turn it on one day and it went to the third screen the one after it say sandisk and then sansa and it just says Internal Searching for new music and it sits there an does nothing. Help!!!
    Novelist:
    Scholar:
  • 114 Answers
Take the memory card out, clean the contacts and if you have an air duster clean the socket, reset the device by doing the following; take the battery out, hold the power-on button for 30 seconds (time it as it will seem to take forever). Put a new battery in and try it again. If this is no help then it would seem that either the memory card's file system or the internal memory's file system so plug the device in over USB and backup any data your PC can find. with anything that can be rescued, rescued format the memory using FAT32, do not use quick format. Alternatively you can buy rescue software from SanDisk www.lc-tech.com/software/rescueprodetail.html but it's not guaranteed to help.
Posted on Aug 27, 2007
  • Nicholas Wilson
    Nicholas Wilson Aug 27, 2007
    Woops I missed a chunk of sentence there! it should reed:
    If this is no help then it would seem that either the memory card's file system or the internal memory's file system is corrupt or at least unreadable to the device so plug the device in over USB and backup any data your PC can find. with anything that can be rescued, rescued format the memory using FAT32, do not use quick format.
I connect the Sansa E130 through the USB port to my Linux-Box. I backed up all the files. I remove all the files from the flash memory, also the hidden ones. Then, I put one by one the music files. I worked without re-formatting the flash.
Posted on Nov 26, 2007
  • 59 Answers
I'm going to guess here and say that info (music) on the unit is toast...bite the bullet...wipe the unit and start over. You may want to wait on a second opinion though.
SOURCE:
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
I can't turn down volume on my Sansa mp3
Try rubbing alcohol on the area. might just need to be cleaned
Jun 04, 2009 | SanDisk Sansa Clip MP3 Player
Screen went blur after downloading music
Try refreshing it if that dioes not work go to sansas website and call their tech support for your area.
Apr 17, 2009 | SanDisk Sansa e270 MP3 Player
My M240 sandisk is frozen
Attention: Resetting the device will delete all the songs
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
May 30, 2008 | SanDisk Sansa m240 MP3 Player
My mp3 freezes up..can anyone help??
Thank you for the help in reformating my sansa e140. It worked perfectly!!!
Jan 18, 2008 | SanDisk Sansa e130 MP3 Player
Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Apr 03, 2007 | SanDisk Sansa e260 MP3 Player
Internal Searching for music
I had this same problem. I moved all the files off the device. Went into Windows explorer. Right clicked on the Sansa device (the internal memory, not the expansion card memory. Clicked on format and on the screen that came up I picked "Quick Format." I have just now moved all the music (but not the system files) back onto the player. Turned it on and it is now working. Hope this helps
Feb 27, 2007 | SanDisk Sansa e130 MP3 Player
It doesn't give me my music
Check to ses if they are .mp3 files.
Battery
I'm having the same problem! I've had my Sansa e130 for exactly one year today. I loaded new music on it last night and when I tried to turn it on, it said "searching internal memory for new music." I left it on and this morning it wouldn't come back on with new batteries or even when hooked to a computer! I sent an e-mail to the company for help since there is no reset button. I haven't heard anything yet. I suggest you contact SanDisk too. They may have a problem. And I can't believe someone actually suggested as a solution to put a new battery in it or hook it up! No duh! We're looking for real help here, not the obvious things to try.
Apr 01, 2006 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa e130 MP3 Player Logo
191 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
