Question about GE JVM1850 1000 Watts Microwave Oven
Ge microwave wes145odm1bb model
Diners are coming out overcooked
My wife overcooked a potato to a crisp in the microwave. The microwave doesnt work at all anymore. No life. Breaker good. But my smoke alarms do. Any answers
Without the full model number, I can only give a general answer.
I would suspect that the overheating damaged the thermostat / thermal cutout that protects the magnetron. Hopefully it did its job.
This most often occurs when the microwave is left to run unattended, a big no-no as mentioned in the owner's manual.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Oct 01, 2011 | GE JVM1860 Microwave Oven
I have a GE Microwave Oven/Dual Element Browner Model # JES1288SHO3. The inside cabinet is arching through the wave guide panel. DAVE IN LA.
Hi Dave in LA,
The wave gude cover is replaceable, the part number is1085082. The reason for arcing through is typically a splatter of food stuck to the cover and then the heating waves overcooked or burned it. Carefully replace the cover (panel), look for any burned spots behind the cover, if the wave guide is burned through, the Microwave is unrepairable. If the waveguide has small arc spots you can carefully clean (sandpaper) and use touchup paint to recoat. I hope this helps and if it does, please let us know!
Apr 18, 2010 | Microwave Ovens
No heat micro keeps cycling through all programsdemo in cook/bx
My GE doesn't have a Demo mode but say we have a power failure. It won't let me use it until I set the clock.
Try that and see if it helps
May 26, 2009 | GE Profile Spacemaker Over-the-Range...
Did I blow it up????
After washing you need to poke holes in potatoe skins or the steam can cause them to explode. Cook potatoes no longer than 6 to 8 minutes depending on your units power.
Microwave ovens can be very dangerous if damaged, so you will be safer to replace the unit. Better safe than sorry. Service on microwave ovens is not cost effective, and the newer ovens are very reasonable.
Ray
Oct 28, 2008 | GE XL1800 1100 Watts Microwave Oven
Overcooked potato overcooked the microwave
The magnetron probably overheated, blowing the thermal cutout / thermal fuse / thermostat mounted on it.
If you or a friend decide to look into it, we have critical safety and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Cleaning the door insides
The door should come apart with a little prying. Be careful because the plastic can break fairly easy. You can look at this description to see what pieces are involved. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503590
Nov 07, 2007 | KitchenAid KHMS155LSS 1000 Watts Microwave...
GE JVM1850 1000 Watts Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
