Question about Android Apps
Backlight,out I can touch the phone and things will happen but my backlight won't come on
    New Friend:
If you are getting a response but no light the back light is out, shorted, etc. but tablets are a little tricky to self fix so bring it in.
Posted on Jul 12, 2013
White screen, can only see shadows of the picture
Hello
Its backlight is not working. Check the CCFL tubes, and it backlight inverter board for fault.
Backlight inverter board will look somewhat like this. If this board has damaged, CCFL lamps won't light up, and there will be no backlight. OK.
Jan 03, 2012 | Dynex DX-40L260A12
My xperia x10i fell in water i have dried it 4 about 60 hours everything is working fine else than its backlight
The water that remained on the backlight section conducted as this section had voltage for the back light LED's resulting in failure of a track or a fusible resisitor on the board.
You need to use a good magnification glass or inspection lens with a desolderring station to touch up the cracked or damaged area to restore the connection to the backlight LED.
Jul 26, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My Kin 2 screen won't show anything. It still gets messages and everything, it's just the screen won't show it.
mine is doing the same thing no one will seem to give us the solution but i will call verizon and if they tell me i will let you know...
May 23, 2011 | Microsoft KIN Two Cell Phone
Hi I have a Acer aspire 9410 (9414wlsmi) 17 screen. The problem is that i have no backlight at all, i've bought a new screen + new inverter/backlight driver + new cable but it did'nt help i have...
The inverter/backlight combination isn't the whole picture. The inverter powers the backlight, but the inverter is controlled by a signal commonly called "Brite-On", which comes from the motherboard. If the "Bright -On" signal from the motherboard is missing,then the inverter (and thus the backlight) won't work. The problem you are having is on the motherboard. here's a link to a datasheet of such a device:
http://pdf1.alldatasheet.com/datasheet-pdf/view/245132/FAIRCHILD/FAN7317.html
May 15, 2011 | Acer Aspire 3690 (LX.AFL0J.044) PC...
Screen lock after a short time want to disable this feature S/W Version LN510ZVC
1. Touch > Main Menu > (slide the screen up) >
Settings > Display > Backlight.
2. Select Backlight Dim or Backlight Off.
3. Touch a time setting.
Feb 13, 2011 | LG Rumor LX260 Cellular Phone
Backlight won't come on after water damage.
The only thing you can do is to dry it out.Remove the battery panel and battery.
Wipe inside battery compartment and battery with kitchen towel, then move all pieces to a warm room(not on radiator) and leave for 24 hrs.
Then fix in battery and battery panel.Turn on ,that will be the best as you can get this phone. Fingers crossed for you.
Dec 11, 2009 | Apple iPhone 3G
Env Touch backlight stays on
go to your settings choose backlight and turn it off
Sep 16, 2009 | LG enV Touch VX11000 Cell Phone
Back light
if you mean that only the backlight is not working then this may have happened when you opened the handset you didnt place all correctly ...
just open it again and near by screen there will be a pin or chip which must touch the board to get backlight ... so i think that might not be touching the board ...
so open it and make it touch the board ...
you will get the backlight...
your problem is minor one you can solve it by your self ...
this has happened due so loose conntact inside ....
Mar 31, 2008 | Nokia 6126 Cellular Phone
Android Apps Logo
77 people viewed this question
Top Apps Experts
Brett Duxbury
Brett Duxbury
Are you an App Expert? Answer questions, earn points and help others
