Question about Kenmore Washing Machines
Replace pump kenmore 417.29042991
How do I access the pump on dthe Kenmore referenced
4 Suggested Answers
  • 57 Answers
SOURCE: how do i replace the pump in a kenmore he2t front ...
The outlet pump can be easily identified by reverse tracing the outlet pipe most of the unit will have at the back of the unit so remove the back side cover you can see the pump two clips will be present one from the drum and another is connected to the outlet pipe just remove the clips then two screws will be presented kindly remove those to unfix the pump from the machine then you can easily replace the pump
Posted on May 19, 2010
  • 670 Answers
SOURCE: KENMORE WASHER 110.267.91690 pump leaks. Can I
If you are mechanically inclined and have a few basic tools, Yes you can. I have instructions for you and this link will take you to Sears website for drawings and parts direct.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11026791690&productCategoryId=0153200&brandId=0582&brandDescription=KENMORE&modelName=AUTOMATIC-WASHER&diagramPageId=00001&componentDescription=TOP%20AND%20CABINET&documentId=10045916&blt=06
Disconnect the power cord. Turn off the water. There are two clips, one at each front corner, holding the control panel in place. 1. The best tool to use to unhook these clips is a putty knife. From the front push the putty knife between the machine top and the control panel at either outer corner of the control panel . You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring clip releases the control panel corner will lift easily. Repeat at the other corner. 2. Now, simply and carefully roll the control panel over the back. Do not force, some models have screws in the back top corner of the panel check this before rolling panel over the top. 3. Unplug the wire that connects the control panel to the top of the case. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the front of the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. The pump is the most forward part in the bottom of the case. There are two clips attaching the pump to the machine. Carefully release them with a flat blade screwdriver. There are two hoses attached to the pump and can be reused with the new pump. Be prepared to catch residual water left in the hoses from the last run. Unless you had a pump leak then they are probably empty. But best to be prepared. Allow 30 to 45 minutes for the first removal.
If the link does not work, an exploded view of your machine is available at www.sears.com under the parts direct tab enter your model number, found under the lid at the back of the tub opening. Copy and paste model number if needed.
11026791690
If you have any questions, I am here at least onc a day. Good luck.
Posted on Jul 09, 2010
richroth
  • 9472 Answers
SOURCE: washer leaking intermittantly while drainong
Take a look at this service manual. You model may be a little different but the process should be the same.
Posted on Nov 04, 2012
We have a new drain pump and can't figure out how to access the old one. 630.13993012 Kenmore elite dishwasher. How do we access the drain pump to replace it?
Many parts suppliers have excellent video tutorials on their sites.
This is not a trivial replacement, but with patience and guidance, you can do it!
Lacking a a video, an exploded view drawing will also help!
Oct 22, 2016 | Kenmore Dishwashers
HOW TO ACCESS DIAGNOSTIC CODES FOR TROUBLESHOOTING
Tub-to-pump Hose - Sears Parts Direct
www.searspartsdirect.com/part-number/4738er1002a/0026/795.htmlPart Information. Choose this manufacturer-approved tub-to-pump hose for yourwasher. This tub-to-pump hose replaces the damaged or leaky hose connecting ..
On google; Try to unplug it for a while, see if it resumes without error code.
Jul 17, 2015 | Frigidaire Kenmore Washer Tub to Pump Hose...
Kenmore elite he4t f33
The F33 code can indicate a bad pump or a problem with the wiring either at the pump or the CCU (central control unit), or the wiring harness itself. Before you replaced the pump, did you test the resistance in the wiring harness?
Unplug the washer and use an Ohmeter (VOM) to test. See http://media.fotki.com/1_p,wtftddqbdtwbdkrxgtqsskgwtqkq,vi/tgdkbwkswxfddbwsbdbxtbgtgwftb/1/1303472/5961857/image49983img-or.gif for the schematics of the wiring for the pump on the CCU. To access the CCU, you need to remove a few screws on the back of the top panel. You remove the lower service panel on the front of the washer to access the pump. The wiring should read 12.3 ohms at the CCU. If you get a reading of infinity (open), check the pump. If the leads to the pump motor give a resistance of 12.3 ohms, then the wiring harness should probably be replaced. If the circuit to the pump is fine and the error persists, then the CCU is faulty and needs to be replaced.
I hope this helps. If you add a comment with the specific model of your washer, I may be able to give additional suggestions.
Dec 23, 2012 | Kenmore Washing Machines
What does the code F33 mean
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit). Remember to disconnect power to the washer before attempting access. could be a bad pump or loose wire connections. good-day !
Nov 17, 2011 | Kenmore Washing Machines
Kenmore washer reads f-33
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 14, 2009 | Kenmore Washing Machines
Kenmore washer does not empty on spin cycle & is leaking water
This video will show you how to open the cabinet.
Ignore the coupling replacement.
Just use it for cabinet access.
The pump is attached to the motor.
Apr 21, 2009 | Kenmore Washing Machines
My Kenmore 70 series washer will not drain, what can I do to fix this? It will spin properly, but there has been water in there for about a week
Sounds like you need to replace the pump. Go to www.shop.washermd.com and download the motor coupler replacement tutorial. This will show you how to access the pump. Dave
Mar 02, 2009 | Kenmore 22422 Top Load Washer
Water won't spin out
Only two possibilities; if belt driven, the pump belt has snapped, if shaft driven, the pump has failed. Opening the back of the washer shouldn't be difficult, 8-10 screws, probably hex-head. Checking the interior, you may find pieces of a black drive belt. If you don't, then the pump itself is probably bad; the drive shaft may have separated from the impeller.
Check Sears website for the belt part number; they have 100s of thousands of illustrated parts diagrams with part numbers given and the chance to buy directly on line. You might also note the pump part number once you are on the right page.
If the pump has failed, check if you have a Johnstone Supply in your area; their parts prices are aimed at wholesalers but they will not turn you down and won't have a problem cross-referencing Sears/Kenmore part numbers.
Sep 13, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
14 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
