Question about NetGear WN3500RP Dual-Band WiFi Extender
Will it work
Will this extender work with at&t U- Verse Modem/router SSID 2WIRE785
How do I find the SSID so I can set up my new wireless printer?
Most new modem/routers come with a pre-set SSID & password. They are generally located on a label on the rear or underside of the unit.
In the even that yours is not "broadcasting" it's SSID, you'll need to access the modem/router web interface (a webpage) & verify or tick the box which activates broadcast of the network name (SSID).
You can Google for your brand of modem/router to find it's default web address (usually begins something like 192.168....) and username/password. Type that number into the address bar of any browser, input the default user/PW, & access the modem/router's settings. From there, you'll look for the settings page which talks about the network/wireless.
Dec 10, 2014 | HP Envy 4500 e-All-In-One Printer, Copier,...
Change network name (SSID)
Is this an ATT U-verse and you have TV on a different box? if so you will need to contact them. If you had to have the router replaced they forgot to re setup the system as the two devices work off each other somehow.
Mar 26, 2014 | 2wire (1000-400108-001) Router
I HAVE A BELKIN N 300 CONNECTED TO MY COMCAST MODEM EVERY 20 MINUTES I LOSE MY SIGNAL, I HAVE TO REFRESH
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Mar 18, 2012 | Belkin Basic Wireless Router
I am trying to download movies from Direct TV on demand using a D-Link device and it worked before until I changed to at&t U-Verse. I entered the new IP address to Direct TV i.e. 192.168.1.254 however...
Since you already switched from DirecTV to U-Verse, I'm not sure if you can still download movies the same way your doing before with DirecTV. First of all, AT&T is serious when it comes copyrights policy meaning all of their equipments are secured and won't really allow you to copy any movies from their network. The 192.168.1.254 ip address you put in is the default gateway of your AT&T U-Verse modem, meaning its the ip address you use to access the interface of your modem and eventhough you manage to access the interface of the modem, you won't be able to login to the site not unless you call AT&T technical support team to assist you on logging in to that site.
Sep 10, 2011 | D-Link DIR-615 Wireless Router
How To Use a Belkin Wireless G Router as a range extender? I'm trying to hook my Xbox to the internet, the problem is that the xbox isn't wireless and internet comes from a wireless modem and is...
You can Convert the Router as an Access Point But your Wireless Modem Should Be Hard wired to router. But if your Router has an wireless Bridge Option in it you can Convert it as an Range Extender. Check For the Wireless Bridging Feature on your Router or Please Post your Router's Model Number Here. I Will Be Glad to Help you out... :)
Mar 12, 2011 | Belkin N1 Vision Wireless Router
I have purchased a T-Box from Telstra and have to connect it to my computer to set it up. It is asking for a password or security key? I have tried every number on the bottom of the wireless router but...
Telstra has a YouTube video on setting up the T-Box. Click on this link to view the video :-
http://www.telstra.com.au/tbox/video-popup.html?vid=BV072L9dweA&title=How%20to%20setup%20your%20T-Box
The video also shows how connect the T-Box to the wireless router/modem.
To connect the T-Box to youre Belkin wireless router/modem the SSID and password you need to enter is on the card supplied with the modem.
If you still need assistance, then list each steps you take and any error messages and get back to me.
Sep 06, 2010 | Computers & Internet
Have ATT Uverse & it always drops the internet connection. I reset the main 2wire box weekly. The little router by my desktop is the problem - I have to disconnect & reconnect several times per...
check with 2wire website for a newer firmware version. if you are able to update to a newer version and still have problems, then your router is on its way out.
Aug 24, 2010 | 2wire (1000-400108-001) Router
I have a dell 1180 truemobile USB wireless adapter and does not sem to coneect to my AT&T U verse. has WEP key enter and U verse has a WPA key. are these incompatible? How can I make it work
if the adapter wont do WPA then yes it is incompatible. You will have to logon to your modem/router and change its wireless settings to WEP
please give details of your router/modem etc if you need help with this
Jan 15, 2010 | Dell TrueMobile 1180 802.11b Wireless...
2wire wireless connection problem
Make sure that the wireless switch on your laptop is on. Click on view wireless network by right clicking on the network icon on your system tray. Locate the name of your modem ( SSID ) & enter the wireless encryption key ( WEP ) or password
Apr 08, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Repeater function
you make a device into ap mode you can get it
Jun 09, 2008 | SMC EZ Connect g SMCWEBT-G
NetGear WN3500RP Dual-Band WiFi Extender Logo
81 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
