Question about Philips 30PW633R 32" TV
  • 45 Answers
Re: TV WANT COME ON - Philips 30PW633R 32" TV Standard (CRT) Televisions
Is this an LCD?? Patrick
Posted on Aug 27, 2007
0 characters
3 Points
Need to attach base to tv
There is typically four slots & four matching L shaped pegs on the base. On the bottom of the base there will be an arrow with or without text showing which way is Front. Match the pegs & the slots & push till you hear a click, which means the base is locked to the TV. If it doesn't swivel right, look for the thumb tab on the bottom of the base & push it to release the base, turn it 180? and repeat the steps above to lock the base back into position. -DellTech1
Nov 08, 2013 | RCA Standard (CRT) Televisions
Philips tv powered off and wont turn back on
There is a smt located at 7404 [C-6 Bottom] A common problem, does the tv make a sound like it wants to come on? Location 3239 should be small resistor, 3414 another resistor and a driver transformer at 5402 if it looks burned. See MCM electronics website and see if there is a kit to repair this. Or ask for part #s as per location of problem area mentioned. What you will be doing is changing the timing so all the components will come on at the same time. If this is done correctly you will notice the top of tv screen will flash red, green and blue lines. This will be the new norm each time you turn it on. But it will be OK. This is what the flashing green light is telling you. signed the Green Lantern7!!!!!!!
Sep 03, 2009 | Philips 30PW8420 TV
JVC AV 32D305y won't turn on
check the horizontal transistor at the back of plyback,it is a big rectangular parts with 3 pins
Oct 22, 2008 | Philips Magnavox MS3252S 32" TV
Magnavox 27m53404/17 Picture went out
Hello there, I'm having a major problem with my TV, I have called all of the local TV repair shops and they all are the same, they want money money money before they will even speak with me about the problem I'm having. This is the only TV in my entire household for a family of 4 and we desperately need the TV in working condition for our kids. I don't want to have to put out $500 for another set if I don't absolutely have to.
The Problem...
About 3-4 months ago the TV when turned on, the picture would slowly come into view and be very scrambled and before the picture would come into complete view the TV power would shut itself off, but the power light would remain on. You can hear the "Click" noise when it would shut itself off.
2-3 seconds after it 'shut itself off' then the TV would make the "Click" noise (The same noise it makes when you first turn it on), it would make the "Click" noise over and over and over again but nothing would happen. So i would turn it off and on again and change the channel rapidly until after 2-3 minutes it would come into view and work.
So we decided to leave the TV on 24 hours a day. Then today we awoke and it was off and making the "clicking" noise over and over and over again but with no picture or sound. Now it wont even turn on/off it just sits there and goes "Click, Click Click Click" and doesn't do anything.
I described the problem as best as I can. Here is the TV information and specifications...
Philips 27 Inch Tube TV
Model Number... 27PT54 3S37A
Serial Number... 78438404
105 Watts
Date Code March 2003
Now that I typed the model number there are threads everywhere people saying the same issue exactly as me, I will read them but please someone tell me is there anything I can do...
Can anyone explain exactly what is wrong with the Tv and why it's doing this?
Also, what should I expect to pay to repair it?
Any information or help would be appreciated very much.
Thanks in advance,
Just got off the phone with certified Philips shop...they said they will repair it for $100-$130 with a $25 down payment just drop it off and he will call me when its done. Does this sound like its worth it or a rip off?
Sep 07, 2008 | Philips 27PT543S 27" TV
Phillips 30PW633R37A - Wont Turn on.
Hi Panix:
Sorry, but it sounds as if the power supply or high voltage circuit has failed. You will have to take it to a repair shop.
Feb 24, 2008 | Philips 32PT6441/37 32" TV
Power light blinks repeatedly on my Philips TP3284C
Defective Horizontal output, or Flyback shorted. Need to Check up.
Jan 20, 2008 | Philips TP3284C 32" TV
Power on and yet picture flicks and powers it's self off (over and over again)
First it's not just Philips, they all are making TV to only last a few years now, they are not made to last, thats how they make money by selling you something you will have to replace in just a few short years. As far as your problem, you may have a cold solder joint somewhere, do you have a 25/35 watt soldering iron? if so try soldering pins on the regulator IC the vertical IC the horz output transistor and drive transformer and the flyback, in fact solder just about as much as you can, spend some time in there soldering. Dont forget to ubplug the set and stay away from the high voltage anode connected to the picture tube, it can still hold a charge even if the set is unplugged, do not try to take it off. Hope this helps!
Sep 27, 2007 | Philips 27PT543S 27" TV
Phillips 30" Mod 30pw633r37a
I unplugged it for 24 hours. When I plugged it back in it was ok. It has done it a couple of times since, but only for a few seconds.
Sep 02, 2006 | Philips 32PW8608 32" TV
Philips 30PW633R 32" TV Logo
218 people viewed this question
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
