Question about Panasonic KX-FPG378 Fax
No ans greeting - Panasonic KX-FPG378 Fax
I want to delete an existing greeting message on the autoattendant. How do I do that?
Okay, it sounds like you're using a standard auto attendant greeting setup.
Try this:
Feature 983
Password: 1020000 (or whatever you have recorded for the password)
Select AA
Select Greeting
Select Greeting again
Enter 1 (for Greeting 1)
You can hit Play to ensure that you are listening to the correct greeting. If not, select another greeting by enter the number 2 for greeting.
Once you have found the greeting that you would like to erase, simply press record and let it record one or two seconds of silence. The greeting will be gone. Press OK to accept the new greeting (silence) and exit the system.
May 13, 2014 | NorStar Startalk Flash 2 Phone
How do I record a mailbox greeting on Avaya 1408?
Hi Tourmaster,
I have these steps for you on how to do it. Hope it helps.
Mailbox Greeting While the voicemail system will play a generic greeting to caller, prompting them to leave a message, you can record your own greeting.
1. Press the key%20messages.zoom50.png MESSAGES button. Depending on how your system is configured, you may be required to enter your voicemail password and then press the Done soft key. The visual voice menu is displayed.
2.Use the up and down arrow keys to scroll to the option Greeting.
2.Press the Select soft key or OK.
3. Use the soft keys to listen to and record your mailbox greeting.
Listen
Listen to the current greeting or the new greeting just recorded.
Record
Record a new greeting. Note that the greeting must be at least 3 seconds long or the voicemail system will discard it.
More
Switch between the different sets of available soft key functions.
Submit
Submit the new recording as your mailbox greeting.
Delete
Delete your current mailbox greeting. The voicemail will use its default greeting.
Apr 28, 2014 | Avaya 1408
Activate temporary greeting
What make and model answering system?
Dec 12, 2012 | Lands Phones
HOW DO I SET UP (RECORD) AN ANSWERING MESSAGE?
From the base, press and hold the GREET button until you hear the prompt. Record your greeting at the beep. Press the GREET button when done.
You can download the manual here.
Sep 23, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do I change Voice Mail on my phone?
Dial your extension. Wait for the greeting to say that you are at your voice mailbox. This is also the "Quick Voice Mail Tutorial Set Up."
Follow the instructions provided in the tutorial. You will be asked to enter your name (or company name), password and greeting. Write down the password and keep it in a safe place.
Record other greetings, if needed. After the tutorial, you have an option to add different messages for different situations. Press "311" to change your general greeting. Use "312" to record a message for when the line is busy. Dial "315" to record a temporary greeting for when you are away for an extended period of time, such as vacation. Good Luck
Dec 25, 2010 | Panasonic Lands Phones
Recording a Personalized Greeting
Press and hold greeting... it will ask for a new greeting... Record new greeting and then press greeting button again.
Feb 25, 2010 | Uniden 5.8GHz Cordless Phone
AVAYA PARTNER ACS PHONE SYSTEM - Voicemail/Greeting capability
Yes you can have the 2 lines answered by a particular mailbox instead of the AA greeting.
Would need to know the model of the voicemail system that is installed to see if there are more than 1 AA menus.
Oct 06, 2009 | Avaya Lands Phones
Callers are not prompted to general mailbox
Under greeting table 1 set your greeting attendant assignment as 100,that should send the caller to mbox 100 if they press 0 or make no selection at all
Sep 29, 2009 | NorStar M7310 Corded Phone
Nortstar M7324
In order to record an alternate greeting, you sign into your voicemail. Select Admin, Select Greet, Select Choose (and select which greeting you would like to use eg..Prime or Alt) Once you select the greeting. The voicemail is set to use that greeting. To record that greeting, go back into Admin, Select Greet, Select Rec, and record and save your greeting.
May 30, 2008 | NorStar M7324 Telephone
Panasonic KX-FPG378 Fax Logo
53 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
