Question about Garden
POWERMATE ELECTRIC PRESSURE WASHER MODEL CW 70-1200 REPAIR MANUAL
THE PROBLEM WITH IT WAS 85 PSI INLET PRESSURE. WHEN BOUGHT. SENT BACK TO GET REPAIRED, REGULATOR DID NOT WORK WHEN I GOT IT BACK. AFTER ALL THOSE YEARS I NEED IT REPAIRED. TAKING IT APART I THINK THAT THE RELIEF VALVE OF THE OUTLET HAS BEEN PUT IN IN BACKWARDS THE BALL IS AT THE TOP THE OUTLET OF THE PRESSURE, OTHER WISE WILL NEVER OPEN. I WOULD ALSO KNOW WHAT OIL LEVEL IT SHOULD HAVE AS IT HAS AN OIL INDICATOR. THANKS KIRK kirk.o@live.ca
  • 10 Answers
SOURCE: Oil leaking from pump
top is a breather you may be overfull of oil most pumps you can use engine oil .drain and put in half litre or if it has a sight glass top up to low side of glass and try it out.possible your seals on way out this usually then leaks at front or gets water in.if you still have good pressure oil seals easy to do.
Posted on Apr 21, 2009
  • 5 Answers
SOURCE: Need to lower 1750 psi to 300 psi on my portable power washer.
Don't starve the inlet to the pump. It will detroy it.
Buy a pressure regulating valve and plumb it in line per the instructions. Do not use a relief valve because you will have to have a return line or you will heat the water up on the inlet side of the pump depending on how the pressure washer is set up. It should already have a safety relief valve. You might look and also find a pressure regulator that is adjustable and all you problems will be solved.
Posted on Apr 25, 2009
  • 3 Answers
SOURCE: karcher k2400hh pressure washer, water pressure cuts out.
Hello cikanek:
Try this:
From your posting, I assume you have removed the splash cap and the nylon bypass valve cover. Connect the water supply to the pump and connect the high pressure hose and wand to the pump outlet. Wad up a small towel and place it over the bypass valve opening to catch the valve insert when it pops out. With the engine throttle closed, pull the starter cord several times to see it the valve insert will pop out. If it doesn't come out after two or three pulls, set the throttle to low and start the engine. I have performed this procedure a number of times and the valve insert always pops out. There is no real danger of the valve parts getting seriously airborn since the actual pump output volume is very low (2.5 Gal/min).
Good luck,
Ed
Posted on May 23, 2009
  • 174 Answers
SOURCE: Reconditioned B&S pressure washer will not restart
Some suggestions:
Is the gas old? If in doubt replace it.
Try removing the air filter and spraying carburetor cleaner into the carb Then try starting it. If it runs for just a minute, then stops, the carburetor needs cleaning.
Posted on Sep 20, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Very simple lost the owners manual. need to know
Simple answer: http://www.powermate.com/pdfs/2007/11/30/manual_pw0872401_pw0872500_pw0872700.pdf
That is your manual.
Posted on Feb 20, 2010
I need to know where to put detergent in the pressure washer I have no model number
These units come with a detergent bottle that attaches to the spray wand. The manual describes what detergents to use and the attachment reduces the pressure and siphons the right amount of detergent from the container. It is not a good idea to try to run detergent through the pump.
Here is a link to the operating manual for a similar pressure washer.
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/pw0501400.pdf.
Mar 05, 2015 | Coleman Powermate DuraBuilt 1400 PSI...
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
Need the manual
A model number would have been helpful; however this may be your manual:
http://www.powermate.com/pdfs/2007/11/10/manual_pw0501400.pdf
If the above is not your manual, check your unit for a model number and then review or search the list here:
http://www.powermate.com/productmanuals.php?cat_id=6
Jun 28, 2011 | Coleman Powermate DuraBuilt 1400 PSI...
Hi! Our gun trigger is not working right on Model
Lowes and home depot sell replacement guns for most smaller pressure washers.
Jul 29, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
I need a Coleman Back Max Pressure Washer manual. 3000 PSI 2.5 G/Min
If you have your model number.... go to this page find your model number and download the users manual AND the parts manual:
http://www.powermate.com/productmanuals.php?cat_id=3
Or you can contact them:
http://www.powermate.com/faq.php?cat_id=6&faq_id=88
How can I obtain a replacement operator's manual? If you misplaced your operator's manual, you can order a replacement copy by calling our toll-free hotline at (800) 445-1805. Be sure to have your model number handy, so we can send you the appropriate copy.
Thanks for choosing FixYa.
Kelly
Jun 23, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
No water coming out from powerwasher. Motor is running
check the filter at the inlet water pipe connection, a long nosed pliers may help to remove.
Aug 16, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Lance
Here is a link where you can look up your exact model and replacement parts from coleman...
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts
Looks like your model may be out of production though so here's a generic kit that will 99% work with your washer...
http://www.silverbin.com/FAIP-PowerWasher-Universal-Pressure-Washer-Gutter/A/B000EEQ9KM.htm
Hope that helps...
Feb 09, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
