Question about Nautilus Nr Recumbent Exercise Bike
NR 3000 Does anyone know where I can get a left pedal arm for my Nautilus NR 3000 recumbent bike? This is the part the pedal connects to. Nautilus does not make them anymore.
2 Suggested Answers
guru_fixya
  • 944 Answers
SOURCE: I installed a new motor
These manual will guide you more..
http://www.manualnguide.com/download/manual-guide/nautilus-nb-2000-upright-bike-assembly-manual.html
http://download.dfxi.com/supportdocs/OM/Nautilus/NLS_NBNR1k2k_OM_web.pdf
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 20, 2011
The electric display does not work on my stationary bike
It may sound daft.But giving the infomation in your question,Maybe try changing the batteries.
Oct 11, 2017 | Nautilus Nr Recumbent Exercise Bike
Looking for Biodex stationary bike model 950-120 parts
Ask Biodex, since this is a specialist medical product. They should be able to guide you to a spares supplier.
Alternatively try to figure out who manufactures the product, it will be subcontracted
http://www.biodex.com/support
Jun 26, 2014 | Biodex Semi Recumbent Cycle Physical...
Recumbant bike makes aclunking sound whe pedaled
follow this steps and fix it. God bless you
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess grease
Loose Pedals
Kneel next to the left side of the elliptical's base. Use the Phillips screwdriver to tighten the two screws located in the center of the left pedal.
Use the Allen wrench to remove the bolt securing the left pedal arm to the pedal leg and body arm. Use the Phillips screwdriver to remove the screw securing the rear end of the pedal leg to the crank arm.
Pull the end of the pedal leg free of the crank arm. Wipe the crank arm clean, then apply a fresh coating of machine grease or silicone lubricant. Replace the end of the pedal leg back onto the crank arm and use the previously removed screw to secure it back into place.
Join the front end of the left pedal arm to the ends of the pedal leg and body arm. Use the previously removed bolt to connect the pieces together.
5
Move to the right side of the elliptical and repeat the above steps on the right pedal arm
Dec 09, 2013 | Exercise & Fitness
C846 hard to pedal
follow this instruction. God bless you
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Jul 21, 2013 | Precor C846i Experience Series Commercial...
How do I remove the pedals on a 8500 life fitness recumbent bike
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Using a wrench, you remove the left pedal as you would loosen a normal, left hand threaded bolt. The right side is a reverse thread and would need to be loosened in the opposite direction.
Feb 20, 2013 | Life Fitness Nut Lock, Cranknut, Lifecycle...
Pedals are locked won't spin foward but will spin backward
see the following steps, and fix it. God bless you
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Nov 28, 2012 | Nautilus R514 Recumbent Bike
I have a NordicTrack SL710 recumbant bike that the pedals slip and make a clicking noise?
Prepareto oil by filling a grease gun with lithium grease. Check your owner's manualfor the exact type of grease for your unit.
Oct 31, 2011 | Nordic Track NordicTrack Treadmill, A2550
Recumbant bike slips while peddling
http://www.youtube.com/watch?v=mVJxs7ALxDM&feature=related
Loose Pedals 1
5
Move to the right side of the elliptical and repeat the above steps on the right pedal arm.
Oct 30, 2011 | Nordic Track NordicTrack Treadmill, A2550
The readout on my NR1000 does not work, I have repalced the battries.
Welcome to FixYa.
There are only two things that we can do to the readout/computer problem of the NR 1000.
1. Make sure that the batteries has power. 2. Turn it on then press and hold the reset button for 5 to 10 seconds.
If it does not resolve the problem, the device has a mechanical error and servicing it is the best way.
Thank you for using Fixya. Have a great day.
Jas247
Jul 12, 2011 | Nautilus Nr Recumbent Exercise Bike
Purchasing a 514 currently have a rt1000
514 is definite upgrade to Nr 1000 with walk thru feature and adjustable lumbar support instead of magnetic boot resistance it is using eddy current resistance.
May 03, 2010 | Nautilus Nr Recumbent Exercise Bike
Nautilus Nr Recumbent Exercise Bike Logo
76 people viewed this question
Top Nautilus Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Nautilus Cycling Expert? Answer questions, earn points and help others
