Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
I have a 450 series 148cc push lawn mower once it starts it runs for less than 10 minutes then cuts off, after a while it starts again, dont know what the problem is
Can you tell me what the possible problem is?
  • 7 Answers
SOURCE: Requires several times just to get started and
The most likely problem is the ignition module. It is probably going out. when a bad ignition module gets hot from use, it stops working, which kills the lawn mower since there is no spark. Once it cools off it sometimes works. This can be a some what costly part, $60 - $80. You might want to take it to a lawnmower repair shop and have them check it out, since there are other issues that could be the cause to your problem. If you have a spark tester, you could test the ignition module to see if you get spark, both before you start the mower, and after it quits on you.
Posted on Mar 10, 2009
  • 81 Answers
SOURCE: replacement of mower wheels
You have to pop the clips off the outside of the wheels. There may be a plastic over on each wheel that has to be removed first, but without a model number I'm not sure it your mower has them. If you don't break any of the clips they can be reused.
Posted on Jun 23, 2009
  • 29 Answers
SOURCE: I have a Murray 6.0 hp 20 inch push lawn mower. Ho...
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
Posted on Jun 04, 2010
SOURCE: my murray push lawn mower won't start
did it die right after a refueling? You might have water in your fuel can.
Which now is probably in your mower.
Drain out all the fuel *(remove the carb bowl too) Get some fresh gas *(dump your can of fuel out into a secondary container so you can look for water in it. If it has water on the bottom...you should dispose of it wherever you dispose of your mowers waste oil.
You should be sure you have spark. Which means you need to remove the spark plug from the head and with the boot still attached dangle it on the metal head and give it a pull and look for sparks. If you have no spark you might need a new plug or coil. Thats really all you can do for weak or no spark. Be sure the plug is clean and free of oil/gas contamination as that may have fouled the plug.
Good luck and be careful!
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: My lawn mower will start
There is a filter between the gas tank and the carb... pull that apart and get the dirt out...
heatman101
Posted on Aug 04, 2010
My mower is cutting out.
water or dirt in the carby bowl blocking the main jet
Apr 05, 2018 | Briggs Garden
Ihave a Briggs&Stratton 450 series 148cc push lawn mower it has seperate compartments for oil&petrol it ran out of oil 2day what type of oil do i need?
Hi SAE 30 in warmer temp ::::::: SAE 10W-30 in colder temperatures... also in temp below 5° C SAE 5W-30..... Cheers
Oct 25, 2016 | Garden
Why is my 450 series 148cc briggs and stratton lawn mower engine running fine and then when it gets hot it runs with no throttle
Keep an eye on the oil level, it could be sucking oil past the rings and burning it causing the engine to run a bit faster. it may also have a small vacuum leak at the carb or manifold tube, make sure the carb and manifold gaskets are not leaking air. All combustion air must pass through the carburetor exclusively.
Jul 28, 2014 | Briggs & Stratton Garden
Where can I find a Briggs & Stratton 450 series 148cc magneto?
best place is from a B&S mower shop. Try e-bay as well as they are available on line. may be you know some one who has a mower that is not going that you can get the unit from it.
Jun 17, 2013 | Garden
A 450 series 148cc on a victor, mower starts but runs rough(low engine rev and blows black smoke)
There has been a great deal of issues with the diapham between the carb and the tank, replace it and hopfully all will be well again.
Mar 10, 2013 | Briggs & Stratton Garden
What oil to use 148cc briggs & stratton 450 series
main jet clogged and use plain 30 weight oil in it not not 10w30
May 02, 2012 | Briggs & Stratton Briggs Stratton...
Requires several times just to get started and then runs fine for about 5-minutes and cuts then cuts out on its own. Then have to wait for about 10-15 minutes to start again but still requires several...
Mar 10, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
16 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
