Question about Dishwashers
Whirlpool dishwasher will not turn on MOdel # WDF530PLYB2 there is power to the unit but no indicator light or response??
localwonder
  • 6784 Answers
SOURCE: Maytag Dishwasher MDBH965AW will not power.
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replace
If the junction box checks out ok, the wall outlet socket is live, replace the main control or timer module.
Posted on Jun 19, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool dishwasher won't turn on. There is
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
If everything stated above is ok, this will lead to a failed control sector. The control sector can be a timer module, or control board assembly.replaced the control sector if all above is ok.
Posted on Nov 06, 2009
rickead1
  • 1998 Answers
SOURCE: Maytag MDBtt60awb
most likely you have a bad motor when replacing the motor ihave found it is cheaper to get the pump with the motor attached where as they charge you more money for just the motor or the pump seprately try allbrands appliance parts they seem to be cheaper
Posted on Apr 30, 2010
  • 949 Answers
SOURCE: Whirlpool DU1055XTSS dishwasher is totally dead as
If you have power going to the dishwasher, meaning the breaker, switches, wiring and fuses in the home are okay, the most common cause for your symptoms is the thermal fuse.
The thermal fuse is a small disk shaped device that is behind the control panel on the right side it is snapped on to the electronic module. The part number for your model is W10258275
Posted on Jul 24, 2010
  • 1531 Answers
SOURCE: I have a Frigidaire Gallery dishwasher model
you need to rpelace the electronic control board
Posted on Oct 23, 2010
Whirlpool integrated dishwasher model ADG 7460 Have run the engineer test cycle and it stops and drains water after 2 mins; start light blinks 5 times.
F5 or 5 times flashing.
Variable speed motor failure.
Reason:
- Connection between Spray pump (Variable speed motor) and control board interrupted.
- Frequency converteron Spray pump broken or control board defective.
= Check the power voltage on the motor. BUS: 5V DC, Motor: 230V AC
Reaction: Cycle stops, drain pump drains out,failure indication.
OR
SPM blocked (MPH motor unit)
Failure condition:
- This failure is only indicated during the active test program
- The electronic detects an irregular deviation of the motor current consumption.
Reason:
Spray pump blocked = check pump housing
Short circuit in motor or wiring = check motor values
Reaction: After 5 attempts to reactivate the spray pump motor the cycle stops, drain pump drains out, failure indication.
Dado
Sep 03, 2015 | Whirlpool Dishwashers
Cancel light blinking
this normally indicates an error code, what is the make and model number? also which lights are flashing?
Oct 02, 2014 | Whirlpool Gold Dishwasher with Quiet...
No indicator lights Whirlpool wdt710paym dishwasher
If it doesn't run and you have no indicator lights, check the circuit breaker for that outlet. If it is ok, test the output voltage at the plug-in for the machine (115Vac). If it is "live" then check inside the control panel (turn off the breaker first) for a fuse that appears blown. If no fuse problem, CAREFULLY (with breaker back on) see if the main switch is getting power. If it is getting power, the control board is shot...replace it!
Dec 28, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Won't turn on
unit will only run on cancel cycle
Jan 29, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
Lock light is on will not go off. nothing will work
Hold the Air Dry button until the light goes off. or Press and hold the "Heated Dry" button for approximately 4 seconds. The control lock indicator light under the padlock symbol will turn off when the controls are unlocked.But if that is not helping then its faulty control panel.It has to be replaced.Unplug the unit from power outlet for 10 minutes then reconnect and check,if lock light turns off.----------------- Thank you.
Jan 24, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool DU1055XTSS dishwasher is totally dead as if it were unplugged. No response from front lights. Only 3 years old. Another post for an different Whirlpool model says it's the thermal fuse, but I...
Jul 24, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Dishwasher won't start and control buttons don't do anything.
It would have helped if you provide the Dishwasher model.
HOwever, I am assuming you have the power connected and inlet water is turned on.
It is likely the child control button might be enabled. CHeck dishwasher manual to show how to disable child lock.
If this is not the problem, then assuming your dishwasher has this feature, try to hard reset the dishwasher to factory setting. This is usually done by pressing 2 buttons (depending on dishwasher) together for a specific time. Or in some cases the mains power is turned off and on within a specific time.
Please post a comment to indicate your observations and model no. Please do not rate this solution until I have got some more details of your dishwasher problem.
Jan 17, 2010 | GE Dishwashers
I have a Whirlpool Quiet Partner dishwasher that stopped working
that is a typical indication of a faulty board. once replaced, i suggest a surge plug to be installed. it will protect the unit from future power fluctuations.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Model # DU1055XTPQ3 WHIRPOOL DISHWASHER RESET CODE
chris72 had the solution to my Whirlpool DU1055XTPQ3 not turning on. Per Chris's suggestion, I pressed back and forth between sani rinse and heated dry. All the lights came on as it reset and it was good to go. The dishwasher started up immediately. Saved me a service call, THANK YOU Chris!!
Aug 07, 2008 | Whirlpool 24 in. DU920PW Built-In...
'Dead' DU1100XTP
have you checked the door switch? it controls the power to the dishwasher so it won't run while open. that is a common issue with all dishwashers.the door switch runs to the motor controlling the power...good luck
Sep 25, 2007 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
