Question about Boating
Bilge drain plug location,2003 185 bayliner - Boating
2 Suggested Answers
  • 5687 Answers
SOURCE: 1991 bayliner capri wiring schematics/ owners manual?
West Marine has a lot of compatible aftermarket parts. The wiring diagram for that boat will be hard to come by. If you buy a signal tracer at Lowes or Home Depot, you should be able to backtrace the power source from one of the wiring leads where the old connectors plugged in.
A place around Detroit, called "HELM" publishing can sometimes supply new books for a very high fee. Fortunately Bayliner is still in business and may be able to help you. Just do some web browsing for there contact info.
Posted on Aug 25, 2012
Where is the bilge drain plug located on a 2002 glassport 17" boat
usually in the transom area middle of boat
May 06, 2018 | Boating
A.c. condencingg drain line location
Well if you're talking to a refrigerator that line goes in the bottom into a trip tray which stays warm and evaporates that moisture.
If you're talking about a home or house air conditioning unit that needs to go into bucket or a bilge pump which drains that water outside or into a nearby drain
The problem is you put this under refrigerators or appliances but I think you might be talking about an air conditioning what should be question in a different area than here
Mar 27, 2018 | Refrigerators
How to drain remote control bass boat only used 15 min. ran good until water got in the hull don't know how to drain it
Install a bilges pump maybe??
Look if there is no plug installed at the lower edge of the transom.
May 30, 2017 | Boating
How to replace the bilge pump on a 1988 Bayliner
Turn off the power to the pump. access the pump and disconnect the mounting bracket then the hose and electrical wires will be much easier to remove .Be sure to mark the wires. Installation is the reverse of the removal steps. Its a very simple job half hour, not including cleaning time in the bilge if necessary. Hope this helps Mike
Oct 04, 2014 | Boating
My bayliner 2455 1988 model leaks in the front of the boat.
Could be a broken bilge pump. You can find some answers on the boating forum.
http://forums.iboats.com/bayliner-boats-37/?boatid=29
If the bilge pump is bad, you can find some on iboats.com
http://www.iboats.com/Bilge-Pumps/dm/view_id.217442
Mar 18, 2013 | Boating
Where is the bilge pump located/how to access
The Star Craft 190 has an automatic bilge pump located on the lower side of the boat. ------------------------------------------------------------------------------------
Original Launch X431 Master
Mar 12, 2013 | Cars & Trucks
Jet boat SL2000 bilge pump location how to access it
the tray that houses the cleanout plugs needs to be removed and pry'd up. thr pump is straight down from there.
Sep 08, 2012 | Rule Mate Fully Automated Bilge Pumps...
Aug 25, 2012 | Cars & Trucks
Wheres my bilge pump
It's located in the rear compartment centered on the bottom of the boat in front of the transom.
Jun 22, 2012 | Nitro Collectable Fishing Boat...
Need to change steering unit 1987 Bayliner cuddy
I have a 1988 Bayliner with Power Steering. If you are asking about removing the steering parts on the transom, they are just like a Rack and Pinion.
You want to turn the steering to shorten the rod and drive it back into the case. Then you will unbolt the case from the transom and the motor.
The hydraulic hoses are another challenge. You want to remove as much fluid from the steering pump as possible. Leave the fluid coolers alone and just uncouple the hoses at the steering case on the transom.
You want to BE PREPARED to cap the ends of the hoses and raise them as high upwards as you can keep them.
The steering case will then drop fluid. In an ideal situation you would have plugs to close the holes the hoses are removed from. A bucket to catch the fluid and plenty of rags to keep the fluid out of the bilge is about all you can do. You may get lucky and be able to wrap plastic wrap around the steering case to seal off the leaks.
You reinstall and then bleed the air out of the system by steering lock to lock a few times.
Mar 29, 2010 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
