Question about Coleman York Dgat Gas Furnace Flame Sensor Rod 2702-311 2702-211p Pse-ec3 19663
DGAT070BDD control board wiring diagram
I need to know what wires my new control board. I need to see a picture or the color codes for the wire to place in the right place
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Posted on Aug 16, 2008
james3751
  • 614 Answers
SOURCE: trying to figure where all the wires connect on a/c contacter?
The two wires coming from your inside unit. They are the low voltage wires go on either side of the contactor coil. You should not have two blues on one side. see if the black wire comes from inside unit. Rus
Posted on Jun 25, 2009
heatman101
  • 43501 Answers
SOURCE: coleman mach3 wireing diagram diagram
Hi, Yes, but you need to know which wires do not need to be hooked up...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
motor1258
  • 6674 Answers
SOURCE: bought a used coleman 15,000 btu with heat
You'll need the ceiling assembly and control box to operate it properly, or at the very least a ceiling assembly with mechanical controls. The ceiling assembly is where you will run your 110 volt, and depending on what set-up you choose, the wiring etc, relays and transformers will be determined by that. I assume you didn't get the ceiling assembly with it? Here's a link to wiring diagrams etc and service manuals to help you understand what and where to go with it. Model number should be on it, just go to proper info pertaining to your model.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Posted on Jun 21, 2011
motor1258
  • 6674 Answers
SOURCE: The control module is missing from my Model
Check here: http://www.rvcomfort.com/rvp/tech_info/wiring.php
Posted on Aug 19, 2011
Coleman Evcon DGAT070BDD furnace fan continues to cycle on & off after temp is reached blowing cold air. Replaced control board & limit switch - problem continues
If its turn on AND off, I'd suspect a shorted control wire. Remove the G terminal at the control board and see if the problem continues. If it does not, then you know it's in the wire that connects your unit to the tstat, or the tstat itself. The reconnect G, and at your tstat, disconnect G. If the problem goes away, with G disconnected at tstat, its the tstat. If it continues, the the control wire has a short between G and R. If neither one of these work, then there's something else in that unit that's causing 24v power to engage G. Hope this helps!
Mar 09, 2017 | Coleman Heating & Cooling
Does anybody know where I can find a color coded wiring diagram for a 1983 Ford F-100 or 150?
Try a library for a repair manual. That may not help, pretty hard to find fuse block wiring off a diagram. Find this truck at a salvage yard, take the fuse block off with wires cut way back so you can see color of the wires.
Apr 01, 2016 | 1983 Ford F150
De 407 maytag dryer how do i find a wiring diagram
the Maytag dryers would have the diagram either INSIDE the control panel, OR on the back of the control panel. Neither are color coded as there never was a color coded diagram ever printed. The diagrams do list the color of wires and show where they start and terminate. That is all a service tech would require to troubleshoot. If the diagram has been removed, you could try an online search.
Jul 03, 2014 | Frigidaire GLER341A Electric Dryer
I have a set of hand controls for a 95-06 Harley with no diagram how Do I figure out witch wire from the switches go were
If you're simply replacing the controls with other controls, the color coding of the wires should be the same. Simply unplug the old wire from the plug and insert the same color wire from the new set. Now, if you're trying to install a later set of switches on an earlier model bike, you need a wiring diagram of BOTH the new switches and the old bike so you can figure out the color codes on the wires.
Good Luck
Steve
Mar 02, 2011 | Harley Davidson XL 1200 C Sportster Custom...
There are a few wires off underneath the game table. Score board is not working, need wiring diagram from the battery holder, to the on -off buttons & to the scorebord. The whole wiring diagram from...
To be precise, your question was asked two days back and none of the experts are answering your question just because you have not provided the complete problem. Kindly let me know the color of the wires on your battery holder and the color code on the on off button and to the score board. We experts don't have wiring diagram for each and every equipment but we do have color code system.
Jan 22, 2011 | Carrom Super Stick Table Hockey Game
Best Buy installed a new cd player in my 03 Tiburon GT. All of my instrument cluster lights no longer work. The fuse is ok. Anyone know the wiring color codes. Best Buy is unco-operative and want me to...
Is fuse 29 the one you say is good? If that fuse is good, check your tail lights. If the tail lights are not working either, check the TAIL LAMP fuse in the engine compartment relay box.
There are 2 different wiring diagrams depending on if you have the amplifier or not. If you have only the basic radio, it would not have the amp. If you have a premium option, it would have the amp.
There is also another wiring color code I got from another website that's different--more like the standard colors. I'm going to include that color code as well in case you find the colors don't match the diagrams.
In the diagrams, there are actually 2 wires that run the light on the radio. One is green and one is brown with a white stripe. An aftermarket CD player will probably not have any wires for the light and just have it come on when the radio is on--day or night. So, if they connected those factory wires anywhere, that may be your problem.
I have pasted all of the relevant wiring diagrams below, though they may be hard to read because of picture size policies at FixYa. Please let me know if you have more questions.
Possible alternate color scheme:
Radio Constant Wire 12V+: Red
Radio Ignition Switched Wire 12V+: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Pink/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Factory Amplifier Turn On Wire: n/a
Left Front Speaker Wire (+): White
Left Front Speaker Wire (-): Brown
Right Front Speaker Wire (+): Black
Right Front Speaker Wire (-): Yellow
Left Rear Speaker Wire (+): Blue
Left Rear Speaker Wire (-): Red
Right Rear Speaker Wire (+): Green
Right Rear Speaker Wire (-): Orange
Nov 09, 2010 | 2003 Hyundai Tiburon
How do I replace the thermstor
first you need the diagram.... its located behind the timer// .control pannel ....get the diagram look at it ....look for thermister.in diagram .....look at the color code on diagram to find the part .....the wires are marked on diagram in color ...so if the diagram says thermister... wire.. in is blue //wire out.. is white.. look for
them color wires to find the thermister.... thats the only way i know ...let me know ..an good luck //joe// 25 years exp
Aug 31, 2010 | Kenmore Dryers
Intec ps-2 7005-c controller
Try clicking here first. If that can't help, I would try going to sony and RMA the controller, which means you send them your controller, and then they'll send you a brand new one for free. But they may charge S and H. I couldn't find any circuit board diagrams. Sorry about that. Well, Good Luck. Please rate my solution.
Jan 08, 2008 | Sony PS2 Dual Shock 2 Controller...
PS2 Controller Wiring Diagram
heres the diagram
http://www.curiousinventor.com/guides/ps2
Dec 09, 2007 | Sony PS2 Dual Shock 2 Controller...
Coleman York Dgat Gas Furnace Flame Sensor Rod 2702-311 2702-211p Pse-ec3 19663 Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
