Question about Frigidaire Dryers
Frigidaire Affinity Dryer Model LAQE7077KW0 No Heat
The dryer works but has no heat. I followed the test sequence and the dryer says the temp inside is 71. Would it be the element, the thermostat or thermistor. How can i check
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: My Frigidaire Affinity Dryer won't heat up element good just replaced the thermistor and also the fuse only thing left to replace is the Thermal High Limit... but tested that and it was good any t
Are you sure you have 240V going to the dryer?
Posted on Nov 06, 2012
Fridarire affinity FAQE7001LW dryers runs no heat
Good Morning Friend,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is running but there is no heat. Before calling a technician, check the following solutions:
    1)Make sure that the two house fuses your dryer is attached to. If one of the two fuses is blown, the drum may turn but you won't receive any heat.
    2)For Gas Models Only: Make sure the gas supply valve is open, make sure there is enough air supply to support the burner flame, and make sure the LP gas supply tank is not empty or there has been a utility interruption of the natural gas.
    3)Check the lint filter, the ducting that leads outside, as well as the outside vent for any lint that might be clogged inside. This can cause a no heat issue, due to your dyer is not getting a good air flow.
    4)For Electric Dryers Only: Make sure your dryer is connected to a 208 volt circuit.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
May 29, 2014 | Frigidaire FAQE7001LW Dryer
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Affinity aeq7000eg0 no heat stops after 20 minutes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 01, 2011 | Frigidaire Affinity AEQ6000WH Dryer
My frigidaire affinity dryer works but does not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 06, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My frigidaire affinity dryer is not heating up but still works what is wrong?
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer not heating frigidaire affinity front loader
heatman101
fgssggs
Feb 22, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
Sep 06, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire affinity dryer problem
message "ad" showing on my affinity frigidaire, anything wrong with this?
Apr 01, 2008 | Dryers
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
