Question about Hardware & Accessories
How do I set the times on my timer switch hager eh010 switch timer
SOURCE: i have a hager eh
Here's the EH135 manual
http://waterheatertimer.org/Hagar135-manual.PDF
EH135 is 240V SPST timer with NO normally open pole and NC normally closed pole. Clock motor is 240V. Manual override located lower right of dial.
Tabs on dial push down and out. The manual seems to illustrate the following: tabs are down and out, timer is off and NC poles 5-6 are connected. When tabs are up, timer turns on and NO poles 5-4 are connected.
Posted on Sep 24, 2010
SOURCE: How do I set my
Resourceful do-it-yourselfer will find following information helpful for solving problem.
Max Load 1000Watts incandescent
http://waterheatertimer.org/How-to-program-Hagar-timer.html#700-series
Manual uses several languages including English
http://waterheatertimer.org/pdf/Hager-EH711-Timer.pdf
Hagar 700 series analog timer has mechanical dial that rotates as time passes.
Segments located on outer edge of dial are moved down-and-out, or up-and-inward to set on-off times.
As dial rotates, segments move lever that turns Load on-off.
With segment timers, all consecutive segments between on and off times have to be pushed in place.
Since EH700 series timer has NO NC terminals, segment position is determined by how timer was wired.
This is because segments-in and segments-out turn different terminals ON.
As a result, the best way to set this timer is to push 10 consecutive segments down-and-out.
Leave rest of segments up-and-inward.
Then manually rotate timer dial to watch when Load turns on-off.
Hagar analog timers also have a switch located in bottom right.
This is the manual override switch.
Set switch in position "I" and then rotate timer dial to watch when Load turns of-off.
Set switch in position "O" and then rotate timer dial again to watch when Load turns of-off.
Manually rotating dial and experimenting with segments and switch will tell resourceful do-it-yourselfer exactly how to set timer.
Once segments and switch are set, then rotate timer hands until current time shows on analog dial face.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 18, 2011
SOURCE: I have a Hager (leGrand)
Posted on Apr 27, 2011
SOURCE: Hager ES220 cant get the
I am not familiar with that specific model number, but Hagar timers have more than one number since sellers apply their own numbers so their product appears unique.
I suggest contact Hagar:
http://controls.hager.com/index.php?scr=800&id=1462
Open following link for Hagar timer resources:
http://waterheatertimer.org/Hagar-timers-and-manuals.html
Hager ES220 does not show in the timer catalog:
http://waterheatertimer.org/pdf/Hagar-timeSwitches.pdf
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
Posted on Jun 05, 2011
SOURCE: How to set Hager timer
Hagar EH711 is surface-mount analog timer with segments located around timer dial.
Timer has 2-position slide switch with I and O.
Timer has NO and NC wiring terminals, and I O switch reverses terminals.
Timer dial can be rotated by moving minute hand clockwise with finger
Open following link for instructions that illustrate how to set analog timers by experimenting with features.
http://waterheatertimer.org/How-to-set-timers.html
Open following link to see Hagar analog and digital timers with illustrations and manuals:
http://waterheatertimer.org/Hagar-timers-and-manuals.html#700-series
Take a moment and rate answer:
Posted on Sep 07, 2011
How do you set a hager eh010 timer
switch the timer off or disconnect
turn the thermostat setting to low
that way it will not work when the solar section is producing enough hot water and when the temperature in the hot water system falls below the thermostat setting it will switch on the power
usable hot water temperature is around 60 degrees c and anything over that will scald the skin within minutes
low thermostat setting is 55 -65 degrees c
Aug 06, 2016 | Solar Hardware & Accessories
How to set Hager eg010 timer
how to set hager timer eg010
Dec 09, 2015 | Hardware & Accessories
How can i connect a hager EH010 timer switch for DOL startor. the startor is using for 7.5 HP motor
Hello sajikumar
Following links have wiring illustrations:
http://waterheatertimer.org/How-to-program-Hagar-timer.html#wire
http://waterheatertimer.org/images/EH-010-timer-wiring2.jpg
http://waterheatertimer.org/images/EH-010-timer-wiring.jpg
http://waterheatertimer.org/How-to-install-3-phase-timer.html
The EH 010 timer has max amp rating 16 amp max.
This timer is connected to 12-14 gauge wire
Ordinary 3-phase 7.5 Hp motor draws 22 amps at 230volt and probably connected to 30-40 amp breaker and size 10-6 wire.
Timer and wire to timer must be fuse-protected, and cannot be directly connected to 30-40 amp line.
Add comment for more assistance.
Apr 18, 2013 | Hardware & Accessories
How can I set the time on my hager ES420
Hagar ES420 is 230Volt, 20 amp 4-NO contactor.
Hagar timers: Copy following link to identify Hagar digital timer. Scroll down and view each timer until correct one shows. Then download manual.
Copy following link to see general image of Hagar timer system.
http://waterheatertimer.org/images/Hagar-timer-fuseholde-relay.jpg
On left is a fuseholder.
In middle is timer.
On right is the contactor (or relay depending on model).
Oct 24, 2012 | Hardware & Accessories
Operating instructions for a digital timer Hager EG 203E
i set up the hager eg203 time clock i have the times correct but i can not seem to over ride it, meaning to switch the load on and off manually by passing the times, can enybody help, a big thank you if you can my mail is
mcglynncathal@yahoo.ie
Apr 29, 2012 | Hardware & Accessories
How to set Hager timer EH 711 from 7pm to 11pm
Sep 07, 2011 | Hardware & Accessories
Hager ES220 cant get the timer to work how do i set it i do not have any guidelines where can i get the information from ?
Upvote the help.
Jun 05, 2011 | Hardware & Accessories
How do I set my Hager timer EH711 to on at 7pm and off at 7am
Mar 17, 2011 | Hardware & Accessories
I have a hager eh 110 time switch on my pool and I cant set it. Any clues?
Hagar EH 10 is 230V analog time switch.
EH010 is 1" wide.
1) See large image of EH010
http://www.bewdirect.co.uk/home/m/Shop/id/3985/page/1/
2) See large image that explains how to set EH-010
http://waterheatertimer.org/images/EH-010-image-1000.jpg
3) With analog timers, there is a movable dial that rotates with fingers.
Pins or segments are located around edge of dial.
Segments are moved one direction or the other to set on-off times.
After segments are set, the dial is rotated to match current time.
The dial rotates as time passes, and segments move a switch that opens and closes electric circuit.
4) EH-010 is different.
Usually analog dial is located on face of timer like a clock face.
However EH-010 is only 1" wide, so dial is perpendicular to front of timer and is rotated with thumb.
5) I suggest setting a few segments one direction or the other and then manually rotate dial full circle to watch when pool equipment turns on-off.
This will tell you if segments should be set right or left.
I have not seen this particular timer, but it appears as if times on printed on edge of timer dial.
6) Timer has 240V clock motor.
So Hot line wires from circuit breaker connect to terminals 1 and 2.
This powers clock motor so dial rotates as time passes.
240V Line and 240V Load wires are connected as shown in image below:
Feb 10, 2011 | Electrical Supplies
Hardware & Accessories Logo
562 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
