Question about 2-Way Car Alarm System w/ Remote Start
Icbm 7071 i need the wire schematic for 2012 corolla windows door locks and ignition and would like some help with the kill switch relay why is there 2 greens?
5 Suggested Answers
  • 207 Answers
SOURCE: lost the manual to program performance teknique
there should be a help line number on the product or the box or a website go to the m they can walk u thru it or google instructions for performance technique car alarm
Posted on Feb 24, 2010
SOURCE: I need a manual for Performance Teknique Icbm-7071
como puedo optener el manual de instalasion
Posted on Mar 31, 2011
  • 33 Answers
SOURCE: i have a Performance Teknique
The alarm shouldn't require any programming to function.
Posted on Apr 13, 2011
  • 24 Answers
SOURCE: Do i need a bypass module in installing performance teknique 2 way alarm system w/ remote in my 2008 mazda 3
Yes, to do a remote start properly, a bypass module will be needed. The less expensive ones will require you to lose a key. The better one will program to your car using 2 existing working keys. Many online retailers sell them. Look for Fortin, Idatalink, etc.
Posted on Feb 20, 2013
I can't find the fuse for the power windows on a 1998 Lincoln Navigator
All the other windows work ? Not a fuse , one fuse powers all the windows . Test for B+ voltage at the switch an the window regulator would be the proper diagnostic procedure . Do you own a volt meter ? know how to read a wiring diagram ? how to do basic automotive electrical testing . The Faint click you hear is probably a relay , which means the GEM - genaric electronic modual is energizing the window relay . The windows are computer controlled .
The GEM will activate the OTD Relay until one of the following conditions is met:
  • The LF regulator control switch is pushed to the UP position.
  • The LF regulator control switch is released (OFF position) and then moved to the down position (first detent) or one touch down (OTD) position (second detent).
  • Seven seconds have elapsed since the OTD was initiated.
  • A window regulator electric drive stall condition is detected on the one touch down sense line inputs.
The UP window operation is not controlled by the GEM. The feature is activated when the delayed accessory is active and the LF window regulator control switch is pressed to the UP position. The switch provides delayed accessory power to one side of the motor and ground to the other side through the one touch down relay. The one touch down relay is not active when the LF regulator control switch is in the UP position.
Passenger windows may be raised or lowered using the LF master control switches or the appropriate passenger window switch. Passenger window switches receive power when the delayed accessory relay is active and the LF remote lock-out switch is in the UNLOCK position. When in the LOCK-OUT position, the passenger windows are deactivated.
The GEM controls manual down and auto down window movement with the down window relay. The relay is activated by applying ground directly to one side of the down window relay coil, and deactivated by removing the ground signal.
The delayed accessory relay provides power for the operation of the power windows and the power moon roof. The delayed accessory feature is active when the ignition switch is in the RUN or the ACC position, or when the ignition switch is changed from RUN or ACC to the OFF/LOCK position and the LF and RF doors are closed.
The GEM will deactivate the delayed accessory feature when:
  • the LF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • the RF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • 10 minutes have elapsed since the ignition switch was changed from ACC or RUN to the OFF/LOCK position.
Feature inputs:
  • LF door open warning switch (open circuit with door closed, grounded with door ajar).
  • RF door open warning switch (open circuit with door closed, grounded with door ajar).
  • Ignition switch RUN position (battery potential on both the RUN and RUN/ACC inputs).
  • Ignition switch ACC position (battery potential on the RUN/ACC input).
  • Ignition switch OFF/LOCK position (absence of battery potential on the RUN, RUN/ACC, and START inputs).
The Trainer 24 Power Window Troubleshooting
Mar 03, 2017 | 1998 Lincoln Navigator
Aside from Driver Window Switch, where can I find a RAP-OFF wire Gray/Black in a 2012 Equinox?
Each door ajar switch sends a signal. The signal goes through the window switch for that door, probably be easiest to access the ajar signal wire at the window switch connector on any door.
Nov 02, 2015 | 2012 Chevrolet Equinox LS 4dr SUV 2.4L...
Box fuse picture
old post, and I feel your pain or others land here.
yes, The IMMO(alarm) on the car can kill the engine dead
some cut fuel, others cut cranking.
The 96 prizm/corolla. is what it is.
early cars were (daffy) and easy to hack ,done most.
if the immo lamp stick on what to do. lacking new alarm programming or repairs to same. how to HACK.
hack IMMO 101:
the answer can very by make of car and year, newer cars are impossible.
do not confuse words writting about 1991 car , on a 96
they are worlds apart(evolution, and LAWS)
your alarm box is called.
doors and locks and theft deterrent.
as expected its got a zillion pins, (big job it has)
but only 1 pin matters, (hacking mind set) pin A1 SRLY
im no genius, im just and electronics tech, retire. and can read this print , here at mitchells so can you.
the print shows that pin as P, my guess for Purple wire.
next is the starter pages.
it shows, what? it goes to the starter relay coil
and the non alarm car wire ground there is missing
so there is your fix, ground the purple wire there
or at pin 2 of relay start, ground that.
now the starter cranks forever, no matter what , deity willing.
The AM1 fuse kills the live relay power.
or pull battery neg lug, and all is off line, 0volts.
The GIG+DOME+HORN fuse kills dead the alarm box
or
pull the AM2 or the power fuel.
so will the 100 amp ALT fuse.
all this in the book , the schematic, all that.
just ground the P wire. end story
watch out for door locks, keep windows open , killing this alarm box. as it runs all door lock motor......... !!!
Apr 06, 2014 | 1996 Geo Prizm
2012 toyota corolla headlights stay on after I leave the car
sorry but it doesn't work like that.. there are ways but its after market solutions.. 1 way is to have a mechanic remove the main Power wire from the head light relay and attach it to another relay that uses your ignition wire as a switch.. All the solutions are HACK mods that's your local mechanic will know.. There are devices you can but but its expensive. and all the solutions will void your warranty.
Dec 30, 2012 | 2012 Toyota Corolla LE 4-Speed AT
2010 corolla key stuck in ignition
It can be faulty ignition lock cylinder.I suggest to wiggle the steering wheel a bit and see if the key gets released out.If that is not helping then first turn steering wheel to right and try removing the key,or next turn steering wheel to left and see if you can remove the key.
Spray wd-40 in the ignition key hole and let it remain there for few minutes,after that once again try to remove the key and see if that helps.
But if that is not helping then ignition lock cylinder has to be removed out and key has to be manually removed.
For more troubleshooting on these types of issues,i suggest you to refer the help links mentioned below.Its the accurate solutions mentioned in it.that will help you to narrow the problem:-----
Click the link below:------
1999 Toyota Camry: Key Will Not Come Out Of Ignition?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-key-will-not-come-out.html
2001 Toyota Tacoma: Ignition Locked?
http://technoanswers.blogspot.in/2012/04/2001-toyota-tacoma-ignition-locked.html
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
Car will not turn the ignition to start?
http://technoanswers.blogspot.com/2012/01/car-will-not-turn-ignition-to-start.html
Ignition Key OFF but engine still running?
http://howtobyme.blogspot.in/2012/03/ignition-key-off-but-engine-still.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
2012 Dodge Ram: Ignition Key will not release?
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html-----------
Ignition locked up on Mercury Villager?
http://technoanswers.blogspot.in/2012/01/ignition-locked-up-on-mercury-villager.html-------------
Key won't turn in the ignition on Toyota land cruiser?
http://technoanswers.blogspot.in/2012/02/key-wont-turn-in-ignition-on-toyota.html
How to remove ignition switch on VW Car models?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-ignition-switch-on-vw-car.html
How to Replace Ignition Switch on Chevrolet Caprice Classic?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-ignition-switch-on.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Problem Troubleshooting
http://whoisbyme.blogspot.in/2012/07/ignition-problem-troubleshooting.html
------------------These will help.Thanks.
Nov 28, 2012 | 2010 Toyota Corolla
2000chrysler 300m doors not locking by switchs only by key how do fix
As per this problem,there are help links provided to troubleshoot the exact cause of problem.Click the link below to go through the procedure :----Diagnosis & Testing Power Windows? http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html----------
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
------------Car windows will go down but come right back up
http://schematicsdiagram.blogspot.com/2011/06/car-windows-will-go-down-but-come-right.html
Electric Window Motor REMOVAL and INSTALLATION ?
http://schematicsdiagram.blogspot.com/2011/06/electric-window-motor-removal-and.html
Driver side power window wont go up on ford expedition?
http://howtobyme.blogspot.com/2011/10/driver-side-power-window-wont-go-up-on.html
How to replace window motor and regulator on jaguar S-Type?
http://howtobyme.blogspot.com/2011/09/how-to-replace-window-motor-and.html
How to remove window motor and regulator?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
power locks, power window and power mirror on the passenger side not working ?
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
-----------Power windows works intermittently? http://schematicsdiagram.blogspot.com/2011/12/power-windows-works-intermittently.html
--------Power window fuse location? http://schematicsdiagram.blogspot.com/2012/01/power-window-fuse-location-for.html
----------Power windows will not go up and relay clicks when switch is pressed? http://technoanswers.blogspot.com/2012/01/power-windows-will-not-go-up-and-relay.html
----------Keyless keypad on drivers door stopped working?
http://technoanswers.blogspot.com/2012/01/after-alternator-failure-keyless-keypad.html
Remote will not unlock Rear door ?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door locks not working on?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
----------Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks? http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
--------This will help.Thanks.
Feb 17, 2012 | Chrysler 300M Cars & Trucks
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 29, 2009 | 1994 Toyota Pickup
'86 corolla relay switch- how much and where can i get one?
there is not such a thing as ignition relay sw.send me an email to daddykouki@gmail.com. I can help you,i am an electromecanic with specialty in 1984/1987 corollas. If you send a tel. no. I can call you.
Mar 03, 2009 | 1986 Toyota Corolla 2 Door
05 corolla oem power door locks and windows install
All of the power locks and power windows are directly ties into the "Integration Relay". This is the large white box behind the fuse panel under the dash. There are 2 different Integration relays, one with electric windows, and one without them. You may need to change the integration relay, also.
Feb 24, 2009 | 2005 Toyota Corolla
Icbm-7071 performance teknique alarm remote starter wont work
what type of vehicle and year is it in? Also, most remote start alarms have a neutral safety wire that needs to be grounded and a hood-pin wire that needs to be connected. If the start system was working and has since failed, it is pointing at the hood-pin wire. If it never started remotely, then you may look to the programming on the alarm. Make sure that the tachometer wire is connected and that the tach setting has been programmed. This should take care of it. If not, I would recommend visiting a local stereo shop to have them diagnose what is wrong with the system.
Aug 09, 2008 | Car Audio & Video
2-Way Car Alarm System w/ Remote Start Logo
21 people viewed this question
Top Performance Teknique Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Performance Teknique Vehicle Part and Accessory Expert? Answer questions, earn points and help others
