Question about Fujitsu LifeBook A6010 Notebook
Bootable device was not found - Fujitsu LifeBook A6010 Notebook
What dose no bootable device--please restart
no hard drive,dvd,cd or usb "bootable devices" have been found by the bios and booting to an operating system can not proceed
Aug 30, 2014 | Computers & Internet
What do you do if no bootable device is found
When your pc starts as no bootable device that means it either can't see the hard drive or it's trying to start from the dvd or floppy? Do you know how to get into the bios menu?
Aug 23, 2014 | Compaq Computers & Internet
HP 255 How do I setup bootable disk ? I have tried esc and seled internal cd-dvd room but it doesn't work
On the HP System, you'll need to press the escape key as the system is starting up, and then hit F9 to get to Boot Device Options. Once there, you can set the boot order. After you've set the boot order, you'll also need to make sure that you have bootable files in the device that you've selected as the first boot device.
For example, if you've set the first boot device as CD-ROM drive, and the second is the Hard Disk Drive, then you'll have to make sure that there's a bootable CD/DVD in the drive when you start the system. If no bootable files are found on the first boot device, it'll automatically check the next boot device, which is the Hard disk and start booting from the Hard disk.
GuruAid
May 18, 2014 | Computers & Internet
No bootable device found
The Hard Drive is not starting up. You can check the Hard Drive and detach/re-attach. If it's a HDD failure, you will need to replace it.
The other issue could be HDD controller on the motherboard.
90%of the time it's a HDD failure.
Nov 23, 2013 | Computers & Internet
Bootable devise was not found new
Bootable device not found actually indicates the HDD (hard disk) is no longer recognised and either needs to be re-seated or replaced, if the bootable device error message comes up all the time the it will be a definite HDD replacement.
Oct 09, 2013 | Fujitsu LifeBook AH530 NoteBook
When laptop says no bootable device
re-seat hard drive and check settings for boot devices in bios.
run ibm diagnostics and see if it is seeing the hard drive . if it is run the hard drive tests if they pass then you probably have misconfigured the bios settings somehow. if the hard drive is not found or fails the tests then im afraid your going to have to look in to an exspensive data reclamation service, your best bet there is go to the hard drive manufacturer or even ibm itself.
Jun 13, 2013 | Lenovo Computers & Internet
Why is my bootable device not found
It is more than likely the hard drive has issues, have the hardware tested for possible replacement.
Jul 27, 2012 | Acer Aspire One PC Notebook
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Installed a new hdd after my dell 1300 kept saying no bootable device and no hdd found now still says no bootable device restore cd wont start ether.
Have you tried accessing the bios and resetting it to factory default settings? Sometimes this will get the laptop to recognize the hdd. Otherwise, it may be either the connection isn't secure, or the bios has become corrupt and you may need to update (flash) the bios
Mar 05, 2010 | Dell Inspiron 1300 Notebook
Fujitsu LifeBook A6010 Notebook Logo
82 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
