Question about Tomtom Tom Tom RDS-TMC Traffic Receiver (9V00.080)
How do I change from mph to kml on my tom tom in my mazda CZ5
What is a KML Report?
What is KML? KML is a file format used to display geographic data in a mapping application, such as Google Maps for mobile. You can create KML files to pinpoint locations, add image overlays, and expose rich data in new ways. KML is an international standard maintained by the Open Geospatial Consortium, Inc. (OGC).
Keyhole Markup Language Google Developers
Jul 15, 2015 | Office Equipment & Supplies
Tip
Upload and Download to an Explorist 100
Summary:
Even though the Explorist 100 does not come with a data cable, or software to download or upload data to a computer, it is possible using an after-market cable and a nifty piece of software.
What I use: Note: be sure to download the software for the USB adaptor from here
  • GPSBabel software (free) from http://www.gpsbabel.org
  • A macintosh iMac and a Macintosh Macbook (but it should work fine on a PC)
What I do:
  • attach the cable to the back of the 100 as shown here
  • READ the pages at pc-mobile carefully!
  • Either use the GUI version or command line version of GPSbabel
See examples below for some usage tips....
Examples:
  • [command line] - output to Google earth format!
  1. ~/applications/gps/current/gpsbabel -t -i 'magellan' -f /dev/cu.usbserial -o kml -F 2-feb-08-track.kml
  2. ~/applications/gps/current/gpsbabel -w -i 'magellan' -f /dev/cu.usbserial -o kml -F 2-feb-08-waypoint.kml
  3. ~/applications/gps/current/gpsbabel -r -i 'magellan' -f /dev/cu.usbserial -o kml -F 2-feb-08-route.kml
where...
-t = tracks
-w = waypoints
-r = routes
-i = input format
-f = input file
-o = output format
-F = output file
Troubleshooting:
  1. If you get a speed or connectivity error from GPSbabel:
  • [on a Mac] check to see if /dev/cu.usbserial exists usng a terminal
  • retry the command ... sometimes the 100 doesn't seem to initialise properly
  • Check the FAQ's at http://www.gpsbabel.org
[Note: there may be other types of cable / software available, other than the items mentions here]
on Feb 03, 2008 | Magellan eXplorist 100 GPS Receiver
Tip
How I Download and Upload data from my Explorist...
Summary:
What I do:
Examples:
where...
-t = tracks
-w = waypoints
-r = routes
-i = input format
-f = input file
-o = output format
-F = output file
Troubleshooting:
I have a van mazda mpv 98, rpm going over 3000 and the van its only 45/ mph take to long to change gears
So if it is to hard to change gears it might be you have transmission problems . And to support that it also might be a shaky ride
May 26, 2012 | 1998 Mazda MPV
How can i change my r1 clocks from kph to mph 2001 model oldshape
Hi, Tom for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/104-04-06-r1-mechanical-help/247052-changing-display-kph-mph.html
How to Change the Time on R1 R6 kmh MPH Setting
2000 2001 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 01, 2010 | 2000 Yamaha YZF-R1
I have hoshizaki kml 450 mah and i need water pump for it can you give me the part number . old onr is burnt out
I can get that pump. Look us up on the repair directory under refrigerators zip code 60060
Northeast Cooling LLC :)
Oct 01, 2009 | Hoshizaki KML-451M Low-Profile Crescent...
98 mazda millenia shaking front end at 40 mph?? any clues??
try the simple solution first put your front tires on back and back tires on front. check your air pressure then take it for a drive and see if any thing has changed. if so you probably have a badly worn tire. if no change have someone move the steering wheel back and forth wyle you are under the fornt of the car (dont forget to chalk the wheels) and see if any of your steering components are loose/moving. if nothing is loose and your tires are good try to bounce the front end. if you can really get the front of the car going up and down pretty easy you havce bad struts/shocks.
Apr 15, 2009 | 2001 Mazda Millenia
Mazda mx-6 fault
try changing the transmisson senser or the wire came off.
Jul 14, 2008 | 1995 Mazda MX-6
Tomtom Tom Tom RDS-TMC Traffic Receiver (9V00.080) Logo
20 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
