Pairing code for brother printer MFC j430w - Office Equipment & Supplies
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
GodBlessU
  • 3513 Answers
SOURCE: I have an error message, Brother MFC-8640D Printer
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
Posted on Jan 15, 2010
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
My Brother Printer MFC-J430W always says "install Magenta Ink" even though it is already installed
reset the engine to the factory. and clean the cupper pins that are on back of cartridge and on the carriage.
Oct 09, 2016 | Brother MFC-J430W Inkjet All-in-One...
My brother j430w is a bad print quality how to solve the problem
in your printer, Click the MENU Button, the INK- CLEANING then ALL then START. try this for 5 times cleaning or more, then try Test Print.
Oct 13, 2014 | Brother MFC-J430W Inkjet All-in-One...
How to cancel brother mfc-j430w displaying "cannot detect"?
Try turning off the printer (hold down the on/off button) then restart your computer.
Aug 16, 2014 | Brother MFC-J430W Inkjet All-in-One...
Brother MFC-J430W INK PROBLEM CANNOT DETECT
Exchange it with a different colour and see if the problem moves to the new position. Its the INK Cartridge. If not then its the ink reservoir system faulty
Apr 11, 2013 | Brother MFC-J430W Inkjet All-in-One...
Brother MFC j430W. How do I correct machine error 48?
The print head circuit or cable is malfunctioning or faulty. Replace the printer. I would suggest the Brother MFC-j450dw/j470dw printer as it is an upgraded and newer version of the j430w. Good luck!
Mar 16, 2013 | Brother DCP 165C Compact Color Inkjet...
Error 76 on brother mfc-j430w after clearing paper jam
Please check this out also. It solved the problem for me.
http://support.brother-usa.com/ModelDocuments/Technical/Service%20Updates/SU_F1379.PDF
Feb 18, 2013 | Brother MFC-J430W Inkjet All-in-One...
BROTHER MFC-J430W
how to reset ink absorber full with brother mfc j430w
Jul 17, 2012 | Brother Office Equipment & Supplies
UNABLE TO INIT. 49 (BROTHER PRINTER MFC-J430W)
dear sir, My printer Brother MFC J430 shows unable to clean 49 in display I have found any solve or suggestion in youtube / Google please suggest me.
email. laskarnet2014@gmail.com
BAHAR LASKAR
SILCHAR, ASSAM
Jun 19, 2012 | Brother MFC 420CN All-In-One InkJet...
53 people viewed this question
jasbo
jasbo
