Question about Car Audio & Video
Wat size box and port do I use for 1 12" pioneer tsw5000 spl, I need to build a box
5 Suggested Answers
SOURCE: Subwoofer Box for four lanzar 15"
Any kind of enclosure that will hold four 15 lanzar in the back of my 1999 GMC S15 SUV.I would like to have the big tom drops for SPL.Also i will be playing some music form time to time and still i need the big (BOOM) for the SPL.I have one amp going to my sub just for my subwoofer it's a 3000 crunch mono amp.Lanzar say there woofer works bets with ports in the box. I just trying to fine out what is the best way to go for the big boom.
Thank You,
Wayne
Posted on Jan 28, 2008
zoomiezz
  • 50 Answers
SOURCE: spl box 12inch pioneer subs pls
this is from pioneer  http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/126763081TRD1217-A.pdf
Posted on Feb 25, 2009
etirbynnor
  • 655 Answers
SOURCE: building a box, need to know best dimensions for box and port
Hello dirt_digger6,
The specific sub you are asking about would seem to be the TS-302F which is the only 12" 800W Pioneer I have located.
Directly from Pioneer's support knowledgebase:
TS-W302F = Ported: 2.5 Cu.Ft. F3 = 39HzPort: 4  x 6.5 tuned @ 37 Hz with 12 % port noise.
An enclosure 16X18X21, constructed from 3/4" MDF will yield 2.69 Cu.Ft., allowing .19 Cu.Ft. displacement for the sub and port.
There's an excellent "box calculator" located here on the12v.com web site. You can measure the space you have to put the box and fiddle with the dimensions to get close to your ideal volume. There are also calculators on the12v.com which will allow you to calculate a port length based on port diameter (or width/height), enclosure volume, and desired tuning frequency.
Hope this helps.
Posted on May 07, 2009
mr1967mejias
  • 637 Answers
I have been building custom enclosures since 1984. First of all I would need to know exactly what type of vehicle you were trying to install the enclosure into. You will need 8-10 cubic feet for this totally closure. I'm not too sure if you have enough room for this if it's going sometimes of small s_u_v you definitely have the room. I would use a 4 inch by pennington lane ports 1 in eating closure but you might even think about making to sebring closures and bringing them together because you're going to have a lot to flexing with that money into of what first. There again I need to know how much power you're driving to them as well and in what type of configuration you'll be connecting them. Good luck and hit me back up with any questions I will be glad to help thank you.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Posted on Nov 22, 2014
What is the best vented/ported box size for my 15 sub that will give maximum output and maybe even more?
Unbless you are building a wall...I would never give up my back seat. I built "The Pace-Maker" which won IASCA Enhanced SPL Nationals in 91,92,93 & 94.
Sep 30, 2011 | Lanzar OPTI1533D Car Subwoofer
What size box should i build fro two pioneer 12inch speakers 1200watts each
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches.
Mar 17, 2011 | Pioneer TS-W307D2 12" 1200 Watt Champion...
How do I make a sub box for my single ten inch re sx 10 inch sub dat is 1000 rms. Da box needs to be tuned to 35 hz
yeah, you likely cant build a box to tune 35hz... try just building a box that has correct spec by the manufacture for ideal operation, and adjust the gain accordingly, that's where you will attain your desired hertz, oh and by the way hertz refers to signal, and pulse rate,
Sep 12, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
I don't get d true bass quality from my car system...
Firstly, If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 13 inches x 13 inches x 13 inches.
May 14, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
I have 2 12 inch kickers and have a solid box in my mustang. would it sound better if it was ported?
Kicker speakers always require very large boxes (you're looking at 12 cubic feet for both), when ported. Ported boxes are very sensitive to box size, port tuning etc, so it's probably best to leave it sealed, as they are far more leniant, and sealed boxes are usually 1/2 size of ported boxes. You would get less bass when ported than with sealed (because ported boxes must be bigger to match the sealed ones).
If you wish to experiment with the bass response of speakers, download winISD, and put your speakers in, see what size boxes give you what.
Jan 09, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Building a ported box for three audiofonic 12" subs but need spec
you need to find out factory reccomendations for airspace and port size. Many people with lots of experience building boxes still fail to do this and build good quality boxes, but for the wrong speakers.
Oct 03, 2009 | Audiofonics ADF-272 Car Speaker
Building a box, need to know best dimensions for box and port
Hello dirt_digger6,
Hope this helps.
May 07, 2009 | Car Audio & Video
Need to build a ported sub box for my alpine swr-1222d subs x 2
Try going to Alpine web site, I think they have box building program as well that you just input your sub models into and it gives you blueprints for various types of enclosures. I know Rockford has one and a comparative attachment to compare equipt specs. Or if you call Alpine headquarters you may be able to get info that way, I once sweet talked a rep @ a demo vehicle I met doing some car shows that turned me on to a senior rep @ Korbon Trading the owners of Rockford Fosgate and they gave me specs for a 5 stage band pass box for some competition subs that was more intricate and detailed than anyone before that could find me, Won me first place in spl. Matching your box specs to your subs is crucial and the best specs are often kept a secret for demo competition vehicles! So ask around with some competition guys or other top experts if your real serious about your boooom.
Mar 13, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Spl box 12inch pioneer subs pls
Dec 16, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
what r u trying to do ?shake the car apart?Only kidding that a good questin 4 15: woofers in 1 enclosure>?what kind of enclosure ?how much space r we working with ? i use to be a installer , i also built costume boxes.I need to knoew how much space u have is it a car van,pick-up?I think an iso baric enclosure woukld be your best bet, it would take up the laest space. What frequency are you going to be runnig to your subs? what do you want? punchy bass,over the big tom drops?
what amp r you running or should i say amps?
you'll get the highest spl in a sealed enclosure,but i dont think thats what your looking for.you want heavy vibrating soud,am i correct? a band pass box will give that to you in a close space.bass sounds better and louder the further away you get../.give me more info then ill give you a layout.but 4 now this might help or solve your problem
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
they have all the wiring and p[hyschics and designs of boxes. rating please.
Jan 25, 2008 | Lanzar OPTI1222D Car Subwoofer
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
