Question about Home
Elite 5600 se water softener
I am trying to understand how to program it...it seems very complicated (manual reading and understanding) and since I tried to program it--the salt level in the container has not moved.
  • 641 Answers
SOURCE: LG LD-2160 dishwasher
Get an aqua vac and suck out the water (with the dissolved detergent)from the salt container. Refill it with water and repeat the process couple of times. Fill the container with water and salt and it should be fine. Good luck !!
Posted on Jun 28, 2006
IFIXALL
  • 868 Answers
SOURCE: dishwasher - water softener not working
Make sure your water temperature is at least 120 degrees .Make sure your heater element is working and last of all ,Rinse Aid is the 2nd most important after water temp.
Posted on May 26, 2008
  • 5 Answers
SOURCE: salt for DDW1805 Danby
I use ordinary household water softener salt crystals, not pellets, or table salt. The table salt often is not as refined as softener crystals, and can damage the dishwasher's softener in time. Also, the water softener salt comes in a large bag (around 25-50 lbs) for about $6 US.
Posted on Jul 28, 2009
SOURCE: I have a culligan,gold series water softener.The
call your culligan service department. they will tell you what to look for.
Posted on Dec 22, 2009
  • 19 Answers
SOURCE: my water softner pumps water into salt container,
Your line running from the softener has an air leak, inspect your connections, redo them to ensure sealing
Posted on May 18, 2010
How do I programme my digital thermostat?
Repost question with link to product manual, or photo of timer
This will allow expert to view the product and maybe help you program the timer to match your schedule
Gene
Water Heater Timers Save Money
Nov 18, 2014 | Hardware & Accessories
Do not understand what the white spot on dial is for, on the 5600 water sofener.
The white dot you refer to is on the gallon wheel ? Upper right hand corner ??? That dot is the starting point for the gallon counter to read "soft water gallons used". If you turn that dial counter clockwise all the way around to "0", then turn the big main dial on the front...CLOCKWISE ONLY!!! this looks like an oven dial, you'll see that the gallon wheel will turn one complete revolution and end up back where it started, that is, the arrow will be opposite the white dot ! That white dot is critical to achieve the correct capacity recovery, based on how hard the water is and how big the cylinder is.
Dec 09, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Have a fleck 5600 water softener timer (not economider) dont understand the setting of the days of week when there is 12 pointers on the skipper wheel?
The 12 day wheel is used primarily so that the unit does NOT regenerate on the same day of the week, every week.
There is a 7 day wheel available for this valve so if you irrigate on specific days, and you need it to cycle on specific days, you have the ability to do it without the softener cycling at the same time as watering schedule.
Nov 15, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
I need to know how to set the program on an elite water softener
You can find your owners manual here. http://www.nelsencorp.com/default.aspx?page=customer&file=customer/nelcor/customerpages/Fleck_Serv_Man.htm
Your system is a fleck 5600SE
RJ
Apr 12, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Water Softener won't regenerate
mmmm.
I see they charge for a user manual!
I am not familiar with this controller. Is there a manual overide - a large screwdriver slot on the frint of the main shaft?
If so, you should try turning that (clockwise) to the next position and see if the moter will drive it from there. If not, then take it right through 360 degrees, one step at a time.
If it does not work on the next cycle then you may have to replace the controller.
Feb 20, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
My water softener seems to be working, but my water feels nasty, like it's not working
If you have a three valve bypass the center "bypass" may be open and letting hard water past softener.
RJ
Dec 23, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Water softener seems to be draining all the time
http://www.puritecwatersofteners.com/documentation/Hydrotech_5600MI_manual.pdf
I'm pretty sure this is the manual for your unit. It might not be exactly like the one you have but at least could give you info for it. This is something you might have to contact the manufacture for. Hope this helps!!
Mar 31, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Manual
May I get the model # to help you more
Feb 12, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
