Question about Dell Inspiron XPS M1710 Notebook
Cd-rom not comin out3weotuwik
131dsfafsdfsaf cdrom not working !
  • 55 Answers
There is a small pin whole where the dvd drive is push it in and it should come out. Nice Posting it 5 times! I guess I'll post it 5 times.
Posted on Aug 27, 2007
SOURCE:
I have IBM think pad Notebook and I can't play CD in my CD Rom CD Rom Name is: HL-DT-ST DVD -Rom GDr808 2n I wanted just play a simple audio CD or install some Software with install CD but I could not....
If your CDROM is older than a year than you need to take it to repair person and ask for service of the device. He will carefully clean the sensitive lense and other parts of the CDROM. If the CDROM does not work even after that you need to retire it and get a new one.
The CDROM drivers are built into windows. Windows detect the device driver once you start your computer with a CDROM in a working order.
Good Luck!
Feb 03, 2011 | Computers & Internet
Tip
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
Thanks
Proton
on May 12, 2010 | Computers & Internet
My desk top Dell optiplex GX 260 CD Rom drivers corrupted, G: Drive does not display, kindly send me drivers.
CD Rom do not need any extra drivers, the drivers are provided by your Operating System ie Windows.
The only thing that need updating for a CDROM, may the firmware for the CDROM.
Most probably your CDROM has malfunction or faulty. Replace the CDROM drive.
Aug 23, 2010 | Dell Computers & Internet
Cd brokes in cd rom
IS IT ON?...DOES CDROM HAVE POWER GETTING TO IT FROM PC? Next to open/close switch there is a small pin-hole. Push a paperclip into this hole and gently pull out tray...try gently pushing tray back in and watch for a blinking green light;if none either the cdrom is not getting power, or it has quit working
Mar 20, 2010 | E-Machines emachines (emachinees) CD-ROM...
No matter what i do cd rom not detecting
check whether the powe plug has been inserted properly and the power plug is working fine. Even though if the power plug inserted is working fine and CD ROM not detecting means CD ROM was damaged.
Sep 04, 2009 | Intel Motherboard
CDrom drive is no longer working. When I insert
You can try to transfer your cdrom content to a flash drive if your laptop support usb port.
Apr 17, 2009 | Sony VAIO FX301 PC Notebook
IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
Nov 24, 2008 | IBM ThinkPad T21 Notebook
My Cd-Rom/DVD-rom don't work. It doesn't open any folder. I thought I have problems with drivers: SCSIVAX DVD/CD-ROM SCSI CdrOM DEVICE DVD-ROM SD-R2102 TOSHIBA LAPTOP SATELLITE 5005-S507 THANKS, OSCAR
According to the Toshiba website, the scsi cd-rom/dvd-rom does not require a driver to operate, but the driver for the scsi controller card it plugs into may need to be reinstalled or updated. Visit the following link, and go to the section labeled scsi cdrom/dvdrom. At the bottom of this section there are two links to websites where you may be able to find the drivers for your scsi controller card.
http://sdd.toshiba.com/main.aspx?Path=8100000000220000000100006598000000E7/810000000C58000000010000659C00002C36
Apr 09, 2008 | Computers & Internet
Missing cdrom drive
Is the LED of your CD ROM blinking? If yes then go to device manager by right clicking the My Computer icon and then click the Properties command. In the Properties window select the Hardware tab and then click the device manager. Is the CD ROM entery there! yes> right click and enable the device. If no then reformat your hard disc and reinstall.
In case your CD ROM's LED is not blinking (Rarest case) then simply check all the cables connected to it, atleast the power cable. if it is still not working, your CD ROM got damaged and there is a time to change it.
Feb 04, 2008 | Computers & Internet
Compaq Presario V2000
somthing thats worth trying is going into my computer, right click on the cdrom drive and click eject if it works that way then its software thats stopping it from ejecting, if it still dont work take a paperclip and push it in the small hole in the cdrom drive and it will pop out its only a temporary thing but it works to get the cd out.. All the Best John
Mar 07, 2007 | Compaq Presario 1200,1600 (297657-001)...
Dell Inspiron XPS M1710 Notebook Logo
Ekse
Clive
Clive
