Question about Nokia N70 Cellular Phone
I cant updet my nokia n70
I cant updet my nokia n70 (3mobile)network.....pls help me to change my nokia firmware version my cureent version is 2.0539.1.2 pls help me outttttttttttt
  • 4 Answers
Can you give some other codes for mobile format n70
Posted on Mar 30, 2009
SOURCE:
My nokia 5233 switchoff automatically.when i switchon my phone,after sometime it switchoff automatically.i restore or format my phone two times,but there is no use.sir pls suggest a solution for this...
Take the steps...
  • backup everything
  • switch it off
  • long press green, red and camera buttons along with the power button until the nokia hands show (hard reset).
  • Then set everything
  • after this method, just *#7370# soft reset
  • If it dont work, change the firmware version
  • pls vote!!
Sep 24, 2011 | Cell Phones
I cnt rmember the code i saved. i want to restore the factory settings and remove or change the lock code..pls. help. my imei number is 353382041736997.tnx
( for Nokia 5800XM - use the following buttons to do a hard reset, GREEN/RED/CAMERA keys pressed all at once on power up. this will only work on 5800's that have firmware version 20... and up. )
Feb 10, 2011 | Nokia 5800 XpressMusic Smartphone
I cant access my yahoo messenger, each time I sign in it tell me it encountered a problem that I should check my connection. Mean while I am connected to the internt
buDdy please check ur firewall settings.. and configuartion ,, try reinstalling messenger ..after having removed ur cureent version (restart aftr uniinstall) Hope diz helps..
Jan 31, 2011 | Computers & Internet
I have nokia c3 just bought 4 days ago, my problem is.. my FM radio didn't work I connect the headphone but still didn't work. Pls help me to solve this.. thnx in advance
Hello
To get the transmission of FM in Nokia N79. You have to upgraded to firmware version 31.002. FM Transmitter will not work with firmware version 20.xxx,
Good Luck,
Hope it help, do rate the solution if so,
CMPTRLINK
Dec 13, 2010 | Nokia N79 Cellular Phone
How i repair 73 network prob
Try to flash your firmware to the newest version. Most likely Network problem I had similar problem with my N70 once but then once I got out of that place it worked fine.
or
\Have you change a new PA(power amp)or any hardware part on your Nokia N73 cellphone? You could try a factory restore on the handset. If this fails you would need to book it in to your nearest Nokia Repair centre for it to have a firmware update
Jun 01, 2010 | Nokia N73 Cellular Phone
Nokia 1650 Firmware Update
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Updating Nokia Mobile Phone Firmware Here I’ll tell you the things you need to do in order to update the embedded firmware in your Nokia cell phone.
Things to do before a firmware update:
  1. Install Nokia PC Suite, and back up all the stuff from your phone to your computer.
  2. Charge your phone battery to its full level.
  3. Beware that any hindrance (like power off, etc.) during the update process can damage your phone.
Let’s get started.
  1. In your Nokia mobile phone, type in *#0000#
    Your Nokia mobile will now display the firmware version it’s running
  2. Carefully open the back case of your mobile, and also take away the battery.
  3. Note the product number down
  4. Go here and type the product number. You’ll now know if a new version of firmware for your Nokia mobile phone is available
  5. Download the Nokia Software Updater. Click here to download it
  6. Install the Nokia Software Updater (I think it’s recommended to run it if you have more than 256 MB of RAM on your computer)
  7. Connect your Nokia mobile phone via the USB port, and also make sure your computer is connected to the internet
  8. Run the Nokia Software Updater by clicking on the icon on your desktop
  9. The Nokia Software Updater connects to the internet, checks for updates, and then detects your phone to start installing firmware updates for your Nokia phone
  10. You might see some fuzzy things going on in your Nokia phone, and that’s perfectly normal to happen during a firmware update
  11. When all’s done, the updater gives a confirmation message and then the phone restarts
  12. You can now disconnect the phone from the computer
That’s how you upgrade your Nokia mobile phone’s firmware. Let me know in the comments if you have any question.
Oct 21, 2009 | Nokia 1650 Cell Phone
Cant update ota nokia 5800 need server profile for t moblie nokia 5800 rm428 nokia software updater has only v21 and v31 is out but i cant get it plz help me Thanks
This is up to your network operator. Your Nokia 5800 has a firmware version and product code that will indicate its a T Mobile phone
Once they have approved v31 then that upgrade will be available to you.
You can try to hack and change the product code - but that invalidates any warranties etc etc
Sep 25, 2009 | Nokia 5800 XpressMusic Smartphone
Unlock security code for nokia3110c
Hi sir, i have nokia 3110c and i have forgot the security code which i had changed from default i.e 12345..and the new security code i had forgot...please help me out to unlock mine phone as if i have mine important contact numbers and data in dat phone pls help me out for this...
Jul 09, 2008 | Nokia 3110 Cellular Phone
Firmware Upgradation Failure
Which version of firmware did u try? Is it 3.0510.0? If you haven't tried then try installing this.From what I have heard this doesn't have anything extraordinary but its good enough to keep your phone to running smoothly!
Sep 25, 2007 | Nokia 3230
Nokia N70 Cellular Phone Logo
111 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
