Question about Beverage-Air CFG24 Freezer
Where do i find a ballast for the lighting? - Beverage-Air CFG24 Freezer
J2GF-40S ColdTech display freezer merchandiser no lights come on
Sounds like a loose wire since the move. Check you have power at the switch (in and out). If you have, check the starters and ballasts
Apr 14, 2012 | Coldtech 40 cu. ft. / 1133 liter...
GDM-49
http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
Go to the above web site. It should be the installation manual for your unit. It has lots of good stuff.
Hope this helps
Nov 13, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Ballast
You haven't supplied a model number... Makes a big difference. Generally speaking though you pull off the bottom louvered section and it will be inside of a post where the condensing unit plugs in or mounted against the sidewall.
Jul 04, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Lights wont come on in the cooler
underneath the unit in the metal box there is a ballast for the lights check it to see if it is getting power and or producing power to the bulbs
Jun 15, 2009 | True 23 cu. ft. / 651 liter Commercial...
Hussman DCCG Freezer
are they the florescent tube type?? i suspect that the ballast went bad
Apr 15, 2008 | Hussmann Commercial Freezer DCCG-12
Beverage-Air CFG24 Freezer Logo
19 people viewed this question
Top Beverage-Air Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Michael Youngman
Michael Youngman
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
